查看: 2500|回复: 2
[MVTEC] MVTEC Halcon 20.11.1.2 Steady Deep Learning Core Win64 HALCON20.11.1.2稳定版深度学习内核
    昨天 08:45
  • 签到天数: 3641 天
    发表于 2021-3-24 23:00:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.1.2-windows-deep-learning-core.exe
    文件大小: 1734605368 字节 (1.62 GB)
    修改日期: 2021-03-03 23:05
    版本: 20.11.1.2
    MD5: c006a4dbf3d244c1fe07f0c8866fe014
    SHA1: dc805d986d6e2402e66ed409ee848947f40fc467
    SHA256: e1a0a8dc02dba875cf057e9aa5645a65a9e9305ef400c7bbab2e16e757844a43
    CRC32: caf664d6
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    百度网盘下载地址:
    链接:
    提取码:vt2s
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.1.2 STEADYHOTFIX FOR HALCON 20.11.1.1 STEADY
    This document provides the release notes for MVTec HALCON 20.11.1.2 Steady, as released in January 2021, which is a Hotfix for HALCON 20.11.1.1 Steady. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.1.0 Steady.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.1.2 Steady (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
      • HALCON/PYTHON
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.1.2 STEADY (HOTFIX)
    The changes in HALCON 20.11.1.2 Steady are described with respect to HALCON 20.11.1.1 Steady.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    HALCON/PYTHON
    • The Python examples for HALCON Steady incorrectly required the Python language interface for HALCON Progress. This problem has been fixed.
    发表于 2021-11-9 08:19:37 | 显示全部楼层 来自:江苏省苏州市 电信
    GMT+8, 2025-9-4 04:25
