查看: 3647|回复: 0
[NI软件产品] NI License Manager 4.6.0 Win32/64中文/德语/日语/法语/英文/韩语 NI许可证管理器NILM4.6.0
    昨天 11:03
  • 签到天数: 3581 天
    发表于 2021-7-1 12:00:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    License Manager可帮助您管理许可的NI软件资产。
    许可证管理器是实用程序软件,您可以使用它来激活、停用和传输带有许可证激活代码或许可证文件的软件许可证。许可证管理员可以使用许可证管理器自动激活产品并添加批量许可证服务器。
    License Manager helps you manage licensed NI software assets.
    License Manager is utility software that you can use to activate, deactivate, and transfer software licenses with license activation codes or license files. License administrators can use License Manager to automate product activation and add volume license servers.
    4.6
    文件大小: 319907840 字节 (305.09 MB)
    修改日期: 2020-04-06 05:30
    MD5: 57e2203ff914b7e8797e159f5876f04b(官方正确)
    SHA1: 7985e22cc426c74fe377d537fbf38e2e721c659c
    SHA256: 182ad48f91be24dd4c3da060ed5a464067b247aaa49945b7a9ef850b18cfd854
    CRC32: ae4ac192
    注册登录视觉论坛会员购买附件查看下载地址
    LM4.6.0.txt (539 Bytes, 下载次数: 0, 售价: 10 元)
    NI License Manager 4.6 Readme
    March 2020
    This file contains important information about National Instruments License Manager 4.6, including installation instructions, and how to access NI License Manager and the NI License Manager help.
    Alert for Volume License Program Customers
    Accessing NI License Manager
    License Manager Drops Support Windows 7, Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Use the NI License Manager to activate and manage your licenses or configure NI products on your system to obtain licenses from volume license servers.
    NI License Manager 4.6 has the following requirements:
    • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
    • At least 150 MB of disk space
    • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
    NI License Manager 4.6 supports the following operating systems:
    • Windows 10/8.1 Update 11/7 SP12
    • 64-bit version of Windows Server 2012 R21
    • 64-bit version of Windows Server 2008 R2 SP12
    1 NI License Manager 4.6 installs the VC2010 and VC2015 Runtimes and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    NI License Manager is installed with all licensed NI products. No separate installation of NI License Manager is needed.
    NI License Manager 4.6 is only compatible with NI Volume License Manager 3.1.1 and later.
    If you are using FlexNet Publisher instead of NI Volume Licence Manager, NI License Manager 4.6 is only compatible with FlexNet Publisher 11.15.0 and later. You can find a compatible version of Flexnet Publisher here.
    You can access the software and documentation known issues list online. Refer to the NI Licence Manager 4.6 Known Issues for an up-to-date list of known issues.
    Follow these steps to open the NI License Manager:
    • The first time you open NI software, the NI Licensing Wizard launches automatically if the software is not activated to guide you through the licensing and activation process.
    • If you need to manually launch NI License Manager, navigate to the following locations:
      • (Windows 7) Start»All Programs»National Instruments»License Manager»NI License Manager
      • (Windows 8) click NI Launcher and select License Manager»NI License Manager
      • (Windows 10) Start»National Instruments»NI License Manager
    Refer to the NI License Manager Manual, accessible from the blue question mark icon on the top right of NI License Manager, for information about using NI License Manager.
    License Manager Drops Support for Windows 7, Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    License Manager will drop support for Windows 7, Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021 will not support 32-bit applications. For detailed information about 32-bit application support, visit ni.com/r/32bitsupport.
    ©2004–2020 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help?Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    376733F-01
    GMT+8, 2025-7-2 06:01
