查看: 2909|回复: 0
[NI驱动程序] NI-SCOPE 18.7 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE18.7
    昨天 08:45
  • 签到天数: 3647 天
    连续签到: 9 天
    发表于 2021-3-17 00:18:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    18.7
    文件大小: 2753565355 字节 (2.56 GB)
    修改日期: 2018-12-18 04:51
    MD5: 84c46dd4f9dd5474afa95fb8a7275f0e(官方正确)
    SHA1: faa1781cb7a0d74116bebd9abded114d44811b37
    SHA256: 2c95e16b310e50dee5b120b2b3fadaf12e0808f7a65b772bdf416d92a01e34f7
    CRC32: cfef6cbc
    SCOPE18.7.0.txt (587 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SCOPE 18.7 Readme
    November 2018
    This file contains important information about the NI-SCOPE driver, including installation instructions, new features, and known issues.
    NI-SCOPE is an NI instrument driver that enables you to implement multirecord acquisition, continuous acquisition, multiboard synchronization, more than 50 measurement and analysis functions, and the functionality of traditional oscilloscopes. NI-SCOPE is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the oscilloscope and includes an interactive soft front panel and examples.
    NI-SCOPE 18.7 has the following requirements:
    • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
    • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
    • If you are running your application on an RT target, at least 128 MB of memory
    NI-SCOPE 18.7 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    • Linux
      • Red Had Enterprise Linux Desktop + Workstation 6.x, 7.x
      • CentOS 7.x
      • OpenSUSE Leap 42.2, 42.3
    Note  In 2016, NI-SCOPE dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SCOPE will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SCOPE to an unsupported OS. Additionally, after installing NI-SCOPE 18.7, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SCOPE supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-SCOPE
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW NXG3.0
    LabVIEW Real-Time Module32014 SP1 or later
    LabWindows™/CVI™2013 SP1 or later
    LabWindows™/CVI™ Real-Time Module2013 SP1 or later
    3No support for legacy devices, the PXIe‑5110/5111/5113, the PXIe‑5163, or the PXIe-5164 and PXIe-517x reconfigurable oscilloscopes.
    If you are using the NI-SCOPE .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SCOPE .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-SCOPE installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-SCOPE is available for download from ni.com/downloads/drivers. NI-SCOPE installs NI-DAQ if it is not already installed or if an earlier version of NI-DAQ is installed. NI-DAQ support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQ is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    • From NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    • From NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    Uninstalling NI-SCOPE
    As part of the NI-SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages:
    • NI-DAQmx 17.1.1
    • NI Measurement & Automation Explorer 18.0
    • NI Hierarchical Waveform Storage 18.0
    • NI I/O Trace 18.5
    Notice  Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    Installing NI-SCOPE for LabVIEW NXG
    • NI‑SCOPE 18.7 adds support for Linux.
    • NI‑SCOPE 18.7 adds support for CableSense to the PXIe‑5110, PXIe‑5111, PXIe‑5113, PXIe‑5160, and PXIe‑5162 oscilloscopes.
    • NI‑SCOPE 18.7 adds support for the PXIe‑5163 oscilloscope.
    • NI‑SCOPE 18.7 adds support for variable rate external sample clocks to the PXIe‑5170 and PXIe‑5171 reconfigurable oscilloscopes.
    • NI‑SCOPE 18.6 adds support for the PXIe‑5110, PXIe‑5111, and PXIe‑5113 oscilloscopes.
      • NI‑SCOPE 18.6 adds support for glitch, width, and runt triggering to the PXIe‑5110, PXIe‑5111, and PXIe‑5113.
    • NI‑SCOPE 18.5 adds support for LabVIEW NXG 3.0.
    The following table details the hardware models supported in NI-SCOPE.
