查看: 3030|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2.2 Win32/64Eng NI-RFSG回放库2.2完整版下载
    9 小时前
    发表于 2021-6-2 11:27:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    2.2 32/64
    文件大小: 325607424 字节 (310.52 MB)
    修改日期: 2016-12-09 00:15
    MD5: 748e429284478034c504846ad0da765f(官方正确)
    SHA1: e02845fd50efa25ba6e9adc89ecde4e7a9529a8e
    SHA256: d8c8f7c41f3a2953389b11976a9bf9f15edc34517ae4a8fd12748eed42bfce3e
    CRC32: 8ce0a2c6
    NIRFSGPL2.2.txt (508 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG Playback Library 2.2 Readme
    December 2016
    Thank you for using NI-RFSG Playback Library. This file contains important information about NI-RFSG Playback Library and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFSG Playback Library
    NI-RFSG Playback Library 2.2 includes the following new features:
    • Support for downloading user waveform
    • Support for retrieving the downloaded waveform names
    • Addition of functions to read the waveform properties from the TDMS file
    • Addition of functions to store and retrieve the RF Blanking Enabled, RF Blanking Marker Source, LO Offset Mode and Signal Bandwidth properties from the NI-RFSG waveform database
    NI-RFSG Playback Library 2.1 includes addition of functions to store and retrieve burst start and stop locations from the NI-RFSG waveform database.
    Supported HardwareVector Signal Generators
    • NI PXIe-5673
    • NI PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help.
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFSG Playback Library 2.2 supports the following operating systems:
    Note  NI-RFSG Playback Library 2.2 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    • Adobe Reader
    Recommended System
    • RAM—4 GB*
    • Adobe Reader
    Note  You should install ADEs, such as NI LabVIEW, or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. To add support for ADEs installed after installing NI-RFSG Playback Library, modify your NI-RFSG Playback Library installation or launch the NI-RFSG Playback Library installer again.
    • LabVIEW 2013 SP1, 2014 SP1, 2015 SP1, or 2016
    Note  NI-RFSG Playback Library does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5*
    * NI-RFSG .NET Class Library 14.5 is required only for .NET support.
      • (64-bit) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\lib32\msvc
    C, .NET
    ExamplesNI-RFSG Playback Library\Examples
    Examples\LabVIEW \examples\instr\niRFSGPlayback
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RfsgPlayback.Fx40.dll
    Documentation for NI-RFSG Playback Library is located at Start»All Programs»National Instruments»NI-RFSG Playback Library»NI-RFSG Playback Library Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFSG Playback Library HelpHTML/Windows HelpInformation about NI-RFSG Playback Library. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFSG Playback Library
    • A complete reference for all NI-RFSG Playback Library programming functions
    NI-RFSG Playback Library 2.2 ReadmeHTML (this document)Information about supported hardware, operating systems, and legal notices.
    To use the NI-RFSG Playback Library .NET API, you must install the NI-RFSG .NET Class Libraries or the NI-RFSG .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-RFSG Playback Library palette VIs are available from the Functions»Measurement I/O»NI-RFSG Playback Library palette.
    You can also access all the installed NI-RFSG Playback Library examples at Start»All Programs»National Instruments»NI-RFSG Playback Library»NI-RFSG Playback Library Examples.
    NI-RFSG Playback Library 2.2 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFSG Playback Library drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFSG Playback Library 2.2and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 2.2 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 2.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFSG Playback Library 2.2 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFSG Playback Library 2.2 installation, the following software is installed. To completely remove the NI-RFSG Playback Library 2.2 installation from your system, you must also remove the following packages:
    • NI-RFSG Playback Library Runtime 2.2
    The following are the behavior changes in NI-RFSG Playback Library 2.2 from NI-RFSG Playback Library 2.1:
    • While modifying the script, NI-RFSG Playback Library uses RF Blanking Marker Source property per waveform, instead of using the RF Blanking Marker Source set on RFSG
    You can access the software and documentation known issues list online. Refer to the NI-RFSG Playback Library 2.2 Known Issues at ni.com for an up-to-date list of known issues in NI-RFSG Playback Library 2.2.
    The following items are changes in NI-RFSG Playback Library 2.2 from NI-RFSG Playback Library 2.1.
    568365Fixed an issue with the niRFSGPlayback Read Waveform From File VI to automatically determine the waveform data type saved in the TDMS file, irrespective of the polymorphic VI instance used.
    © 2015–2016 National Instruments. All rights reserved.
    375556C-01
    GMT+8, 2025-12-8 19:07
