查看: 3371|回复: 0
[NI软件产品] NI DataFinder Server Edition 2014 Win32Eng 数据查找服务器版DFSE2014英语版下载
    前天 16:03
    发表于 2021-7-1 16:20:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    DataFinder Server
    DataFinder Server是一款应用软件,无论文件格式和网络位置如何,都可以搜索数据,而无需复杂的IT系统。
    DataFinder Server是一款集中式数据管理软件,可自动发现、标准化和管理工程数据,方便多个用户进行搜索。 与传统解决方案不同的是,DataFinder Server可直接索引计算机或网络上指定文件夹中的数据文件,而不需要构建数据库。 当文件发生更改时,DataFinder Server会自动重新组织,而无需让服务器脱机即可进行维护。 随着需求的增加,DataFinder Server可通过联合架构升级为部门级和企业级规模。
    DFSE2014
    文件大小: 237189215 字节 (226.20 MB)
    修改日期: 2014-08-05 21:56
    MD5: 76977698eac470840af2e53fd8ad863f
    SHA1: bea2ddbe6b74428f94e63aee203230ded6bb686a
    SHA256: 36e94ce69b05abb04b5d4b60bbf99bc7b27bc9a0c4701296f649c14d08d4b884
    CRC32: 729d1769
    请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服
    DFSE2014Eng.txt (569 Bytes, 下载次数: 0, 售价: 10 圆)
    DataFinder Server Edition 2014 Release Notes
    2014
    Version 14.0
    July 2014
    This file contains basic information on the DataFinder Server Edition 2014. The file contains the following information:
    Incompatibilities of DataFinder Server Edition Version 2014 with Previous Versions
    Known Issues in DataFinder Server Edition 2013 and 2014
    Automatic_Installation_of_NI_Products
    How to Use NI Software with Microsoft Windows Server 2012
    NI DataFinder Server Edition Drops Support for Microsoft Windows Vista, Windows XP, Windows Server 2003, Windows Server 2003 R2, and Windows Server 2008 in 2016
    For correct DataFinder Server Edition performance, the following system requirements must be met:
    Minimum system requirements
    CPU2 Processor cores, clock frequency 1.4 GHz
    Amount of memory2 GB
    Operating SystemsWindows Server 2008 R2 SP1, Windows Server 2012 including R2
    Recommended system requirements
    CPU4 to 8 processor kernels, clock frequency 2.5 GHz
    Amount of memory16 to 32 GB
    Hard disks for operating system and index15.000 rpm SAS drives or SSD drives; National Instruments recommends storing the DataFinder index on a separate drive.
    Miscellaneous
    • Internet Explorer Version 6.0 Service Pack 1 or later
    • If you do not install DIAdem, you need the Windows Scripting Host if you use VBS-DataPlugins.
    Note  DataFinder Server Edition, LabVIEW DataFinder Toolkit, and DIAdem Version 10.0 and later versions install and use a common software component (DataFinder client), which is refreshed by the installation of the DataFinder Server Edition. When you uninstall DataFinder Server Edition, the current version of the shared component remains. This is intentional and has been tested extensively.
    DataFinder Server Edition 1.0, LabVIEW DataFinder Toolkit 2009, DIAdem 9.0, LabWindows/CVI 8.1, and LabVIEW 7.1 and later versions install and use a common software component (USI), which is refreshed by the installation of the DataFinder Server Edition. When you uninstall DataFinder Server Edition, the current version of the shared component remains. This is intentional and has been tested extensively.
    Note  DataFinder Server Edition does not support the volume license manager from National Instruments.
    New FeaturesNew Features in DataFinder Server Edition 2014
    • DataFinder Server Edition 2014 is a 64-bit application.
    • With the DataFinder federation server you can access up to 100 DataFinder servers simultaneously through a common interface.
    • You can configure the system storage, which the DataFinder index uses, in detail.
    • If you use DataFinder Server Edition 2014 as an ASAM ODS server or create a DataFinder federation, you can use the new dialog box in the DataFinder manager in order to create a user-defined navigation hierarchy. To do so, you use optimized custom properties from the file level or group level of the TDM data model without changing the data.
