查看: 3397|回复: 0
[NI驱动程序] NI-RFSG Playback Library 19.1 Win32/64Eng NI-RFSG回放库19.1完整版下载
    9 小时前
    发表于 2021-6-2 12:08:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    19.1 32/64
    文件大小: 474935296 字节 (452.93 MB)
    修改日期: 2019-10-18 16:11
    MD5: 260fe2ddbf8af69b407bc35d30ff97f8(官方正确)
    SHA1: de2d614f4a526c81191139a428b397edfd702d67
    SHA256: c3a898f8e06431905fec717d171c477a7db573b75fa8f858985990dd619deab5
    CRC32: 39b3b23b
    NIRFSGPL19.1.txt (564 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG Playback Library 19.1 Readme
    October 2019
    This file contains important information about the NI-RFSG Playback Library, including system requirements and installation instructions.
    NI-RFSG Playback Library Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    NI-RFSG Playback Library allows users to generate waveforms saved in the technical data management streaming (TDMS) file using the NI-RFSG driver. These TDMS files can be created from the NI RFmx Waveform Creator. You can use the NI-RFSG Playback Library to download multiple waveforms to the NI-RFSG vector signal generator memory. You can then generate all these waveforms using either a single script or multiple scripts. The playback library internally retrieves waveform properties from database to calculate and apply appropriate settings on the NI-RFSG driver.
    NI-RFSG Playback Library 19.1 includes the following new features:
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    • Performance improvements to store and retrieve waveform properties and Set Script to Generate APIs.
    NI-RFSG Playback Library 19.0 includes the following new features:
    • Support for PXIe-5830 and PXIe-5831
    NI-RFSG Playback Library 3.0 adds support for PXIe-5820.
    Vector Signal Generators
    • PXIe-5673
    • PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help .
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5841
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsNI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, NI-RFSG Playback Library dropped support for all 32-bit Windows operating systems. NI-RFSG Playback Library will not install or run on an unsupported OS. Refer to NI-RFSG Playback Library Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. To add support for application software installed after installing NI-RFSG Playback Library modify your NI-RFSG Playback Library installation or launch the NI-RFSG Playback Library installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-RFSG Playback Library
    LabVIEW2016, 2017, 2018, or 2019
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs NI-RFSG Playback Library using NI Package Manager. If you do not already have NI software installed, NI-RFSG Playback Library installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    ItemInstalled Location
    Import Library files
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start»All Programs»National Instruments»NI-RFSG Playback Library»NI-RFSG Playback Library Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFSG Playback Library HelpHTML/Windows HelpInformation about NI-RFSG Playback Library. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFSG Playback Library
    • A complete reference for all NI-RFSG Playback Library programming functions
    NI-RFSG Playback Library 19.1 ReadmeHTML (this document)Information about supported hardware, operating systems, and legal notices.
    You can access all the installed NI-RFSG Playback Library examples at Start » All Programs » National Instruments » NI-RFSG Playback Library » NI-RFSG Playback Library Examples.
    The following are the behavior changes in NI-RFSG Playback Library 19.0 from NI-RFSG Playback Library 3.0:
    • Dropped support for LabVIEW 2015.
    The following are the behavior changes in NI-RFSG Playback Library 3.0 from NI-RFSG Playback Library 2.5:
    • Added support to store the detected burst start and stop locations in the waveform database when using the Download User Waveform function.
    You can access the software and documentation known issues list online. Refer to the NI-RFSG Playback Library Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFSG Playback Library . This is not an exhaustive list of issues fixed in the current version of the NI-RFSG Playback Library . If you have a bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFSG Playback Library 19.1 from NI-RFSG Playback Library 19.0
    235505Fixed an issue where symbolic links to instr.lib folder got deleted after installation.
    The following items are changes in NI-RFSG Playback Library 3.0 from NI-RFSG Playback Library 2.5
    248862Fixed an occasional crash that occurred on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    244193Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    235464Fixed an issue with niRFSGPlayback Download User Waveform API, where burst detection was not working as expected for some user waveforms.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    NI-RFSG Playback Library will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    LabWindows/CVIcvi_lifecycle
    © 2015–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    375556K-01
    GMT+8, 2025-12-8 19:07
