NI SystemLink Server 18.1.1 Win64Eng 系统连接服务器SLS18.1.1下载
SystemLink Server
SystemLink Server提供了启用所有SystemLink应用程序的数据、安全性和通信服务。
SystemLink Server是安装所有SystemLink应用程序的核心,提供了数据、安全性和通信服务,确保每个SystemLink应用程序都能发挥最大作用。大部分工程实验室和制造环境要求工具必须符合所有IT和业务标准,而SystemLink Server正好可以满足企业对安全性、访问控制权限、容错、备份和远程管理的要求。
受支持的操作系统
Windows 7 (SP1) 64-bit
Windows 8.1 64-bit
Windows Server 2012 R2 64-bit
18.1.1
文件大小: 1014365608 字节 (967.37 MB)
修改日期: 2018-10-05 22:47
MD5: b9a6ee048639b7918fbeec8227699dae(重复一致)
SHA1: 0e3ff1981d36d1fc7dc602303dc1bb4254efb24f
SHA256: 8b5f8b12e906a1153a60faaa21805be974be733e942484711e0582923ebb9e53
CRC32: 4f177889
系统连接服务器18.1.1.txt
(550 Bytes, 下载次数: 0, 售价: 10 圆)
NI SystemLink 18.1 ReadmeJuly 2018
This file contains important information about NI SystemLink, including system requirements and known issues.
Overview System Requirements Product Security and Critical Updates Licensing Information for SystemLink Clients Known Issues Accessing the Help Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information OverviewUse NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage Skyline data services to visualize data, trigger alarms, monitor tests,and transfer files over a server.
System RequirementsNI SystemLink has the following minimum system requirements:
Server Requirements
| Windows, less than 50 nodes
| Windows, 50+ nodes
| OS
| Windows Server 2016
Windows Server 2012 R2 (64-bit)
Windows 7 SP1 (64-bit) or higher
| Windows Server 2016
| Processor
| 2-core recommended or higher
| 8-core recommended or higher
| RAM
| 6 GB minimum
8+ GB recommended
| 16+ GB recommended
| Disk
| 6 GB minimum
8+ GB recommended
| 16+ GB recommended
| Target Requirements (Managed Nodes)
| NI PXI (Windows) or Windows PC
| NI CompactRIO
| OS
| NI Linux Real-Time 2018
| Processor
| Pentium 4 G1 (or equivalent) or later
| All Intel and ARM models supported
| RAM
| 2 GB minimum
4 GB recommended
| 512 MB minimum
1+ GB recommended
Note: NI SystemLink does not support targets with less than 512 MB of RAM.
| Disk
| 1 GB minimum
2+ GB recommended
| 512 MB
Note that VxWorks and Phar Lap OS are not supported.
- .NET Framework 4.6.2
- One of the following browsers:
- Chrome
- Firefox
- Edge
- Internet Explorer
- Safari
LabVIEW RequirementsNI SystemLink 18.1 supports the following LabVIEW versions:
- LabVIEW 2015, 2016, 2017, 2018
- LabVIEW RT 2017, 2018
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI.
Licensing Information for SystemLink ClientsSystemLink uses Volume License Manager to license clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
Known IssuesInstalling SystemLink onto a machine with TDM Server 2017 already installed will break TDM Server 2017. NI recommends you install SystemLink on a different machine or uninstall TDM Server 2017 prior to installing SystemLink.
You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
Bug FixesThe following items are the IDs and titles of a subset of issues fixed in SystemLink 18.1. This is not an exhaustive list of issues fixed in the current version of SystemLink. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
ID | Fixed Issue | 699210 | High CPU usage on Linux RT Salt Minions | 702585 | Uninstall button enabled for target's essential software | 700688 | Cannot install the Skyline Test Monitor Support for TestStand on machines without the TestStand Development Environment | 702587 | Available Feeds tab times out while trying to load the available feeds for a managed system | 698874 | Dashboard Builder does not update in web browser if you have used a previous version |
The following items are the IDs and titles of additional issues fixed in SystemLink 18.1.1. ID | Fixed Issue | 706519 | Periods in device names cause managed systems to appear disconnected | 707573 | Missing dependency on startup can cause services crash loop |
Accessing the HelpRefer to the NI SystemLink Help, accessible from ni.com, for more information about NI SystemLink.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10.
Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
Legal Information© 2017-2018 National Instruments. All rights reserved.
- Notices are located in the \_Legal Information and directories.
377243D-01 |
