查看: 3657|回复: 0
[NI驱动程序] NI-SWITCH 3.7.1 Win32/64Eng NI开关产品驱动程序3.7.1下载
    1 小时前
    发表于 2021-7-27 22:51:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    Win32/64Eng
    3.7.1
    文件大小: 857123707 字节 (817.42 MB)
    修改日期: 2008-10-28 23:31
    MD5: fc2f31fe5072d3e97703735915b55d76(官方正确)
    SHA1: 11b1947fdd107688b9a8ed375a791263b30f4cb2
    SHA256: e70b49bc5104398e6f86bc75c3adcfccd77fddf0c19482a2fc01610cac6bc8ed
    CRC32: 0539dea9
    Switch3.7.1.txt (517 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH Readme File
    Version 3.7.1
    Thank you for using NI-SWITCH for Windows Vista/XP/2000.
    This file contains important information about NI-SWITCH and is organized into the following sections:
    • New Features in Version 3.7.1
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-SWITCH
    • Obsolete VIs and Functions
    • Fixed Issues
    • Known Issues
    • Changes by Release
    • Support for the NI PXI-2533/2534 switch modules
    • Support for multisegment triggering in large PXI chassis such as the PXI-1045. This support allows for modules in multiple PXI segments to participate in the same synchronous scanning operation.
    NI-SWITCH 3.7.1 and later supports the following switch modules:
    • NI PXI-2501
    • NI PXI-2503
    • NI PXI-2527
    • NI PXI-2529
    • NI PXI-2530
    • NI PXI-2532
    • NI PXI-2533
    • NI PXI-2534
    • NI PXI-2535
    • NI PXI-2536
    • NI PXI-2545
    • NI PXI-2546
    • NI PXI-2547
    • NI PXI-2548
    • NI PXI-2549
    • NI PXI-2554
    • NI PXI-2555
    • NI PXI-2556
    • NI PXI-2557
    • NI PXI-2558
    • NI PXI-2559
    • NI PXI-2564
    • NI PXI-2565
    • NI PXI-2566
    • NI PXI-2567
    • NI PXI-2568
    • NI PXI-2569
    • NI PXI-2570
    • NI PXI-2575
    • NI PXI-2576
    • NI PXI-2584
    • NI PXI-2585
    • NI PXI-2586
    • NI PXI-2590
    • NI PXI-2591
    • NI PXI-2593
    • NI PXI-2594
    • NI PXI-2595
    • NI PXI-2596
    • NI PXI-2597
    • NI PXI-2598
    • NI PXI-2599
    • NI SCXI-1127
    • NI SCXI-1128
    • NI SCXI-1129
    • NI SCXI-1130
    • NI SCXI-1160
    • NI SCXI-1161
    • NI SCXI-1163R
    • NI SCXI-1166
    • NI SCXI-1167
    • NI SCXI-1169
    • NI SCXI-1175
    • NI SCXI-1190
    • NI SCXI-1191
    • NI SCXI-1192
    • NI SCXI-1193
    • NI SCXI-1194
    • NI SCXI-1195
    NOTES:  NI-SWITCH does not support legacy resource descriptors (SCXI:: and PXI::) under Windows Vista.
    NI-SWITCH supports the NI USB-1359 under Windows 2000, Windows XP, and the 32-bit version of Windows Vista. NI-SWITCH does not support the NI USB-1359 under the 64-bit version of Windows Vista.
    If you are using a PXI product, notice that MXI-4 is supported under Windows Vista/XP/2000, but MXI-3 is supported under only Windows XP/2000.
    NI-SWITCH 3.7.1 and NI-DAQmx 8.7.1 support Windows Vista/XP/2000. It is recommended that you have the most recent service pack for your operating system installed. Earlier versions of NI-SWITCH/NI-DAQ support other operating systems. To find and download an earlier version of a driver that supports other operating systems, refer to ni.com/downloads.
    Minimum System
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • A screen resolution of 800×600 with 256 colors
    • Windows XP/2000, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024×768
    • Windows Vista/XP/2000, with all available critical updates and service packs
    • LabVIEW 7.1, 8.0, 8.2, and 8.5
    • LabVIEW Real-Time Module 7.1.1, 8.0, 8.2, and 8.5
    • LabWindows™/CVI™ 7.1, 8.0, and 8.1
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    FilesInstallation Location on Windows XP/2000 and 32-Bit Version of Windows VistaInstallation Location on 64-Bit Version of Windows Vista
    NI-SWITCHProgram Files\IVI\Drivers\niSwitchProgram Files (x86)\IVI\Drivers\niSwitch
    DocumentationProgram Files\IVI\Drivers\niSwitch\DocumentationProgram Files (x86)\IVI\Drivers\niSwitch\Documentation
    LabVIEW support\instr.lib\niSwitch\instr.lib\niSwitch
    LabVIEW examplesProgram Files\IVI\Drivers\niSwitch\Examples\LabVIEWProgram Files (x86)\IVI\Drivers\niSwitch\Examples\LabVIEW
    CVI supportProgram Files\IVI\Drivers\niDCPowerProgram Files (x86)\IVI\Drivers\niDCPower
    CVI examplesProgram Files\IVI\Drivers\niSwitch\Examples\CVIProgram Files (x86)\IVI\Drivers\niSwitch\Examples\CVI
    C/C++ examplesProgram Files\IVI\Drivers\niSwitch\Examples\CProgram Files (x86)\IVI\Drivers\niSwitch\Examples\C
    VB examplesProgram Files\IVI\Drivers\niSwitch\Examples\VBProgram Files (x86)\IVI\Drivers\niSwitch\Examples\VB
    SWITCH Soft Front PanelProgram Files\IVI\Drivers\niSwitchProgram Files (x86)\IVI\Drivers\niSwitch
    LabVIEW Run-Time Engine 8.0Program Files\National Instruments\Shared\LabVIEW Run-Time\8.0Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\8.0
    NI-DAQmx 8.7.1Program Files\National Instruments\NI-DAQProgram Files (x86)\National Instruments\NI-DAQ
    IVI Compliance Package 3.2Program Files\National Instruments\IVIProgram Files (x86)\National Instruments\IVI
    NI-VISA 4.3WINDOWS\system32WINDOWS\sysWOW64
    Measurement & Automation Explorer 4.4Program Files\National Instruments\MAXProgram Files (x86)\National Instruments\MAX
    Documentation is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    • NI-SWITCH Readme File
    • Readme First: Safety and Radio-Frequency Interference
    Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    • NI Switches Getting Started Guide
    Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information.
