NI SystemLink Server 2020R1 Win64Eng 系统连接服务器SLS20.0.0下载
SystemLink Server
SystemLink Server提供了启用所有SystemLink应用程序的数据、安全性和通信服务。
SystemLink Server是安装所有SystemLink应用程序的核心,提供了数据、安全性和通信服务,确保每个SystemLink应用程序都能发挥最大作用。大部分工程实验室和制造环境要求工具必须符合所有IT和业务标准,而SystemLink Server正好可以满足企业对安全性、访问控制权限、容错、备份和远程管理的要求。
受支持的操作系统
Windows 7 (SP1) 64-bit
Windows 8.1 64-bit
Windows Server 2012 R2 64-bit
2020R1
文件大小: 952109056 字节 (908.00 MB)
修改日期: 2020-05-01 02:16
MD5: 713ccda4ae44d7e7a407846404af2b30(重复一致)
SHA1: 7184c9e944cc7bcc8a250bd7030f683e44663606
SHA256: 0f0f4437e253a5258e1c18008921dcf7a65ca9f6df4580546ff0f2002e528357
CRC32: d86c2f20
系统连接服务器2021R1.txt
(538 Bytes, 下载次数: 0, 售价: 10 圆)
NI SystemLink 2020 R1 Readme
April 2020 This file contains important information about NI SystemLink, including system requirements and known issues. Overview System Requirements Product Security and Critical Updates Licensing Information for SystemLink Clients Known Issues Bug Fixes Accessing the Help Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 SystemLink Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 Legal Information Overview
Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage SystemLink data services to visualize data, trigger alarms, monitor tests, manage assets, and transfer files to a server. SystemLink TDM is a Big Analog Data™ solution for automated preparation and analysis of large amounts of data in various formats and structures from different geographic locations. System Requirements
NI SystemLink has the following minimum system requirements: Server Requirements
| Windows, less than 50 nodes | Windows, 50+ nodes, SystemLink TDM | OS | Windows Server 2016 Windows Server 2012 R2 (64-bit)1 Windows Server 2019 R2 (64-bit) Windows 7 SP1 (64-bit) or higher | Windows Server 2016 Windows Server 2012 R2 (64-bit)1 Windows 7 SP1 (64-bit) or higher Windows Server 2019 R2 (64-bit) | Processor | 4-core recommended or higher | 8-core recommended or higher | RAM | 16 GB minimum 32+ GB recommended | 32 GB minimum 64+ GB recommended | Disk | 6 GB minimum 8+ GB recommended | 16+ GB recommended |
1 NI software installs VC2015 runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2, which require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. Note Refer to SystemLink Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support. Note SystemLink TDM does not support server versions from the Microsoft Semi-Annual Channel. In addition, SystemLink TDM does not support Windows Server Core mode. Target Requirements (Managed Nodes)
| Windows | NI Linux Real-Time | OS | Windows 7 SP1 (64-bit) or higher Windows 7 SP1 (32-bit) or higher | NI Linux Real-Time 2019, 2020 (Supports LabVIEW RT 2019, 2020, and NXG 5.0) | Processor | Pentium 4 G1 (or equivalent) or later | All Intel and ARM models supported | RAM | 2 GB minimum 4 GB recommended | 512 MB minimum 1+ GB recommended | Disk | 1 GB minimum 2+ GB recommended | 512 MB |
Note: VxWorks and Phar Lap OS are not supported.
- .NET Framework 4.6.2
- One of the following browsers:
Note: NI SystemLink 2020 R1 web applications do not support Internet Explorer. Supported Software
NI SystemLink 2020 R1 supports the following LabVIEW versions: - LabVIEW 2017, 2018, 2019, 2020
- LabVIEW RT 2017, 2018, 2019, 2020
- LabVIEW NXG 5.0
SystemLink TDM supports the following DIAdem versions as clients: - DIAdem 2015, 2017, 2018, 2019 (recommended)
Visit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. Licensing Information for SystemLink
SystemLink uses Volume License Manager to license server modules and add-ons as well as clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing. If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server. Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.Bug Fixes
You can access a list of bugs fixed in this version online. Refer to the public bugs list for a list of fixed bugs. Accessing the Help
Refer to the NI SystemLink Manual, accessible from ni.com, for more information about NI SystemLink and the services and APIs it offers. Using NI Software with Microsoft Windows 10
Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1
When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. SystemLink Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
SystemLink will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: Product | Info Code | LabVIEW | lifecycle | LabWindows/CVI | cvi_lifecycle | Measurement Studio | mstudiolifecycle | TestStand | tslcp | DIAdem | ddlcp | SignalExpress | selcp | VeriStand | nivslifecycle |
Copyright © 2017-2020 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 377243M-01
