查看: 2462|回复: 0
[MVTEC] MVTEC Halcon 20.11.1.2 Steady Runtime Version armv7a linux(32bit) HALCON20.11.1.2稳定运行版 32位armv7a linux系统版
    昨天 08:45
  • 签到天数: 3641 天
    发表于 2021-3-24 23:16:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.1.2-armv7a-linux-runtime.tar.gz
    文件大小: 73324122 字节 (69.93 MB)
    修改日期: 2021-03-03 23:11
    MD5: d48a142a72428a4eac6d26715b7f7f83
    SHA1: 08ad911dc4e399651cfb108af3d98a0d923d2bd2
    SHA256: fe5ad60664b3a6afe8bec8d22524a8896a2c7000356b039baf0cd79b2ae8155e
    CRC32: 2ba5abc6
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    百度网盘下载地址:
    链接:
    提取码:dh7t
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.1.2 STEADYHOTFIX FOR HALCON 20.11.1.1 STEADY
    This document provides the release notes for MVTec HALCON 20.11.1.2 Steady, as released in January 2021, which is a Hotfix for HALCON 20.11.1.1 Steady. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.1.0 Steady.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.1.2 Steady (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
      • HALCON/PYTHON
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.1.2 STEADY (HOTFIX)
    The changes in HALCON 20.11.1.2 Steady are described with respect to HALCON 20.11.1.1 Steady.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    HALCON/PYTHON
    • The Python examples for HALCON Steady incorrectly required the Python language interface for HALCON Progress. This problem has been fixed.
    GMT+8, 2025-9-4 04:26
