查看: 2437|回复: 0
[MVTEC] MVTEC Halcon 20.11.0.2 Progress deep learning core Win64 HALCON20.11.0.2深度学习内核 64位Windows版
    昨天 08:45
  • 签到天数: 3641 天
    发表于 2021-3-23 23:37:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.0.2-windows-deep-learning-core.exe
    文件大小: 1734605584 字节 (1.62 GB)
    修改日期: 2021-03-03 22:35
    版本: 20.11.0.2
    MD5: 51b7d98755cc4a5ade84eee040a5c8d8
    SHA1: 7c86991d27573e33c9f0e71de3584a85ae6cd170
    SHA256: 0b5187b4bd4f39c614705b441305f9faefefec668b015a923c9963fd8e80572e
    CRC32: f548e5c1
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    百度网盘下载地址:
    链接:
    提取码:xbkj
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.0.2 PROGRESSHOTFIX FOR HALCON 20.11.0.1 PROGRESS
    This document provides the release notes for MVTec HALCON 20.11.0.2 Progress, as released in January 2021, which is a Hotfix for HALCON 20.11.0.1 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.0.0 Progress.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.0.2 Progress (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.0.2 PROGRESS (HOTFIX)
    The changes in HALCON 20.11.0.2 Progress are described with respect to HALCON 20.11.0.1 Progress.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    GMT+8, 2025-9-4 04:18
