NI System Driver Suite 2010.07 Win32/64Eng NI系统驱动套件SDS-Jul10
System Driver Suite
文件大小: 4275784278 字节 (3.98 GB)
修改日期: 2010-07-29 08:29
版本: 1.2.0.715
MD5: ad30f6c1d7c936b10d63a48167b2b78c(官方正确)
SHA1: c2b952b5ea189fbf0b528bcedf44c84b223bdaee
SHA256: 88e372257b24ec8c24513d9c45990fa5160d15d5cc3c0e75c0108efeb88ea9f6
CRC32: 3a899ffd
请注册登录论坛会员,购买附件查看下载地址
SDS2010.07.txt
(472 Bytes, 下载次数: 0, 售价: 30 圆)
National Instruments System Driver Set ReadmeJuly 2010 Release© 2003-2010 National Instruments. All rights reserved. Windows 7 IssuesNational Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. While most NI products work with Windows 7, NI has become aware of some compatibility issues regarding Windows 7. To learn more about Windows 7 and NI products, visit ni.com/info and enter the Info Code windows7. PatentsFor patents covering National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file in this folder, or ni.com/patents. System Driver Set Contents
- Data Acquisition
- NI-DAQmx 9.1.5
- Traditional NI-DAQ 7.4.4 (Legacy)
- NI-435x 2.5.2
- Instrument Control
- NI-488.2 2.7.3
- NI-VISA 5.0.0
- NI-Serial 3.6.0
- IVI Compliance Package 4.2.0
- PXI Platform Services 2.5.6
- NI System Monitor 1.1.1
- NI-VXI 3.7.0
- Modular Instruments
- NI-Switch 4.0.2
- NI-DMM 3.0.3
- NI-Scope 3.6.2
- NI-RFSA 2.3.2
- NI-PXI-5660 Support
- NI-FGEN 2.7.4
- NI-DCPower 1.4.1
- NI-RFSG 1.6.4
- NI-HSDIO 1.7.3
- NI-5690 1.1.0
- NI-5460R 1.4.0
- Timing & Synchronization
- NI-Sync 3.2.1
- NI-TimeSync 1.0.1
- Reconfigurable IO
- NI-RIO 3.5.0
- CompactRIO 3.5.0
- R Series 3.5.0
- NI-FlexRIO 1.5.0
- NI FlexRIO Adapter Module Support 1.9.0
- Motion
- Vision Acquisition Software
- NI-IMAQ 4.5.0
- NI-IMAQdx 3.7.0
- NI-IMAQ I/O 2.4.0
- Distributed I/O
- Real-Time and Embedded
- NI-488.2 2.7.3
- NI-Serial 3.6.0
- NI-Watchdog 4.0.1
- Communication Buses and Protocols
- NI-XNET 1.1.1
- NI-CAN 2.7.1
- NI-DNET 1.6.5
- NI-Industrial Communications for DeviceNet 2.0.0
- Tools and Utilities
- NI LabVIEW SignalExpress 2010
- NI Spy 2.7.2
- NI Measurement & Automation Explorer 4.7.1
- NI System Configureation 1.1.0
System RequirementsThis installation requires one of the following Microsoft operating systems: - Windows XP
- Windows Vista x86
- Windows Vista x64
- Windows 7 x86
- Windows 7 x64
- Windows Server 2003 R2 (32-bit)
- Windows Server 2008 R2 (64-bit)
This installation requires that version 3.1 of the MSI (Windows Installer) Engine is installed on your computer. If you do not have MSI 3.1 or later, the installer updates the engine automatically and might require you to restart your computer. Additional Requirements for Specific FeaturesCertain features in this installation have additional requirements. Feature | Additional System Requirements | NI Software Requirements | Visual C++ 2005 support for:
| None | National Instruments Measurement Studio VC++ 2005 | Visual C++ 2003 support for:
- NI-DAQmx
- NI-488.2
- NI-VISA
| None | National Instruments Measurement Studio VC++ 2003 | .NET Framework 1.1 and 2.0 support for:
| Microsoft .NET Framework 1.1
or
Microsoft .NET Framework 2.0 | | LabWindowsTM/CVITM Support for: | None | LabWindows/CVI 7.0 or later | LabVIEWTM Support for:
| None | National Instruments LabVIEW 7.1 or later |
Uninstallation InstructionsYou can uninstall software that you installed from this DVD by selecting National Instruments Software in the Windows Add/Remove Programs application.
Copyright © 2003–2010 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. Trademarks CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