    [tr][/tr]
    [tr][/tr]
    Hardware DeviceSupported Under Windows 10/Windows 8.1 (32-bit)/7 (32-bit)1Supported Under Windows 10/Windows 8.1 (64-bit)/7 (64-bit)1
    NI-DAQmx-Based Oscilloscopes
    PXI/PCI-51022
    Yes
    No
    PCMCIA/USB/AT-51022
    No
    No
    PXI/PXIe/PCI-5105
    Yes
    Yes
    PXI/PCI-51122
    Yes
    No
    PXI/PXIe/PCI-5114
    Yes
    Yes
    PXI/PXIe/PCI-5122
    Yes
    Yes
    PXI/PCI-5124
    Yes
    Yes
    USB-5132/5133
    Yes
    Yes
    PXI/PCI-5142
    Yes
    Yes
    PXI/PCI-5152
    Yes
    Yes
    PXI/PCI-5153
    Yes
    Yes
    PXI/PCI-5154
    Yes
    Yes
    PXIe-5160/5162
    Yes
    Yes
    PXIe-5185/5186
    Yes
    Yes
    PXI-56202
    Yes
    No
    PXI-56212
    No
    No
    PXIe-5622
    Yes
    Yes
    PXI-5900
    Yes
    Yes
    PCI-59112
    No
    No
    PXI/PCI-5922
    Yes
    Yes
    SDI-Based Oscilloscopes
    PXIe-5110
    Yes
    Yes
    PXIe-5111
    Yes
    Yes
    PXIe-5113
    Yes
    Yes
    5164 Oscilloscopes
    PXIe-5163
    Yes
    Yes
    PXIe-5164
    Yes
    Yes
    517x Oscilloscopes
    PXIe-5170
    Yes
    Yes
    PXIe-5171
    Yes
    Yes
    PXIe-5172
    Yes
    Yes
    1MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    2Legacy devices.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-SCOPE 18.7.
    The following items are the IDs, versions, and descriptions of a subset of issues fixed in NI-SCOPE releases. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    IDFixed VersionFixed Issue
    71697718.7Implemented various fetch performance improvements for the PXIe‑5110/5111/5113, PXIe‑5164, PXIe‑5170, PXIe‑5171, and PXIe‑5172.
    63949317.2Fixed an issue in which committing a new clocking configuration for the PXIe-5164 without previously phase locking the clock and resetting the device caused LabVIEW to crash.
    64164017.2Fixed an issue causing Traditional NI-DAQ (Legacy) devices to be missing from the NI-SCOPE full installer.
    54602316.1Fixed an issue in which C examples failed to compile in Visual Studio 2015.
    • For help with the NI-SCOPE driver, refer to the NI High-Speed Digitizers Help, accessible by selecting Help»NI High-Speed Digitzers Help.
    • For help with the NI-SCOPE Soft Front Panel, refer to the NI-SCOPE Soft Front Panel Help, accessible by selecting Help»Online Help.
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    For LabVIEW examples, select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SCOPE are located in the labview\examples\instr\niScope directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The following sections detail considerations for using LabVIEW NXG with NI-SCOPE.
    LabVIEW NXG Hardware Support
    The following table details the hardware models supported in NI-SCOPE with LabVIEW NXG.
    [tr][/tr]
    [tr][/tr]
    [tr][/tr]
    PXI/PXIe/PCI-5105
    Yes
    Yes
    PXI/PXIe/PCI-5114
    Yes
    Yes
    PXI/PXIe/PCI-5122
    Yes
    Yes
    PXI/PCI-5124
    Yes
    Yes
    USB-5132/5133
    Yes
    Yes
    PXI/PCI-5142
    Yes
    Yes
    PXI/PCI-5152
    Yes
    Yes
    PXI/PCI-5153
    Yes
    Yes
    PXI/PCI-5154
    Yes
    Yes
    PXIe-5160/5162
    Yes
    Yes
    PXIe-5185/5186
    Yes
    Yes
    PXIe-5622
    Yes
    Yes
    PXI-5900
    Yes
    Yes
    PXI/PCI-5922
    Yes
    Yes
    PXIe-5110
    Yes
    Yes
    PXIe-5111
    Yes
    Yes
    PXIe-5113
    Yes
    Yes
    5164 Oscilloscopes
    PXIe-5163
    Yes
    Yes
    PXIe-5164
    Yes
    Yes
    517x Oscilloscopes
    PXIe-5170
    Yes
    Yes
    PXIe-5171
    Yes
    Yes
    PXIe-5172
    Yes
    Yes
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 1999–2018 National Instruments. All rights reserved.
    375360R-01
    GMT+8, 2025-9-10 06:56
