查看: 2781|回复: 0
[NI驱动程序] NI-SWITCH 2.0 Win32Eng NI开关产品驱动程序2.0下载
    1 小时前
  • 签到天数: 3792 天
    连续签到: 43 天
    发表于 2021-7-27 22:29:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    Win32Eng
    2.0
    文件大小: 356774437 字节 (340.25 MB)
    修改日期: 2008-08-27 13:24
    MD5: 7a1fe5ebe9f148aaf63a91f39836779e(官方正确)
    SHA1: f3f1126e3b14a5f6bfb70c56900e23c515f2eb9e
    SHA256: aacfdbf785d5c97d55324487927feb010056dfc93b259f3723eed15ead5f2be8
    CRC32: f9bd2c82
    Switch2.0.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH 2.0 Readme File
    (c) Copyright 1998, 2001, 2003 National Instruments Corporation. All rights reserved.
    Trademarks: National Instruments, ni.com, and SCXI are trademarks of National Instruments Corporation. Product and company names mentioned herein are trademarks or trade names of their respective companies.
    This file contains the following information:
    • New Features in NI-SWITCH 2.0
    • Supported Switch Modules
    • System Requirements
    • Installed Software Components and Locations
    • New Examples
    • New Documentation
    • New Functions/VIs
    • Known Issues
    • Obsolete/VIs Functions
    • Uninstalling NI-SWITCH 2.0
    • Changes/Fixes in NI-SWITCH 2.0 from 1.6
    • New initialization, scanning, trigger routing, and relay control functions.
    • Support of SCXI-1166/1193 and PXI-2566/2593 switch modules.
    • Simplified example set.
    • Improved switch configuration in MAX.
    • Improved documentation set.
    NI-SWITCH 2.0 now supports the following switch modules:
    • NI SCXI-1127
    • NI SCXI-1128
    • NI SCXI-1129
    • NI SCXI-1160
    • NI SCXI-1161
    • NI SCXI-1163R
    • NI SCXI-1166
    • NI SCXI-1190
    • NI SCXI-1191
    • NI SCXI-1192
    • NI SCXI-1193
    • NI PXI-2501
    • NI PXI-2503
    • NI PXI-2565
    • NI PXI-2566
    • NI PXI-2590
    • NI PXI-2591
    • NI PXI-2593
    NI-DAQmx, Traditional NI-DAQ, and NI-SWITCH 2.0 support Windows 2000/NT/XP/Me/98. It is recommended that you have the most recent service pack for your operating system installed. Windows NT requires Service Pack 6 or later. If you are using Windows NT/98, make sure that you have installed Internet Explorer 5.0 on your computer. Internet Explorer 5.0 or later is required for your help applications to work correctly. Earlier versions of NI-DAQ support other operating systems. To find and download an earlier version of a driver that supports other operating systems, refer toni.com/downloads. For operating system-specific installation instructions, use the DAQ Configuration Wizard atni.com/support/install.
    Recommended ADEs:
    • LabVIEW 7.0
    • CVI 7.0
    Minimum ProcessorPentium 200 MHz or equivalent
    RAM64 MB
    Screen Resolution800 x 600 pixels or no screen
    Operating SystemWindows XP/2000/ME/98 or later
    Recommended ProcessorPentium III/Celeron 600 MHz or equivalent
    RAM256 MB
    Screen Resolution1024 x 768 pixels or no screen
    Operating SystemWindows XP/2000 or later
    The following components are installed for NI-SWITCH 2.0:
    ItemInstalled Location
    NI-SWITCHProgram Files\IVI\Drivers\niSwitch
    DocumentationProgram Files\IVI\Drivers\niSwitch\Documentation
    NI-SWITCH LabVIEW 6.1 supportProgram Files\National Instruments\LabVIEW 6.1\instr.lib\niSwitch
    NI-SWITCH LabVIEW 7.0 supportProgram Files\National Instruments\LabVIEW 7.0\instr.lib\niSwitch
    NI-SWITCH LabVIEW ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\LabVIEW
    NI-SWITCH CVI supportProgram Files\IVI\Drivers\niSwitch
    NI-SWITCH CVI ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\CVI
    NI-SWITCH VB ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\VB
    SWITCH-SFP (Soft Front Panel)Program Files\IVI\Drivers\niSwitch
    NOTE   NI-SWITCH also requires installation of NI-DAQ 7.0, NI-VISA 3.0, Measurement & Automation Explorer 3.0, and the IVI Compliance Package 2.0 which are included in the NI-DAQ 7.0 installation distribution.
