查看: 3517|回复: 0
[NI驱动程序] NI RMX-410x Power Supply Driver 20.7 x64Win10 64位中德日法英韩语 NI RMX-410x设备驱动程序20.7版下载 G语言
    9 小时前
    发表于 2021-6-2 17:24:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RMX-410x Power Supply Driver为RMX-410x设备提供支持。
    RMX-410x Power Supply Driver是一个驱动软件,旨在支持RMX-410x型号的可编程电源设备。该驱动程序可支持通过抽象可编程仪器标准命令(SCPI)来简化常见任务的编程。RMX-410x电源驱动程序还随附多个示例。
    Win64中文, 德语, 日语, 法语, 英文, 韩语
    20.7
    发布日期
    2021/4/21
    包含的版本
    20.7.0完整版
    受支持的操作系统
    程序位数
    64位
    校验和
    文件大小: 670947328 字节 (639.87 MB)
    修改日期: 2021-04-22 07:00
    MD5: 7a9a381166541321a74f1d46bb91a3e6(官方正确)
    SHA1: 0ff304f9e6ecdb4b486062765b3ce6f680dea74f
    SHA256: b016c4a2ac645e8728d8e5178156813dd696ac587c6fb4164059d28d33d6d43b
    CRC32: 5503ff49
    NIRMX410xPSD20.7.txt (597 Bytes, 下载次数: 0, 售价: 5 圆)
    RMX-410x LabVIEW Plug-and-Play Instrument Driver 20.7 Readme
    April 2021
    This file contains installation instructions and compatibility information for RMX-410x LabVIEW Plug-and-Play Instrument Driver.
    The RMX Power Supply Driver provides support for programming Programmable Power Supply Devices.
    The RMX Power Supply Driver is a plug-and-play NI instrument driver that helps you use LabVIEW to operate Programmable Power Supply Devices. With the RMX Power Supply Driver, you can configure your output power session, program and monitor voltage and current levels, and set up master-slave configurations for multidevice operation.
    Note The RMX-410x LabVIEW Plug-and-Play Instrument Driver does not support using the instrument with a GPIB interface. The interfaces supported are Ethernet, USB, and Serial.
    RMX-410x LabVIEW Plug-and-Play Instrument Driver 20.7 supports the following operating systems:
    RMX-410x LabVIEW Plug-and-Play Instrument Driver 20.7 supports the following application software versions, including service packs.
    Versions Supported by RMX-410x LabVIEW Plug-and-Play Instrument Driver
    LabVIEW2017, 2018, 2019, 2020
    Download the RMX-410x LabVIEW Plug-and-Play Instrument Driver installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RMX-410x LabVIEW Plug-and-Play Instrument Driver 20.7 includes the following new features:
    • Added support for LabVIEW 2017, 2018, 2019, 2020
    You can access the bug fix list online at RMX-410x LabVIEW Plug-and-Play Instrument Driver 20.7 Bug Fixes.
    You can access the known issues list online at RMX-410x LabVIEW Plug-and-Play Instrument Driver 20.7 Known Issues.
    The following list details the hardware models supported in RMX-410x LabVIEW Plug-and-Play 20.7 Instrument Driver.
    • RMX-4101 (RMX20-10-LAN)
    • RMX-4102 (RMX20-20-LAN)
    • RMX-4104 (RMX20-40-LAN)
    • RMX-4101 (RMX36-6-LAN)
    • RMX-4102 (RMX36-12-LAN)
    • RMX-4104 (RMX36-24-LAN)
    • RMX-4101 (RMX60-3.5-LAN)
    • RMX-4102 (RMX60-7-LAN)
    • RMX-4104 (RMX60-14-LAN)
    • RMX-4101 (RMX100-2-LAN)
    • RMX-4102 (RMX100-4-LAN)
    • RMX-4104 (RMX100-8-LAN)
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the RMX-410x LabVIEW Plug-and-Play Instrument Driver are located in the LabVIEW\instr.lib\NI RMX-410x Power Supplies\Examples directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    ©2021 National Instruments Corporation. All rights reserved.
    378560A-01
    GMT+8, 2025-12-8 19:08
