NI-SWITCH 4.3 Win32/64Eng/Jpn NI开关产品驱动程序4.3下载
NI-SWITCH
NI-SWITCH为使用NI开关产品的客户提供支持。
Win32/64Eng/Jpn
4.3
文件大小: 1596851202 字节 (1.49 GB)
修改日期: 2011-05-10 22:06
MD5: 3d2399c973f8a544d9ff75be0a107e05(官方正确)
SHA1: a1d52694c04d98f971d211d7ce9843efd5fffa6a
SHA256: 13f21abaf287f3f306d3392e263c4c32745ee9f05b4d0a637cea8da4d36960fd
CRC32: c35bf56d
Switch4.3.txt
(515 Bytes, 下载次数: 0, 售价: 10 圆)
NI-SWITCH Readme FileVersion 4.3
Thank you for using NI-SWITCH. This file contains important information about NI-SWITCH and is organized into the following sections: - New Features
- Supported Hardware
- System Requirements
- Installed File Names and Locations
- Software
- Documentation
- Examples
- Uninstalling/Modifying NI-SWITCH
- Obsolete VIs and Functions
- Known Issues
- Bug Fixes
New FeaturesNI-SWITCH 4.3 includes the following new features: - Support for the NI PXI-2530B and NI PXI-2571 modules.
- Windows 7 performance improvements.
- Dynamic power budget for NI SwitchBlock cards and carriers.
NI-SWITCH 4.1 includes the following new features: - Support for the NI SwitchBlock, including the NI PXI-2800, NI 2810, NI 2811, NI 2815, and NI 2816.
- Addition of the Analog Bus Sharing Enable property and the NISWITCH_ATTR_ANALOG_BUS_SHARING_ENABLE attribute.
- Creation of the NI Switch Health Center for the maintenance of the NI SwitchBlock.
- Addition of the configured topology option for the niSwitch Initialize With Topology and niSwitch Initialize With Options VIs and the niSwitch_InitWithTopology and niSwitch_InitWithOptions functions.
- Support for Windows 7.
NI-SWITCH 4.0.2 adds support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit) NI-SWITCH 4.0.1 includes bug fixes. NI-SWITCH 4.0 includes the following new features: - Support for LabVIEW 2009 (64-bit).
- Support for NI PXI-2510 and NI PXI/PXIe-2512/2514/2515/2531 modules.
- Support for Immediate Mode FIFO: This feature improves driver execution time of Immediate Mode Operations when operating multiple relays.
- Support for 64-bit user mode.
Supported HardwareNI-SWITCH 4.3 and later supports the following National Instruments switch products: - NI 2810
- NI 2811
- NI 2815
- NI 2816
- NI PXI-2501
- NI PXI-2503
- NI PXI-2510
- NI PXI/PXIe-2512
- NI PXI/PXIe-2514
- NI PXI/PXIe-2515
- NI PXI/PXIe-2527
- NI PXI/PXIe-2529
- NI PXI-2530
- NI PXI-2530B
- NI PXI/PXIe-2531
- NI PXI/PXIe-2532
- NI PXI-2533
- NI PXI-2534
- NI PXI-2535
- NI PXI-2536
- NI PXI-2545
- NI PXI-2546
- NI PXI-2547
- NI PXI-2548
- NI PXI-2549
- NI PXI-2554
- NI PXI-2555
- NI PXI-2556
- NI PXI-2557
- NI PXI-2558
- NI PXI-2559
- NI PXI-2564
- NI PXI-2565
- NI PXI-2566
- NI PXI-2567
- NI PXI-2568
- NI PXI/PXIe-2569
- NI PXI-2570
- NI PXI-2571
- NI PXI/PXIe-2575
- NI PXI-2576
- NI PXI-2584
- NI PXI-2585
- NI PXI-2586
- NI PXI-2590
- NI PXI-2591
- NI PXI/PXIe-2593
- NI PXI-2594
- NI PXI-2595
- NI PXI-2596
- NI PXI-2597
- NI PXI-2598
- NI PXI-2599
- NI PXI-2800
- NI SCXI-1127
- NI SCXI-1128
- NI SCXI-1129
- NI SCXI-1130
- NI SCXI-1160
- NI SCXI-1161
- NI SCXI-1163R
- NI SCXI-1166
- NI SCXI-1167
- NI SCXI-1169
- NI SCXI-1175
- NI SCXI-1190
- NI SCXI-1191
- NI SCXI-1192
- NI SCXI-1193
- NI SCXI-1194
- NI SCXI-1195
NOTES: NI-SWITCH does not support legacy resource descriptors (SCXI:: and PXI::) under Windows 7/Vista.
NI-SWITCH supports the NI USB-1359 under Windows XP and the 32-bit version of Windows 7/Vista. NI-SWITCH does not support the NI USB-1359 under the 64-bit version of Windows 7/Vista.
If you are using a cabled PXI chassis, notice that MXI-4 is supported under Windows 7/Vista/XP, but MXI-3 is supported under only Windows XP. System RequirementsSupported Operating SystemsNI-SWITCH 4.3 and later and NI-DAQmx 9.3 and later support the following operating systems: - Windows 7 (32-bit and 64-bit)
- Windows Vista (32-bit and 64-bit)
- Windows XP (32-bit)
- Windows Server 2003 R2 (32-bit)
- Windows Server 2008 R2 (64-bit)
NOTE: NI-SWITCH 4.3 and later and NI-DAQmx 9.3 and later do not support Windows Server non-R2 editions. It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-SWITCH 4.0.1 or earlier. Supported Real-Time Operating EnvironmentsNI-SWITCH 4.3 and later and NI-DAQmx 9.3 and later support the following real-time operating environments: - LabVIEW Real-Time Module
- LabWindows/CVI Real-Time Module
Minimum System- Processor—Pentium III/Celeron 600 MHz or equivalent
- RAM
- Windows XP: 128 MB
- Windows 7/Vista: 512 MB
- Microsoft Internet Explorer 5.5 or later
- A screen resolution of 800 x 600 with 256 colors
- Windows 7/Vista/XP, with all available critical updates and service packs
Recommended System- Processor—Pentium 4 or equivalent
- RAM
- Windows XP: 256 MB
- Windows 7/Vista: 1 GB
- If you are running your application on an RT target, 64 MB of memory or more is recommended.
