查看: 2478|回复: 0
[MVTEC] MVTEC Halcon 20.11.0.2 Progress Runtime Version Win64 HALCON20.11.0.2演进运行版 64位Windows版
    昨天 08:45
  • 签到天数: 3641 天
    发表于 2021-3-23 23:34:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.0.2-windows-runtime.exe
    文件大小: 145357080 字节 (138.62 MB)
    修改日期: 2021-03-03 22:31
    版本: 20.11.0.2
    MD5: 4c79c691fbe35de6dc8407a2658e6535
    SHA1: b648bd94580b211c171f17f6cc56508b9a2defa6
    SHA256: a01b2b15364111fd1aeb75650a32e6db1854dcf63de186cef93b344a16b3cfa3
    CRC32: b8245b2a
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    百度网盘下载地址:
    链接:
    提取码:4y8f
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.0.2 PROGRESSHOTFIX FOR HALCON 20.11.0.1 PROGRESS
    This document provides the release notes for MVTec HALCON 20.11.0.2 Progress, as released in January 2021, which is a Hotfix for HALCON 20.11.0.1 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.0.0 Progress.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.0.2 Progress (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.0.2 PROGRESS (HOTFIX)
    The changes in HALCON 20.11.0.2 Progress are described with respect to HALCON 20.11.0.1 Progress.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    GMT+8, 2025-9-4 04:25