    • You can synchronize DataPlugins between DIAdem or LabVIEW clients and a DataFinder server.
    New Features in DataFinder Server Edition 2013
    • The security settings for DataFinder server has been revised. The permissions for the clients will continue to be set in the Windows permission dialog boxes, but the DataFinder saves all security settings with the program. You also can define individual security settings for individual search areas.
    • The DataFinder compresses the data to be transferred in order to increase throughput, especially in network environments with a low transfer rate.
    • Sort your indexed data stores,for example, according to year and month to get a different view. You can also filter the views.
    • You can now use the DataFinder Server Edition as ASAM ODS server:
      - Read-only ASAM ODS CORBA interface
      - Application model which can be extended during runtime (compatible with ASAM ODS version 5.3) with a user-defined test hierarchy and units catalog.
      - Windows Active Directory based security settings
      - UNICODE support
      - Generic ATF/XML support
    • You can now add search areas to a DataFinder server which the DataFinder Manager cannot access. This covers the case in which the DataFinder Manager is executed by a different user than the actual DataFinder server.
    • In the DataFinder Manager you can now search for updates of existing DataPlugins and install these DataPlugins by pressing a button.
    New Features in DataFinder Server Edition 2012
    • You can now enable automatic indexing of data in the search areas. You can specify whether the DataFinder indexes new or changed files immediately or whether a job file regularly executes the indexing tasks.
    • The DataFinder Server Edition can now refresh the content of the index more quickly because it uses several parallel indexing processes when indexing new and changed files.
    • You can use a scheduler to regularly optimize the index in order to process search queries more quickly.
    New Features in DataFinder Server Edition 2011
    Use the SQL Server Index Adaptor to integrate the DataFinder Server Edition in companies with existing Microsoft SQL server-database systems. DataFinder Server Edition in this case uses the features of the Microsoft SQL server for sophisticated, business critical applications, and can also be integrated into existing maintenance processes, for example backup/restore or optimization. To use the SQL server index-adaptor, you need Microsoft SQL Server 2005, SQL Server 2008, or SQL Server 2008 R2.
    New Features in DataFinder Server Edition 2010
    • You can now index individual files or folders in the browser view of a DataFinder Server.
    • You now can index files without filename extensions so that clients can search for and load these files.
    • You can specify a sorting order for the results before you start a query.
    Note  Specifying the sorting criteria with OrderBy might change the order of the search results compared to previous versions.
    Note  The new file property Folder speeds up queries for a file path. This means that you can no longer can use an existing custom property called Folder on the file level for queries.
    New Features in DataFinder Server Edition 2.1
    • Additionally to DIAdem you can now also use the LabVIEW DataFinder Toolkit as the client of the DataFinder Server Edition.
    • You can now create a separate indexer scheduler for each search area.
    • The performance of the index has been improved considerably.
    New Features in DataFinder Server Edition 2.0
    • In the advanced search of your client, connect several values for one search condition, or use OR to connect various search conditions, for example, to search for several filenames.
    • Use the security settings in DFSE to enable clients to search and browse only in the search areas you specify for sharing. The security settings are based on the rights that you configure in the standard Windows dialog boxes for sharing and security.
    • In co-operation with the S.E.R. company, DFSE has been linked to the DOXiS archiving system. This enables you to handle large amounts of technical data comfortably and inexpensively.
    • DFSE 2.0 supports the Windows Server 2008 operating system as well as Windows Server 2003.
    The following section lists some of the issues fixed in DataFinder Server Edition 2014. This is not an exhaustive list of issues fixed in the current version of the DIAdem. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    CAR IDDescription
    436239You can access an ASAM server without a password even if the the security settings are enabled.
    444626Famos cannot read any bulk data from National Instruments ASAM servers.
    475693The security settings of a search area cannot be exported or duplicated.
    • You can no longer install DataFinder Server Edition on a 32-bit operating system.