Application Development Environments (ADEs)- LabVIEW 8.5.1, 8.6.1, 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), or 2010 SP1 (64-bit)
- LabVIEW Real-Time Module 8.5.1 or later
- LabWindows™/CVI™ 8.1.1 or later
- LabWindows/CVI Real-Time Module 8.1 or later
- Microsoft Visual C++ (MSVC) 6.0 or later
- Microsoft Visual Basic 6.0
Installed File Names and LocationsSoftware- National Instruments file folder location, :
- Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
- Windows 7/Vista: Users\Public\Documents\National Instruments
- Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
- Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
| NOTES: | $(IVIROOTDIR32) is configured as an environment variable on the target system. | | If you upgraded an installation of IVI, your files may be located in the following location:
- Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
- Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
- Windows 7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
| NOTE: | $(IVIROOTDIR64) is configured as an environment variable on the target system. |
File Locations| Item | Installed Location on Windows 7 (32-bit)/Vista (32-bit)/XP | | NI-SWITCH | \Drivers\niSwitch | | NI-SWITCH Function Panel | \Drivers\niSwitch\niSwitch.fp | | NI-SWITCH Examples | \niSwitch\Examples | | NI-SWITCH Header files | \Include | | NI-SWITCH Import Library files (32-bit) | \Lib | | NI-SWITCH Import Library files (64-bit) | \Lib_x64 | | NI-SWITCH DLL (32-bit) | \Bin |
Additional File Locations for Windows 7 (64-bit)/Vista (64-bit)| Item | Installed Location on Windows 7 (64-bit)/Vista (64-bit) | | NI-SWITCH Function Panel | \Drivers\niSwitch\niSwitch.fp | | NI-SWITCH Header files | \Include | | NI-SWITCH Import Library files (64-bit) | \Lib_x64 | | NI-SWITCH DLL (64-bit) | \Bin |
DocumentationDocumentation is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents: - Read Me First: Safety and Electromagnetic Compatibility
Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies. - NI Switches Getting Started Guide
Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information. HTML help format. Includes switching fundamentals, device specific information, programming information, tutorials, a LabVIEW VI reference, and LabWindows/CVI, C++, and Visual Basic function references. Printed and PDF format. Lists specifications for each NI switch module. - NI Switch Accessory Installation Instructions (Optional)
Printed and PDF format. Lists NI switch module accessory installation information. ExamplesRefer to Start»All Programs»National Instrument»NI-SWITCH»Examples for the examples for the supported ADEs. The examples cover immediate operations, synchronous scanning, handshaking, and software triggering. A complete example list is available in the NI Switches Help. Refer to the Installed File Names and Locations section for the installed locations of the example sets. Uninstalling/Modifying NI-SWITCHFor Windows XP, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Add/Remove Programs.
- Select National Instruments Software.
- Click Change/Remove.
- Select NI-SWITCH 4.x from the dialog box that appears.
- Click Remove to uninstall the product; click Modify to change the components that are installed.
For Windows 7/Vista, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Programs and Features.
- Click the Uninstall/Change button.
As part of the NI-SWITCH installation, the following list of software was installed. To completely remove NI-SWITCH from your system, you must remove all of these packages also. - NI IVI Compliance Package 4.2
- NI Measurement & Automation Explorer 4.8
- NI-DAQmx 9.3
- NI-VISA 5.0
- NI Spy 2.7.2
Caution Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly. Obsolete VIs and Functions- niSwitch Can Connect Channels? VI*
- niSwitch Connect and Wait VI/function
- niSwitch Control a Single Switch VI/function
- niSwitch Disconnect and Wait VI/function
- niSwitch Error-Query VI/function
- niSwitch Get Error Info VI/function
- niSwitch Is Debounced? VI*
- niSwitch Is Scanning? VI*
- niSwitch Query a Single Switch VI/function
- niSwitch Read Calibration Data VI/function
- niSwitch Scan VI/function
- niSwitch Scanning Acquisition VI/function
- niSwitch Write Calibration Data VI/function
* The niSwitch Can Connect Channels?, niSwitch Is Debounced?, and niSwitch Is Scanning? VIs were replaced by identical VIs without question marks in the name. Known IssuesYou can access the software and documentation known issues list online. Refer to the NI-SWITCH 4.3 Known Issues List web page on the National Instruments web site for an up-to-date list of known issues in NI-SWITCH 4.3. Bug FixesThe following items are changes in NI-SWITCH 4.1 from NI-SWITCH 4.0.2. | ID | Fixed Issue | | 209501 | Fixed an issue that disabled legacy scanning of multiple modules with NI-SWITCH. |
The following items are changes in NI-SWITCH 4.0.1 from NI-SWITCH 4.0. | ID | Fixed Issue | | 181045 | Fixed power budget issue for the PXI/PXIe-2515. | | 181067 | Fixed an issue where calling Device Reset on certain PXI/PXIe devices (NI-PXI/PXIe-2512/2514/2564/2585/2586) incorrectly updated relay count. |
Copyright © 1998–2011 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. Trademarks CVI, LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
