查看: 3264|回复: 0
[NI软件产品] NI VeriStand 2009 Win32Eng PC版完整版及运行版NIVS2009
    14 小时前
  • 签到天数: 3666 天
    连续签到: 28 天
    发表于 2021-7-15 11:14:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    百度网盘下载地址和NI官方下载地址:
    请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服
    VS2009.txt (236 Bytes, 下载次数: 1, 售价: 10 圆)
    NI VeriStand 2009 Readme
    June 2009
    This file contains important information about NI VeriStand 2009, including system requirements and installation instructions.
    Supported Platforms
    Migrating from NI Dynamic Testing Software 1.0
    NI VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The NI VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be easily customized and extended with LabVIEW, NI TestStand, and other software tools.
    NI VeriStand includes a run-time editable user interface as well as a test manager you can use to configure and implement triggered multi-file data logging, real-time test sequencing, stimulus generation and playback, and model calibration.
    Supported Platforms
    NI VeriStand supports Windows Vista/XP. NI VeriStand runs as a 32-bit application on Windows Vista 64-bit operating system. NI VeriStand does not support Windows 2000.
    To configure and run a simulation using your existing model DLL, you need only NI VeriStand installed. To develop a model and convert it into a model DLL using The MathWorks, Inc. Simulinkо application software, you must be a licensed user of and have the following software installed on the host computer:
    • The MathWorks, Inc. MATLABо software and The MathWorks, Inc Simulinkо application software release 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, or 2009a
    • The MathWorks, Inc. Real-Time Workshopо software release 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, or 2009a
    • Microsoft Visual C++ 6.0, .NET 2003, 2005 (Professional or Express), or 2008 (Professional or Express)
    To develop a model and convert it into a model DLL using other modeling environments, contact your model vendor for requirements.
    To create custom devices, menu items, workspace controls and indicators, timing and sync devices, or Stimulus Profile Editor headers, you must have LabVIEW 2009 installed.
    To import CAN channels from a .dbc or .ncd file, you must have the following NI-CAN driver software installed on the host computer.
    • NI-CAN 2.6.3 or later
    • NI-CAN Frame Channel Conversion Library 1.0.3
    Refer to the National Instruments Web site to download the NI-CAN Frame Channel Conversion Library.
    To run a simulation on a real-time (RT) target, the target must have NI VeriStand installed. You can install software on the target using Measurement & Automation Explorer (MAX). NI VeriStand only supports RT targets running the Ardence Phar Lap Embedded Tool Suite (ETS) operating system. The RT target must meet the following minimum system requirements:
    • 256 MB of memory
    • LabVIEW 2009 Real-Time Module
    • You also must install the following driver software versions, even if you are not using the associated hardware types:
      National Instruments HardwareDriver Software Version Required
      National Instruments FPGA DevicesNI-RIO 3.2 or later
      National Instruments CAN InterfacesNI-CAN 2.6.3 or later
      NI-CAN Frame Channel Conversion Library 1.0.3 or later
      National Instruments DAQ DevicesNI-DAQmx 8.9.5 or later
    Complete the following steps to install NI VeriStand.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert the NI VeriStand 2009 installation media and follow the instructions that appear on the screen.
    • (Optional) Activate NI VeriStand when prompted by the installer, or activate at a later time using the NI License Manager.
    Search the KnowledgeBase for information about installation order if you are using NI TestStand or LabVIEW with NI VeriStand.
    Migrating from NI Dynamic Testing Software 1.0Mapping Directories
    You can use files you created using NI Dynamic Testing Software 1.0 in NI VeriStand 2009. You must move your NI Dynamic Testing Software files to the corresponding NI VeriStand folders. NI Dynamic Testing Software folders correspond to NI VeriStand folders as follows:
    NI Dynamic Testing SoftwareNI VeriStand
    ConfigurationsSystem Definitions
    Rig SetupsWorkspace Files
    Test SetupStimulus Profiles
    Mutating Files
    When you load your NI Dynamic Testing Software .rig and .in4 files in NI VeriStand for the first time, NI VeriStand mutates the files for compatibility with NI VeriStand. As part of the conversion process, NI VeriStand moves aliases from the .rig file to the .in4 file. If you load multiple .rig files that share the same .in4 file, aliases might be overwritten. National Instruments recommends that you take the following precautions before loading NI Dynamic Testing Software files in NI VeriStand:
    • Create back-up copies of any NI Dynamic Testing Software files before you load them in NI VeriStand
    • Create and use separate copies of any .in4 file that is shared by multiple .rig files
    Using Real-Time Engines
    If you install NI VeriStand on a computer that already has NI Dynamic Testing Software installed, the NI Dynamic Testing Software RT engine appears to be unavailable in the LabVIEW Real-Time Software Wizard in Measurement & Automation Explorer. In the LabVIEW Real-Time Software Wizard, set the VeriStand Engine version to 1.0 to install the NI Dynamic Testing Software RT engine. You cannot have both the VeriStand Engine and the NI Dynamic Testing Software engine installed at the same time on the RT target. Refer to the Measurement & Automation Explorer Help for more information about using the Real-Time Software Wizard.
