查看: 3021|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2.5 Win32/64Eng NI-RFSG回放库2.5完整版下载
    9 小时前
    发表于 2021-6-2 12:00:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    2.5 32/64
    文件大小: 326307840 字节 (311.19 MB)
    修改日期: 2018-07-03 16:09
    MD5: d336d8309e6ee188ad2c1b49e3d4bb59(官方正确)
    SHA1: c5e4f472f66892df4016384c8cd686b91f9be3ed
    SHA256: 335f37327bae844cc950ad219abd75e1cf62896c0ccc7530829fe1ad33ab25df
    CRC32: 222e21f2
    NIRFSGPL2.5.txt (506 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG Playback Library 2.5 Readme
    June 2018
    This file contains important information about NI-RFSG Playback Library and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFSG Playback Library 2.5 adds support for LabVIEW 2018 (32- and 64-bit).
    NI-RFSG Playback Library 2.4 includes addition of functions to retrieve the waveform file version.
    NI-RFSG Playback Library 2.3 includes the following new features:
    • Addition of functions to store and retrieve PAPR (Peak Average Power Ratio), Runtime Scaling, and Waveform Size properties from the NI-RFSG waveform database
    • Addition of functions to read the PAPR, Runtime Scaling, and Waveform Size properties from a TDMS file
    • Addition of functions to read individual waveforms from a TDMS file by index
    • Support for TDMS waveform files created with NI-RFmx Waveform Creator 1.0
    • Support for waveforms file version 2.0, for which PAPR and Runtime Scaling properties are mandatory
    Supported HardwareVector Signal Generators
    • NI PXIe-5673
    • NI PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help.
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFSG Playback Library 2.5 supports the following operating systems:
    Note  In 2016, NI-RFSG Playback Library dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFSG Playback Library 2.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 2.5 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  NI-RFSG Playback Library 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. To add support for ADEs installed after installing NI-RFSG Playback Library, modify your NI-RFSG Playback Library installation or launch the NI-RFSG Playback Library installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFSG Playback Library does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5*
    * NI-RFSG .NET Class Library 14.5 is required only for .NET support.
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\lib32\msvc
    C, .NET
    Examples\NI-RFSG Playback Library\Examples
    Examples\LabVIEW \examples\instr\niRFSGPlayback
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RfsgPlayback.Fx40.dll
    Documentation for NI-RFSG Playback Library is located at Start»All Programs»National Instruments»NI-RFSG Playback Library»NI-RFSG Playback Library Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFSG Playback Library HelpHTML/Windows HelpInformation about NI-RFSG Playback Library. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFSG Playback Library
    • A complete reference for all NI-RFSG Playback Library programming functions
    NI-RFSG Playback Library 2.5 ReadmeHTML (this document)Information about supported hardware, operating systems, and legal notices.
    NI-RFSG Playback Library palette VIs are available from the Functions»Measurement I/O»NI-RFSG Playback Library palette.
    You can also access all the installed NI-RFSG Playback Library examples at Start»All Programs»National Instruments»NI-RFSG Playback Library»NI-RFSG Playback Library Examples.
    The following are the behavior changes in NI-RFSG Playback Library 2.3 from NI-RFSG Playback Library 2.2:
    • If the burst start and stop locations are present in the TDMS file, the marker locations used for RF Blanking are calculated from the burst locations instead of the RF blanking marker locations.
    • Peak Power Adjustment property is obsoleted. It is now superseded by the PAPR and Runtime Scaling properties.
    • RF Blanking Marker Locations property is obsoleted. It is now superseded by Burst Start and Stop Locations properties.
    • Playback library resets the NI-RFSG Pre-filter Gain property when using the niRFSGPlayback Set Script to Generate VI call for waveforms file version 1.0.
    You can access the software and documentation known issues list online. Refer to the NI-RFSG Playback Library 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFSG Playback Library 2.5.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFSG Playback Library. This is not an exhaustive list of issues fixed in the current version of the NI-RFSG Playback Library. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFSG Playback Library 2.5 from NI-RFSG Playback Library 2.4.
    688176Fixed an issue where an error was thrown when an empty waveform was given as an input to the niRFSGPlayback Download User Waveform (CDB) API.
    697983Fixed an issue where a memory leak was noticed when running the DPD example in a loop.
    694678Fixed an issue where niRFSGPlayback Download User Waveform API was returning errors for NR Waveforms when only 1 symbol was occupied in each of the slots.
    The following items are changes in NI-RFSG Playback Library 2.3.1 from NI-RFSG Playback Library 2.3.
    662178Fixed an issue where the Set Script to Generate API crashed with Wait Marker Exports.
    The following items are changes in NI-RFSG Playback Library 2.3 from NI-RFSG Playback Library 2.2.
    631089Fixed an issue with the niRFSGPlayback Read Waveforms From File VI, where this VI returned corrupted waveforms when the waveforms in the TDMS file were of different sizes. The niRFSGPlayback Read Waveforms From File VI now returns an error in this scenario.
    640839Fixed an issue where the niRFSGPlayback Download User Waveform VI was hanging for some user waveforms.
    © 2015–2018 National Instruments. All rights reserved.
    375556G-01
    GMT+8, 2025-12-8 19:08
