查看: 2996|回复: 0
[NI驱动程序] NI-SCOPE 17.1.2 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE17.1.2
    10 小时前
    发表于 2021-3-17 00:08:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    17.1.2
    文件名: NI-SCOPE\Win\NISCOPE1712.zip
    文件大小: 2396388089 字节 (2.23 GB)
    修改日期: 2017-08-02 03:26
    MD5: e1523413208a9335f97d5398345810c6(官方正确)
    SHA1: 5244227a403c58429f850e696cdd25cc11834766
    SHA256: b3c295ddaf01679e755347de9258698f5c57899da1587cb86dd1d34563fee95e
    CRC32: 9399279e
    SCOPE17.1.2.txt (589 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-SCOPE 17.1 Readme
    March 2017
    This file contains important information about the NI-SCOPE driver, including installation instructions, new features, a partial list of bugs fixed for NI-SCOPE 17.1, and known issues.
    Driver Version Naming Changes
    NI-SCOPE allows you to implement various acquisitions, measurement and analysis functions, and the functionality of traditional oscilloscopes. NI-SCOPE also includes the NI-SCOPE Soft Front Panel, which allows you to use your NI digitizer without programming.
    NI-SCOPE 17.1 has the following requirements:
    • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
    • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
    • If you are running your application on an RT target, at least 128 MB of memory
    NI-SCOPE 17.1 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016, NI-SCOPE dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SCOPE will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SCOPE to an unsupported OS. Additionally, after installing NI-SCOPE 17.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SCOPE supports the following application software versions, including service packs:
    If you are using the NI-SCOPE .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SCOPE .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    Application SoftwareVersions Supported by NI-SCOPE 17.1
    LabVIEW2014, 2015, 2016, 2017
    LabVIEW Real-Time Module2014 SP1 or later
    LabWindows™/CVI™2014 SP1 or later
    LabWindows™/CVI™ Real-Time Module2014 SP1 or later
    Microsoft Visual C++ (MSVC)6.0 or later
    NI-SCOPE installs NI-DAQ if it is not already installed, or if an earlier version of NI-DAQ is installed. NI-DAQ support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQ is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    • From NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    • From NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    Uninstalling NI-SCOPE
    As part of the NI-SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages:
    • NI-DAQmx 17.0
    • Traditional NI-DAQ 7.4.4
    • NI Measurement & Automation Explorer 17.0
    • NI Hierarchical Waveform Storage 17.0
    • NI I/O Trace 17.0
    • NI-SCOPE 17.1 adds support for the following PXIe-5172 devices:
      • PXIe-5172 (4 channel, 325T FPGA)
      • PXIe-5172 (8 channel, 325T FPGA)
      • PXIe-5172 (8 channel, 410T FPGA)
    • NI-SCOPE 17.0 adds support for LabVIEW 2017 and LabVIEW NXG hardware and software.
    • NI-SCOPE 16.1 adds support for the PXIe-5164.
    • NI-SCOPE 16.0 adds support for LabVIEW 2016.
    • NI-SCOPE 15.1.1 adds bug fixes for incompatability with NI-RFSA and NI-RFMx.
    • NI-SCOPE 15.1 includes the following new features:
      • Support for the PXIe-5170R and the PXIe-5171R reconfigurable oscilloscopes
      • Support for FPGA extensions
    • NI-SCOPE 15.0 adds support for LabVIEW 2015.
    • NI-SCOPE 14.1 includes the following new features:
      • Support for the PXIe-5105 and the PXIe-5114
      • Debugging for the NI-SCOPE Soft Front Panel
    • NI-SCOPE 14.0 adds support for LabVIEW 2014.
    • NI-SCOPE 4.1.3 adds a bug fix for VIs in LabVIEW 2013.
    • NI-SCOPE 4.1.1 adds a critical bug fix for an issue affecting NI PXIe-5185/5186 digitizers.
    • NI-SCOPE 4.1 includes the following new features:
      • Support for the PXIe-5160, 2.5 GS/s high-speed digitizer
      • NI-P2P support for the PXIe-5160 and the PXIe-5162
    • NI-SCOPE 4.0.5 adds support for LabVIEW 2013.
    • NI-SCOPE 4.0 adds support for the PXIe-5162, 5 GS/s high-speed digitizer.
    • NI-SCOPE 3.9.7 redesigns the NI-SCOPE Soft Front Panel.
    • NI-SCOPE 3.9.6 adds 1MOhm support for the PXIe-5185/5186, 12.5 GS/s high-speed digitizers (new model)
    • NI-SCOPE 3.9.4 adds support for LabVIEW 2012.
    • NI-SCOPE 3.8.9 adds support for NI-RFSA 2.5.2.