    New Examples
    NI-SWITCH 2.0 includes a completely new set of examples covering immediate operations, synchronous scanning, handshaking, and software triggering.
    ADELocation
    LabVIEW\examples\intr\niSwitch
    CVIProgram Files\IVI\Drivers\niSwitch\Examples\CVI
    CProgram Files\IVI\Drivers\niSwitch\Examples\C
    VBProgram Files\IVI\Drivers\niSwitch\Examples\VB
    A complete example list is available in the NI Switches Help.
    New Documentation
    The NI switches documentation set changed from 1.6 to 2.0. All documentation is available at Start» Programs»National Instruments»NI-SWITCH»Documentation. The new documentation set is composed of the following documents:
    NI-SWITCH 2.0 Readme FileNI Switches Getting Started Guide
    Printed and PDF format. Includes safety, hardware & software installation, configuration in Measurement & Automation Explorer (MAX), and connection information.
    NI Switches Help
    HTML help format. Includes SWITCH fundamentals, device specific information, programming information, tutorials, and VI and CVI/C++/VB function references.
    NI-SWITCH Instrument Driver Quick Reference Guide
    Printed and PDF format. Lists the VIs/functions and their associated parameters and data types available with NI-SWITCH 2.0.
    A Specifications document for each switch moduleTerminal Block installation guides.New Functions/VIs
    The following items were introduced in NI-SWITCH 2.0:
    niSwitch Initialize With TopologyniSwitch CommitniSwitch Route Scan Advanced OutputniSwitch Route Trigger InputniSwitch Get Relay CountniSwitch Get Relay NamesniSwitch Relay ControlniSwitch Get Relay Position
    Refer to the NI Switches Help for more information about these functions/VIs.
    Additional functions and VIs have been added to support latest IVI-4.6: IviSwtch Class Specification. Refer to the latest IviSwtch specification at ivifoundation.org.
    The following are known issues for NI-SWITCH 2.0:
    • If reverting back to NI-SWITCH 1.6 from NI-SWITCH 2.0, you must uninstall NI-SWITCH 2.0 and reinstall NI-SWITCH 1.6.
    • Various support files such as .h and .lib files are installed in\Program Files\IVIand\VXIpnpdirectories to support ADEs that only recognize the\VXIpnpdirectory.
    • SCXI-1127 (Rev D and earlier) continuously drives the TTL1 trigger line on the SCXI backplane. This does not allow bus sharing of TTL1 with other SCXI modules. NI-SWITCH will return an error if an SCXI-1127 is in the chassis and if TTL1 is being used for scanning. If using the NI-DAQmx driver for your SCXI system, you will get a resource reservation error if you try to perform a switching or signal conditioning operation that requires use of TTL1.
    • There are known DLL collision issues with the Visual Basic debugger and a National Instruments device driver using Traditional NI-DAQ. A support DLL used by NI-SWITCH fails to load if Visual Basic has already loaded another DLL into the same address space. To change the default address that is used to load the driver DLL, create the following registry key:
      \\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\NI-PAL\CurrentVersion\palConfig\Memory\sharedFixedAddress
      where the value is a DWORD (0x44000000 generally works).
      For the change to take effect, all applications must be shut down and restarted after adding the registry key.
    Obsolete Functions/VIs
    The following functions/VIs are considered obsolete in NI-SWITCH 2.0:
    • Easy niSwitch CIN
    • Easy niSwitch Close
    • Easy niSwitch Open
    • niSwitch Connect and Wait
    • niSwitch Control a Single Switch
    • niSwitch Disconnect and Wait
    • niSwitch EasyIO Connect
    • niSwitch EasyIO Disconnect
    • niSwitch EasyIO Reset
    • niSwitch EasyIO Scan
    • niSwitch EasyIO Scanning Acquisition
    • niSwitch Query a Single Switch
    • niSwitch Scan
    • niSwitch Scanning Acquisition
    • niSwitch Error-Query
    • niSwitch Get Error Info
    For Windows 2000/NT/XP/Me/98, complete the following:
    • Open the Control Panel from the Start»Settings»Control Panel Menu and select Add\Remove Programs.
    • Select National Instruments Software
      and click Change.
    • Select NI-SWITCH 2.0 from the list provided and click Uninstall.
    • SCXI switches and the PXI-2566/2593 can be configured under NI-DAQmx Devices in MAX.
    • NI-SWITCH 2.0 requires installation of NI-DAQmx. Traditional DAQ is required for existing applications that use NI-SWITCH.
    GMT+8, 2026-2-3 09:19
