查看: 3160|回复: 0
[NI软件套件] NI System Driver Suite 2010.04 Win32/64Eng NI系统驱动套件SDS-Apr10
    昨天 09:46
  • 签到天数: 3643 天
    连续签到: 5 天
    发表于 2021-7-5 15:41:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    System Driver Suite
    文件大小: 3859928773 字节 (3.59 GB)
    修改日期: 2010-04-23 23:27
    版本: 4.65.0.0
    MD5: 4b37bb18ed08f5447dc8abb25371de8c(官方正确)
    SHA1: 3e4d51281b2520efec41ac70ab4af69e66bf0e1f
    SHA256: 9f69f12be178e2f57115375ba5be2cbc39ec73be93abfa287cc0ad57a64c52ce
    CRC32: 61f77dde
    请注册登录论坛会员,购买附件查看下载地址
    SDS2010.04.txt (471 Bytes, 下载次数: 0, 售价: 30 圆)
    National Instruments System Driver Set ReadmeApril 2010 Release
    © 2003-2010 National Instruments. All rights reserved.
    Windows 7 Issues
    National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. While most NI products work with Windows 7, NI has become aware of some compatibility issues regarding Windows 7.  To learn more about Windows 7 and NI products, visit ni.com/info and enter the Info Code windows7.
    For patents covering National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file in this folder, or ni.com/patents.
    System Driver Set Contents
    • Data Acquisition
      • NI-DAQmx 9.1.0
      • Traditional NI-DAQ 7.4.4 (Legacy)
      • NI-435x 2.5.2
    • Instrument Control
      • NI-488.2 2.7.3
      • NI-VISA 4.6.2
      • NI-Serial 3.5.1
      • IVI Compliance Package 4.1.0
      • PXI Platform Services 2.5.4
      • NI System Monitor 1.1.1
      • NI-VXI 3.6.0
    • Modular Instruments
      • NI-Switch 4.0.1
      • NI-DMM 3.0.2
      • NI-Scope 3.6.0
      • NI-RFSA 2.3.1
      • NI-PXI-5660 Support
      • NI-FGEN 2.7.2
      • NI-DCPower 1.4.0
      • NI-RFSG 1.6.2
      • NI-HSDIO 1.7.2
      • NI-5690 1.1.0
      • NI-5460R 1.4.0
    • Timing & Synchronization
      • NI-Sync 3.1.0
    • Reconfigurable IO
      • NI-RIO 3.4.0
      • CompactRIO 3.4.0
      • NI-FlexRIO 1.4.0
        • NI FlexRIO Adapter Module Support 1.7.0
    • Motion
      • NI-Motion 8.1.0
    • Vision Acquisition Software
      • NI-IMAQ 4.4.0
      • NI-IMAQdx 3.6.0
      • NI-IMAQ I/O 2.3.1
    • Distributed I/O
      • NI-FieldPoint 6.0.6
    • Real-Time and Embedded
      • NI-488.2 2.7.3
      • NI-Serial 3.3.4
      • NI-Watchdog 4.0.1
    • Communication Buses and Protocols
      • NI-XNET 1.1.0
      • NI-CAN 2.7.0
      • NI-DNET 1.6.4
      • NI-Industrial Communications for DeviceNet 2.0
    • NI LabVIEW SignalExpress 2009
    • NI Spy 2.7.1
    • NI Measurement & Automation Explorer 4.6.2
    • Windows XP
    • Windows Vista x86
    • Windows Vista x64
    • Windows 7 x86
    • Windows 7 x64
    This installation requires that version 3.1 of the MSI (Windows Installer) Engine is installed on your computer. If you do not have MSI 3.1 or later, the installer updates the engine automatically and might require you to restart your computer.
    Additional Requirements for Specific Features
    Certain features in this installation have additional requirements.
    FeatureAdditional System RequirementsNI Software Requirements
    Visual C++ 2005 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    NoneNational Instruments Measurement Studio VC++ 2005
    Visual C++ 2003 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    NoneNational Instruments Measurement Studio VC++ 2003
    .NET Framework 1.1 and 2.0 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    Microsoft .NET Framework 1.1
    or
    Microsoft .NET Framework 2.0
    LabWindowsTM/CVITM Support for:
    • NI-DAQmx
    • NI-CAN
    • NI-DNET
    NoneLabWindows/CVI 7.0 or later
    LabVIEWTM Support for:
    • NI-435x
    NoneNational Instruments LabVIEW 7.1 or later
    Uninstallation Instructions
    You can uninstall software that you installed from this DVD by selecting National Instruments Software in the Windows Add/Remove Programs application.
    © 2003–2010 National Instruments Corporation. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2025-9-6 03:03