    Maintaining Behavior
    NI Dynamic Testing Software automatically set the value of a Stimulus Profile Generator and a mapped channel to zero at the end of a test. NI VeriStand does not exhibit this same behavior. NI VeriStand leaves the channel at the last set value. To maintain the behavior of NI Dynamic Testing Software, add a step at the end of the test to ramp the channel to zero in zero seconds.
    Refer to the NI VeriStand Help, accessible by selecting Help»Search the NI VeriStand Help from the pull-down menu in NI VeriStand.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI VeriStand 2009.
    The following items are the IDs and titles of a subset of issues fixed between NI Dynamic Testing Software 1.0 and NI VeriStand 2009. This is not an exhaustive list of issues fixed in the current version of NI VeriStand. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    115727Improve error handling and reporting
    116674User access levels are not always enforced
    117174Parameters committed each time in RT engine, should be committed at end of each set
    121114In Test Profile Editor, using Point Play, the graph is always interpolated
    121117System Explorer window is not the same when opened in stand-alone form versus from Getting Started window
    123576CAN ports are always configured in pairs, even if you only need one port
    127468FPGA support is limited to pre-determined configurations
    127718Channel names, aliases, alternative name, and so on is not consistent in the system
    127787Closing Workspace window while profile is running leaves profile editor in disabled state when Workspace window reopened
    128021Browsing for a relative path does not work and results in a blank relative path
    128376When changing between .rig files, user login is not consistent
    128513Custom device does not correctly handle unconfigured inputs or outputs
    128606System Explorer window: The number of streamed channels seems to be tied to the number of Max Profile Steps
    128612Need ability to assign specific CPU for all high priority loops
    129143Creating (or renaming) a screen named after a menu item (e.g. Screen) disables the menu item.
    130582Add support for vector inports and vector outports
    133101Parameter import list is ignored, and all parameters are always imported
    134032Model did not start with multiple custom devices
    134200Model import definition allows duplicate subsystem names in the same group
    135697Step-based GENs have unit delay for applying values
    136512Mappings in Table-based Test Profile tool can interfere with mappings from System Explorer window
    150058Sometimes when resizing a graph, it will start moving off the Workspace window and disappear
    153096Parsing issue with model inputs and output that are vectors
    157684Clicking on an empty parameter folder in the System Explorer window causes error
    157716Timeout error with large .in4 file
    158004Clicking the Enter button in a text field of a procedure step dialog box cancels, even though the OK button is highlighted
    158208TDMS File Viewer displays the wrong panel on the right side
    170168Incoming CAN message does not correctly link to CAN1
    NI VeriStand, NI TestStand, National Instruments, NI, ni.com, NI-RIO, NI-CAN, NI-DAQmx, and LabVIEW are trademarks of National Instruments. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    MATLABо, Real-Time Workshopо, and Simulinkо are registered trademarks of The MathWorks, Inc.
    Only Licensed Use is Permitted
    You are only permitted to use this product in accordance with the accompanying license agreement. All rights not expressly granted to you in the license agreement accompanying the product are reserved to NI. Further, and without limiting the forgoing, no license or any right of any kind (whether by express license, implied license, the doctrine of exhaustion or otherwise) is granted under any NI patents or other intellectual property right of NI with respect to any other product(s) of NI or of anyone else (including without limitation, the MATLAB, Simulink and or the Real-Time Workshop software of The MathWorks, Inc.), including without limitation, the right to use any of these other products. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction.
    GMT+8, 2025-9-28 23:05
