查看: 2948|回复: 0
[NI驱动程序] NI-SWITCH 4.6 Win32/64Eng/Jpn NI开关产品驱动程序4.6下载
发表于 2021-7-27 23:09:50 | 显示全部楼层 |阅读模式
NI-SWITCH
NI-SWITCH为使用NI开关产品的客户提供支持。
Win32/64Eng/Jpn
4.6
文件大小: 2061478054 字节 (1.92 GB)
修改日期: 2012-10-05 04:10
MD5: b5d1f16b63c0f967b245257de1536b40(官方正确)
SHA1: 9ab3a22882d072309b1f27b79fdee55cdea05a1a
SHA256: f2e0213d0f920784d971de95a6fa4ec5356989af80408fd23c6956dc29e202c1
CRC32: 2aa020f0
Switch4.6.txt (506 Bytes, 下载次数: 0, 售价: 10 圆)
NI-SWITCH Readme File
Version 4.6
Thank you for using NI-SWITCH. This file contains important information about NI-SWITCH and is organized into the following sections:
  • New Features
  • Supported Hardware
  • System Requirements
    • Software
    • Documentation
    • Examples
  • Updates and Notifications
  • Uninstalling/Modifying NI-SWITCH
  • Obsolete VIs and Functions
  • Known Issues
  • Bug Fixes
  • Important Information
NI-SWITCH 4.6 adds support for the NI PXI-2520, NI PXI-2521, NI PXI-2522, NI PXI-2523, and NI PXIe-2790 modules.
NI-SWITCH 4.5.5 adds support for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit).
NI-SWITCH 4.5 adds support for the NI 2833, NI 2834, NI PXI/PXIe-2532B, NI PXI-2720, NI PXI-2722, NI PXIe-2725, NI PXIe-2727, NI PXI-2796, NI PXI-2797, NI PXI-2798, and NI PXI-2799 modules.
NI-SWITCH 4.4 includes the following new features:
  • Support for the NI 2812, NI 2813, NI 2814, NI 2817, and NI PXI/PXIe-2543 modules.
  • Support for one new NI PXI/PXIe-2532 topology and the NI TB-2646 terminal block.
NI-SWITCH 4.3.5 adds support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit).
NI-SWITCH 4.3 includes the following new features:
  • Support for the NI PXI-2530B and NI PXI-2571 modules.
  • Dynamic power budget for NI SwitchBlock cards and carriers.
NI-SWITCH 4.6 and later supports the following National Instruments switch products:
  • NI 2810
  • NI 2811
  • NI 2812
  • NI 2813
  • NI 2814
  • NI 2815
  • NI 2816
  • NI 2817
  • NI 2833
  • NI 2834
  • NI PXI-2501
  • NI PXI-2503
  • NI PXI-2510
  • NI PXI/PXIe-2512
  • NI PXI/PXIe-2514
  • NI PXI/PXIe-2515
  • NI PXI-2520
  • NI PXI-2521
  • NI PXI-2522
  • NI PXI-2523
  • NI PXI/PXIe-2527
  • NI PXI/PXIe-2529
  • NI PXI-2530
  • NI PXI-2530B
  • NI PXI/PXIe-2531
  • NI PXI/PXIe-2532
  • NI PXI/PXIe-2532B
  • NI PXI-2533
  • NI PXI-2534
  • NI PXI-2535
  • NI PXI-2536
  • NI PXI/PXIe-2543
  • NI PXI-2545
  • NI PXI-2546
  • NI PXI-2547
  • NI PXI-2548
  • NI PXI-2549
  • NI PXI-2554
  • NI PXI-2555
  • NI PXI-2556
  • NI PXI-2557
  • NI PXI-2558
  • NI PXI-2559
  • NI PXI-2564
  • NI PXI-2565
  • NI PXI-2566
  • NI PXI-2567
  • NI PXI-2568
  • NI PXI/PXIe-2569
  • NI PXI-2570
  • NI PXI-2571
  • NI PXI/PXIe-2575
  • NI PXI-2576
  • NI PXI-2584
  • NI PXI-2585
  • NI PXI-2586
  • NI PXI-2590
  • NI PXI-2591
  • NI PXI/PXIe-2593
  • NI PXI-2594
  • NI PXI-2595
  • NI PXI-2596
  • NI PXI-2597
  • NI PXI-2598
  • NI PXI-2599
  • NI PXI-2720
  • NI PXI-2722
  • NI PXIe-2725
  • NI PXIe-2727
  • NI PXIe-2790
  • NI PXI-2796
  • NI PXI-2797
  • NI PXI-2798
  • NI PXI-2799
  • NI PXI-2800
  • NI SCXI-1127
  • NI SCXI-1128
  • NI SCXI-1129
