查看: 3529|回复: 0
[NI驱动程序] NI-SCOPE 3.8.7 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE3.8.7
    9 小时前
    发表于 2021-3-16 23:26:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    3.8.7
    文件大小: 1637485566 字节 (1.53 GB)
    修改日期: 2011-09-30 04:56
    MD5: acdc029d798e91c68fc9b08b2ac22abc(官方正确)
    SHA1: 093feddcb0539a913f9a3bab6d86f9558f843514
    SHA256: dd9f5f5f31e794f98715f4d35143f6322a30b1906fa67ed578b316085b58fa5d
    CRC32: dc5bec36
    SCOPE3.8.7.txt (594 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SCOPE ReadmeVersion 3.8.7
    Thank you for using NI-SCOPE. This file contains important information regarding NI-SCOPE and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Installing/Uninstalling/Modifying NI-SCOPE
    • Programming in NI-SCOPE
    • Known Issues
    • Bug Fixes
    New Features in NI-SCOPE 3.8.7
    • Added critical bug fixes for NI 5185/5186 digitizers
    New Features in NI-SCOPE 3.8.6
    • Added support for NI-RFSA 2.5
    New Features in NI-SCOPE 3.8.5
    • Added support for LabVIEW 2011
    • Added the following NI-TClk functions/VIs and attributes/properties:
      LabVIEW VIC/C++ Function
      niTClk Setup For Sync Pulse Sender SynchronizeniTClk_SetupForSyncPulseSenderSynchronize
      niTClk Synchronize to Sync Pulse SenderniTClk_SynchronizeToSyncPulseSender
      niTClk Finish Sync Pulse Sender SynchronizeniTClk_FinishSyncPulseSenderSynchronize
      Labview PropertyC/C++ Attribute
      NI-TClk SyncPulseSender:External Pulse SourceNITCLK_ATTR_SYNC_PULSE_SENDER_SYNC_PULSE_SOURCE
    • Added support for the NI PXIe-5185/5186, 12.5 GS/s high-speed digitizers
    • Added support for including NI-SCOPE run-time in custom installers built using National Instrument Application Development Environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using National Instruments high-speed digitizers.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX), NI LabVIEW Signal Express, or the NI-SCOPE Soft Front Panel.
      • The run-time installer does not support upgrading from NI-SCOPE 3.6.x or earlier and NI-DAQmx 8.9.x or earlier.
      • The run-time installer does not support the NI 5102, NI 5112, NI 5620, or NI 5621.
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductWindows XPWindows Vista
    32-Bit
    Windows Vista
    64-Bit
    Windows 7
    32-Bit
    Windows 7
    64-Bit
    NI PXI/PCI-5102
    Yes
    Yes
    No
    Yes
    No
    NI PCMCIA/USB/AT-5102*
    Yes
    No
    No
    No
    No
    NI PXI/PCI-5105
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5112
    Yes
    Yes
    No
    Yes
    No
    NI PXI/PCI-5114
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PXIe/PCI-5122
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5124
    Yes
    Yes
    Yes
    Yes
    Yes
    NI USB-5132/5133
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5142
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5152
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5153
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5154
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXIe-5185/5186
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI-5620
    Yes
    Yes
    No
    Yes
    No
    NI PXI-5621
    Yes
    No
    No
    No
    No
    NI PXIe-5622
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI-5900
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PCI-5911*
    Yes
    No
    No
    No
    No
    NI PXI/PCI-5922
    Yes
    Yes
    Yes
    Yes
    Yes
    *NI PCMCIA/USB/AT-5102 and NI PCI-5911 are Legacy products.
    Note: MXI-4 is supported on Windows XP and later. MXI-3 is supported only on Windows XP.
    This section lists the minimum system and the recommended system for using NI-SCOPE.
    NI-SCOPE 3.8.7 and later support the following operating systems:
    • Windows XP (32-bit)
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-SCOPE 3.6 or earlier.
    NI-SCOPE 3.8.7 and later support the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      Windows XP: 128 MB
      Windows 7/Vista: 512 MB
    Recommended System
    • RAM—
      Windows XP: 256 MB
      Windows 7/Vista: 1 GB
    • One of the following application development environments (ADEs):
      • LabVIEW 8.6.1, 2009 SP 1 (32-bit), 2009 SP 1 (64-bit), 2010 SP 1 (32-bit), 2010 SP 1 (64-bit), 2011 (32-bit), or 2011 (64-bit)
      • LabVIEW Real-Time Module 8.6.1, 2009 SP 1, 2010 SP 1, or 2011 (If you are running your application on an RT target, at least 128 MB of memory is required)
        Note: Not all devices are supported by the LabVIEW Real-Time Module.
