查看: 3160|回复: 0
[NI软件套件] NI System Driver Suite 2011.08 Win32/64Eng NI系统驱动套件SDS-Aug11
    昨天 09:46
  • 签到天数: 3643 天
    连续签到: 5 天
    发表于 2021-7-5 15:52:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    System Driver Suite
    文件大小: 5645994925 字节 (5.26 GB)
    修改日期: 2011-08-19 00:00
    MD5: e11110c94c17a8505620bfd15773cba0(官方正确)
    SHA1: 5091127c1027662f75781f9b10f9a80b3219dd5f
    SHA256: 36c670cc8666025d99f91646a8405a52658639085ee2268ba383899ba968d27a
    CRC32: 51447eb8
    请注册登录论坛会员,购买附件查看下载地址
    SDS2011.08.txt (455 Bytes, 下载次数: 0, 售价: 30 圆)
    National Instruments System Driver Set ReadmeAugust 2011 ReleasePatents
    For patents covering National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file in this folder, or ni.com/patents.
    System Driver Set Contents
    • Data Acquisition
      • NI-DAQmx 9.4.0
      • Traditional NI-DAQ 7.4.4 (Legacy)
      • NI-435x 2.5.2
    • Instrument Control
      • NI-488.2 2.8.1
      • NI-VISA 5.1.0
      • NI-Serial 3.8.0
      • IVI Compliance Package 4.4.0
      • PXI Platform Services 3.0
      • NI System Monitor 1.1.1
      • NI-VXI 3.8.0
    • Modular Instruments
      • NI-Switch 4.3.5
      • NI-DMM 3.0.5
      • NI-Scope 3.8.5
      • NI-RFSA 2.4.5
      • NI-PXI-5660 Support
      • NI-FGEN 2.8.1
      • NI-DCPower 1.6.1
      • NI-RFSG 1.7.3
      • NI-HSDIO 1.8.0
      • NI-5690 1.1.0
      • NI-5460R 1.6
      • NI-OSI 1.0.0
      • NI-VNA 1.1.0
    • Timing & Synchronization
      • NI-Sync 3.3.0
      • NI-TimeSync 1.1.1
      • NI-1588 Configuration 1.1.0
    • Reconfigurable IO
      • NI-RIO 4.0
      • CompactRIO 4.0
      • R Series 4.0
      • NI-FlexRIO 2.1.1
        • NI FlexRIO Adapter Module Support 2.1.2
    • Motion
        NI-Motion 8.3.0
    • Vision Acquisition Software
      • NI-IMAQ 4.6.1
      • NI-IMAQdx 3.9.0
      • NI-IMAQ I/O 2.5.0
    • Distributed I/O
      • NI-FieldPoint 6.0.9
    • Real-Time and Embedded
      • NI-488.2 2.8.1
      • NI-Serial 3.8
      • NI-Watchdog 5.1.0
    • Communication Buses and Protocols
      • NI-XNET 1.3.1
      • NI-CAN 2.7.3
      • NI-DNET 1.6.6
      • NI-Industrial Communications for CANopen 1.0.1
      • NI-Industrial Communications for DeviceNet 2.0.2
    • Configuration and Utilities
      • NI LabVIEW SignalExpress 2011
      • NI I/O Trace 3.0
      • NI Measurement & Automation Explorer 5.0
      • NI System Configuration 5.0
      • NI Network Browser 5.0
    • Windows XP Service Pack 2 or later
    • Windows Vista x86
    • Windows Vista x64
    • Windows 7 x86
    • Windows 7 x64
    This installation requires that version 3.1 of the MSI (Windows Installer) Engine is installed on your computer. If you do not have MSI 3.1 or later, the installer updates the engine automatically and might require you to restart your computer.
    Additional Requirements for Specific Features
    Certain features in this installation have additional requirements.
    FeatureAdditional System RequirementsNI Software Requirements
    Visual C++ 2005 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    NoneNational Instruments Measurement Studio VC++ 2005
    Visual C++ 2003 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    NoneNational Instruments Measurement Studio VC++ 2003
    .NET Framework 1.1 and 2.0 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    Microsoft .NET Framework 1.1
    or
    Microsoft .NET Framework 2.0
    LabWindowsTM/CVITM Support for:
    • NI-DAQmx
    • NI-CAN
    • NI-DNET
    NoneLabWindows/CVI 7.0 or later
    LabVIEWTM Support for:
    • NI-435x
    NoneNational Instruments LabVIEW 7.1 or later
    Uninstallation Instructions
    You can uninstall software that you installed from this DVD by selecting National Instruments Software in the Windows Add/Remove Programs application.
    © 2003–2011 National Instruments Corporation. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2025-9-6 03:06