    • NI Switches Help
    HTML help format. Includes switching fundamentals, device specific information, programming information, tutorials, a LabVIEW VI reference, and LabWindows/CVI, C++, and Visual Basic function references.
    • NI-SWITCH Instrument Driver Quick Reference Guide
    Printed and PDF format. Lists the VIs/functions and their associated parameters and data types available with NI-SWITCH.
    • Switch Soft Front Panel Help
    HTML help format. Includes step-by-step information about how to use the Switch Soft Front Panel (SFP) to test the basic functionality of your switch module and troubleshoot your applications.
    • NI Switch Specifications
    Printed and PDF format. Lists specifications for each NI switch module.
    • NI Switch Accessory Installation Instructions (Optional)
    Printed and PDF format. Lists NI switch module accessory installation information.
    Examples
    Refer to Start»All Programs»National Instrument»NI-SWITCH»Examples for the examples for the supported ADEs. The examples cover immediate operations, synchronous scanning, handshaking, and software triggering. A complete example list is available in the NI Switches Help.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    For Windows 2000/XP, complete the following steps:
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-SWITCH 3.x from the dialog box that appears.
    For Windows Vista, complete the following steps:
    • Easy niSwitch CIN VI/function
    • Easy niSwitch Close VI/function
    • Easy niSwitch Open VI/function
    • niSwitch Connect and Wait VI/function
    • niSwitch Control a Single Switch VI/function
    • niSwitch Disconnect and Wait VI/function
    • niSwitch EasyIO Connect VI/function
    • niSwitch EasyIO Disconnect VI/function
    • niSwitch EasyIO Reset VI/function
    • niSwitch EasyIO Scan VI/function
    • niSwitch EasyIO Scanning Acquisition VI/function
    • niSwitch Query a Single Switch VI/function
    • niSwitch Scan VI/function
    • niSwitch Scanning Acquisition VI/function
    • niSwitch Error-Query VI/function
    • niSwitch Get Error Info VI/function
    • niSwitch Write Calibration Data VI/function
    • niSwitch Read Calibration Data VI/function
    Fixed Issues
    The following issues were fixed in NI-SWITCH 3.6.
    CAR IDSummary
    45M97A00Commit and initiate are sometimes too slow when scanning
    The following are known issues for NI-SWITCH 3.7.1:
    • Various support files, such as .h and .lib files, are installed in \Program Files\IVI and \VXIpnp directories to support ADEs that only recognize the \VXIpnp directory.
    • SCXI-1127 (Rev D and earlier) continuously drives the TTL1 trigger line on the SCXI backplane. This does not allow bus sharing of TTL1 with other SCXI modules. NI-SWITCH returns an error if an SCXI-1127 is in the chassis and if TTL1 is being used for scanning. If using the NI-DAQmx driver for your SCXI system, you get a resource reservation error if you try to perform a switching or signal conditioning operation that requires use of TTL1.
    • There are known DLL collision issues with the Microsoft Visual Basic debugger and a National Instruments device driver using Traditional NI-DAQ (Legacy). A support DLL used by NI-SWITCH fails to load if Visual Basic has already loaded another DLL into the same address space. To change the default address that is used to load the driver DLL, create the following registry key:
      \\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\NI-PAL\CurrentVersion\palConfig\Memory\
      sharedFixedAddress
      where the value is a DWORD (0x44000000 generally works). For the change to take effect, you must close and restart all applications after adding the registry key.
    • NI-DMM 2.2
      • NI-DMM 2.2 updated the niSwitch DMM Switch Handshaking example for LabVIEW. If you have an earlier version of NI-DMM installed, the VI is inoperable. To use the example with NI-DMM 2.1.2 or earlier, delete the AUX Trig 1 case from the case structure connected to Sample Trigger Source in the niDMM Configure Multi Point VI.
      • NI-DMM 2.2 introduces a new enumerated value, AUX Trig 1.
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using this product. These modes terminate any NI-SWITCH operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    • LabWindows/CVI
      The links in the function panel help in LabWindows/CVI versions 7.1 and 7.1.1 will not work unless you have downloaded the most recent version of the launchhelp.js file. Instructions for downloading and installing the file can be found in the KnowledgeBase entry Why Do I Get "Object Expected" Error When Opening Links in Function Panel Help? You can locate this KB by going to ni.com/info and entering rdnkbe in the Info Code field.
    • Reverting to NI-SWITCH 1.6 after installing NI-SWITCH 3.7.1
    If reverting back to NI-SWITCH 1.6 from NI-SWITCH 3.7.1, you must uninstall NI-SWITCH 3.7.1 and reinstall NI-SWITCH 1.6.
    Changes by Release3.7.1 from 3.6.2
    3.6.2 from 3.6
    • Support for the NI PXI-2535/2536 switch modules
    3.6 from 3.5
    • Support for LabVIEW 8.5
    © 1998–2008 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-23 09:45