        NI 5105
        NI 5114
        NI 5122
        NI 5124
        NI 5142
        NI 5152
        NI 5153
        NI 5154
        NI 5185
        NI 5186
        NI 5622
        NI 5900
        NI 5922
    • LabWindows/CVI 8.5.1 or later
    • LabWindows/CVI Real-Time Module 9.0 or later (If you are running your application on an RT target, at least 128 MB of memory is required)
    • Microsoft Visual Basic 6.0
      • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
    • : is an alias for the following National Instruments file folder location:
      • Windows 7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows XP/2000
    and Windows 7/Vista 32-bit
    NI-SCOPE\Drivers\niScope
    NI-SCOPE Function Panel\Drivers\niScope\niScope.fp
    NI-SCOPE Examples\niScope\Examples
    NI-SCOPE Header files\Include
    NI-SCOPE Import Library files (32-bit)\Lib
    NI-SCOPE Import Library files (64-bit)\Lib_x64
    NI-SCOPE DLL (32-bit)\Bin
    NI-SCOPE Firmware UpdatersProgram Files\NI-DAQ\fpgafiles
    Additional File Locations for Windows 7/Vista 64-bit
    ItemInstalled Location on Windows Vista 64-bit
    NI-SCOPE DLL (64-bit)\Bin
    NI-SCOPE Firmware UpdatersProgram Files (x86)\NI-DAQ\fpgafiles
    Most documentation is available at Start»All Programs»National Instruments»NI-SCOPE»Documentation. The documentation set is composed of the following documents:
    • NI High-Speed Digitizers Getting Started Guide
    • NI High-Speed Digitizers Help
    • Device Specifications
    • Calibration Procedures
    Note: Printed copies of device specifications are shipped with each device.
    Installing/Uninstalling/Modifying NI-SCOPEInstalling NI-SCOPE
    This section provides information on installing NI-SCOPE and NI-DAQ and upgrading from previous versions of NI-SCOPE.
    NI-SCOPE installs NI-DAQ if it is not already installed, or if an earlier version of NI-DAQ is installed. NI-DAQ support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQ is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    Upgrading from NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    Upgrading from NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    • Click Change/Remove.
    • Select NI-SCOPE 3.8.7 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    Do not attempt to uninstall by deleting files, which may be shared with other programs. The following additional software packages may have been installed as part of the NI-SCOPE installation. Exercise care when removing these packages because they may be used by other NI products:
    • IVI Compliance Package 4.4
    • NI-VISA 5.0
    • NI-DAQmx 9.1.7
    • Traditional NI-DAQ 7.4.4
    • Measurement & Automation Explorer 4.7.2
    • NI Hierarchical Waveform Storage 1.4.9
    • NI Spy 2.7.2
    NI-SCOPE provides an intuitive, full-featured interface for programming your hardware. NI-SCOPE is IVI-Scope compliant. For more information, refer to niScopeIVIComplianceDocument.txt.
    Software Examples
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    The NI-SCOPE Soft Front Panel (SFP) is a software oscilloscope application for NI high-speed digitizers. It has the following features:
    • Familiar interactive user interface
    • Robust architecture
    • Scalar measurements
    • Save/load waveforms
    • Save/load configurations
    • Low CPU usage
    The NI-SCOPE SFP demonstrates some of the capabilities of NI high-speed digitizers and enables you to start using your new digitizer immediately without the need to know a programming language. The NI-SCOPE SFP is installed by default as a feature of the NI-SCOPE installation. To remove the NI-SCOPE SFP use the Add/Remove Programs option.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI-SCOPE 3.8.7.
    The following list contains changes from earlier versions of NI-SCOPE to NI-SCOPE 3.8.7. If you have a Bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE.
    Bug IDFixed Issue
    NI-SCOPE
    314046/314048Fixed an issue where NI-SCOPE 3.8.5 and 3.8.6 could corrupt the EEPROM on NI PXIe-5185/5186 during a self-calibration procedure.
    Using Microsoft Silverlight
    © 1999–2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-8 19:07