    • You can no longer delete earlier DataFinder server versions in the DataFinder manager.
    • By default DataFinder Server Edition 2014 enables only TDM and TDMS DataPlugins when a new DataFinder server is created. If an ASAM ODS server is being created, the ATFX_TDM DataPlugin is also enabled. All further DataPlugins you need, you must enable manually.
    • DataFinder Server Edition 2014 searches for a search term with umlauts in the same way as for a search term without umlauts. Searching for a search term containing the letter Ä, for example, returns the results of a search for a search term with the letter A. The same applies for sorting search results with Order By.
    Incompatibilities of DataFinder Server Edition Version 2013 with Previous Versions
    • Since version 2013, the DataFinder Server Edition has been using its own security settings instead of the Windows security settings.
    • When creating a new DataFinder index, the DataFinder no longer adds the register properties to the individual levels.
    • Earlier DataFinder servers can only be upgraded to version 2010.
    • From version 2013 the DataFinder Server Edition will show in the DataFinder manager only DataFinder servers up to and including 2010. If you want to use DataFinders from earlier versions, you can upgrade the DataFinder with an earlier version of the DataFinder manager to a version which supports the DataFinder Server Edition 2013. You can also create a new DataFinder server in the current version.
    • From Version 2013, the DataFinder Server Edition does not index the file, group, and channel properties with the names registertxt1 ... registertxt3, and the channel properties with the names registerint1 ... registerint6, and registerval1 ... registerval6. This means that these properties are no longer available for search queries.
    Fixed Issues in DataFinder Server Edition 2013
    If you install the DataFinder Server Edition on Windows Server 2008 R2, authentication may not be possible in some network environments. If the security settings of the DataFinder are active in such a network environment, DataFinder clients, such as DIAdem or DataFinder Toolkit, cannot establish a connection with a DataFinder server, even if they have the necessary access rights.
    You can no longer use the DataFinder with the Microsoft SQL adaptor if the DataFinder is running on a computer with Microsoft Windows Server 2008 R2, or an earlier version. This error no longer occurs if you install Microsoft Windows Server 2008 R2 service pack 1. Microsoft describes this problem on the Microsoft website in KB entry no. 2640696. There is a hotfix available for this issue on the Microsoft website in KB entry no. 983246.
    Fixed Issues in DataFinder Server Edition 2012
    The following list contains the CAR IDs and the descriptions of the problems solved between DataFinder Server Edition 2011 and DataFinder Server Edition 2012. Use the CAR ID to check the list whether the issue has been fixed.
    CAR IDDescription
    333333On Windows Server 2008 R2 or Windows 7, mapped network drives may not be displayed in the browser.
    • Refer to KB 4CJDP38M, Automating the Installation of a Single Installer for more information on automatic installations of individual NI products.
    • Refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer? for a description of the version of the NI Installer your product contains.
    When you install National Instruments software on Microsoft Windows Server 2012, you will notice a few additional tiles on the Start screen, including shortcuts to NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows Server 2012, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Current ApplicationProgram LocationPin to Action
    Windows Server 2012 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows Server 2012 DesktopStart screenRight-click application and select Pin to Start
    Windows Server 2012 Start PageDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    National Instruments DataFinder Server Edition Drops Support for Microsoft Windows Vista, Windows XP, Windows Server 2003, Windows Server 2003 R2, and Windows Server 2008 as of July 1, 2016. Versions of DataFinder Server Edition that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, Windows Server 2003, Windows Server 2003 R2, and Windows Server 2008. Windows Server 2008 R2 will continue to be supported after July 1, 2016.
    You can no longer install DataFinder Server Edition version 2014 and later on a 32-bit operating system.
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2006—2014 National Instruments Ireland Resources Limited. All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, This includes photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    • Legal notice: Notices are located in the \_Legal Information and directories.
    • EULAs: EULAs are located in the \Shared\MDF\Legal\license directory.
    • Review \_Legal Information.txt for information on including legal information in installers built with NI products: \_Legal Information.txt
    GMT+8, 2026-2-25 01:06