    • NI-SCOPE 3.8.8 adds a critical bug fix for the PXI-5900 digitizer.
    • NI-SCOPE 3.8.7 adds critical bug fixes for PXIe-5185/5186 digitizers.
    • NI-SCOPE 3.8.6 adds support for NI-RFSA 2.5.
    • NI-SCOPE 3.8.5 includes the following new features:
      • Support for LabVIEW 2011
      • Addition of the following NI-TClk functions/VIs and attributes/properties:
        LabVIEW VIC/C++ Function
        niTClk Setup For Sync Pulse Sender SynchronizeniTClk_SetupForSyncPulseSenderSynchronize
        niTClk Synchronize to Sync Pulse SenderniTClk_SynchronizeToSyncPulseSender
        niTClk Finish Sync Pulse Sender SynchronizeniTClk_FinishSyncPulseSenderSynchronize
        Labview PropertyC/C++ Attribute
        NI-TClk SyncPulseSender:External Pulse SourceNITCLK_ATTR_SYNC_PULSE_SENDER_SYNC_PULSE_SOURCE
    • NI-SCOPE 3.8 includes the following new features:
      • Support for the PXIe-5185/5186, 12.5 GS/s high-speed digitizers
      • Support for including NI-SCOPE run-time in custom installers built using National Instruments Application Development Environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using National Instruments high-speed digitizers.
        • The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX), NI SignalExpress, or the NI-SCOPE Soft Front Panel.
        • The run-time installer does not support upgrading from NI-SCOPE 3.6.x or earlier and NI-DAQmx 8.9.x or earlier.
        • The run-time installer does not support the NI 5102, NI 5112, NI 5620, or NI 5621.
    The following table details the hardware models supported in NI-SCOPE.
    Hardware ProductSupported Under Windows 10/Windows 8.1 (32-bit)/7 (32-bit)1Supported Under Windows 10/Windows 8.1 (64-bit)/7 (64-bit)
    PXI/PCI-5102
    Yes
    No
    PCMCIA/USB/AT-51021
    No
    No
    PXI/PXIe/PCI-5105
    Yes
    Yes
    PXI/PCI-5112
    Yes
    No
    PXI/PXIe/PCI-5114
    Yes
    Yes
    PXI/PXIe/PCI-5122
    Yes
    Yes
    PXI/PCI-5124
    Yes
    Yes
    USB-5132/5133
    Yes
    Yes
    PXI/PCI-5142
    Yes
    Yes
    PXI/PCI-5152
    Yes
    Yes
    PXI/PCI-5153
    Yes
    Yes
    PXI/PCI-5154
    Yes
    Yes
    PXIe-5160/5162
    Yes
    Yes
    PXIe-5164
    Yes
    Yes
    PXIe-5170
    Yes
    Yes
    PXIe-5171
    Yes
    Yes
    PXIe-5172
    Yes
    Yes
    PXIe-5185/5186
    Yes
    Yes
    PXI-5620
    Yes
    No
    PXI-5621
    No
    No
    PXIe-5622
    Yes
    Yes
    PXI-5900
    Yes
    Yes
    PCI-59112
    No
    No
    PXI/PCI-5922
    Yes
    Yes
    1MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    2NI PCMCIA/USB/AT-5102 and NI PCI-5911 are Legacy products.
    NI-SCOPE versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-SCOPE 17.0 is the version released with LabVIEW 2017. The last version released under the old numbering scheme is NI-SCOPE 4.1.3. The first version released under the new numbering scheme is NI-SCOPE 14.0.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-SCOPE 17.1.
    • For help with the NI-SCOPE driver, refer to the NI High-Speed Digitizers Help, accessible by selecting Help»NI High-Speed Digitzers Help.
    • For help with the NI-SCOPE Soft Front Panel, refer to the NI-SCOPE Soft Front Panel Help, accessible by selecting Help»Online Help.
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    For LabVIEW examples, select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SCOPE are located in the labview\examples\instr\niScope directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The following sections detail considerations for using LabVIEW NXG with NI-SCOPE.
    LabVIEW NXG Hardware SupportInstalling NI-SCOPE for LabVIEW NXG
    NI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-SCOPE for LabVIEW NXG.
    • Click Download LabVIEW NXG 1.0.
    • NI Package Manager installs, then automatically opens a download window.
    • Select LabVIEW NXG Suite and click the green Install button.
    • Select LabVIEW NXG 1.0 and NI-SCOPE.
    • Complete the installer instructions to download LabVIEW NXG 1.0 and NI-SCOPE.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 1999–2017 National Instruments. All rights reserved.
    375360G-01
    GMT+8, 2025-12-8 19:34