  • NI SCXI-1130
  • NI SCXI-1160
  • NI SCXI-1161
  • NI SCXI-1163R
  • NI SCXI-1166
  • NI SCXI-1167
  • NI SCXI-1169
  • NI SCXI-1175
  • NI SCXI-1190
  • NI SCXI-1191
  • NI SCXI-1192
  • NI SCXI-1193
  • NI SCXI-1194
  • NI SCXI-1195
NOTES:  NI-SWITCH does not support legacy resource descriptors (SCXI:: and PXI::) under Windows 7/Vista.
NI-SWITCH supports the NI USB-1359 under Windows XP and the 32-bit version of Windows 7/Vista. NI-SWITCH does not support the NI USB-1359 under the 64-bit version of Windows 7/Vista.
If you are using a cabled PXI chassis, notice that MXI-4 is supported under Windows 7/Vista/XP, but MXI-3 is supported under only Windows XP.
NI-SWITCH 4.6 and later and NI-DAQmx 9.6 and later support the following operating systems:
NOTE:  NI-SWITCH 4.6 and later and NI-DAQmx 9.6 and later do not support Windows Server non-R2 editions.
It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-SWITCH 4.0.1 or earlier.
NI-SWITCH 4.6 and later and NI-DAQmx 9.6 and later support the following real-time operating environments:
  • LabVIEW Real-Time Module
Minimum System
  • RAM—512 MB
  • Windows 7/Vista/XP, with all available critical updates and service packs
Recommended System
  • Processor—Pentium 4 or later
  • RAM—1 GB
  • If you are running your application on an RT target, 64 MB of memory or more is recommended.
  • LabVIEW 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 (32-bit), or 2012 (64-bit)
  • LabVIEW Real-Time Module 2009 SP1, 2010 SP1, 2011 SP1, or 2012
  • LabWindows™/CVI™ 9.0.1 or later
  • LabWindows/CVI Real-Time Module 2009 or later
Installed File Names and LocationsSoftware
    • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
    • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
      NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
      • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
    • Windows 7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
      NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
ItemInstalled Location on Windows 7 (32-bit)/Vista (32-bit)/XP
NI-SWITCH\Drivers\niSwitch
NI-SWITCH Function Panel\Drivers\niSwitch\niSwitch.fp
NI-SWITCH Examples\niSwitch\Examples
NI-SWITCH Header files\Include
NI-SWITCH Import Library files (32-bit)\Lib
NI-SWITCH Import Library files (64-bit)\Lib_x64
NI-SWITCH DLL (32-bit)\Bin
Additional File Locations for Windows 7 (64-bit)/Vista (64-bit)
ItemInstalled Location on Windows 7 (64-bit)/Vista (64-bit)
NI-SWITCH DLL (64-bit)\Bin
Documentation is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
  • NI-SWITCH Readme
  • NI Switches Getting Started Guide—Printed and PDF format. Contains hardware and software installation, MAX configuration, and signal connection information.
  • NI Switches Help—HTML help format. Contains switching fundamentals, device specific information, programming information, tutorials, a LabVIEW VI reference, and LabWindows/CVI, C++, and Visual Basic function references.
  • NI Switch Specifications—Printed and PDF format. Lists specifications for each NI switch module.
  • NI Switch Accessory Installation Instructions (Optional)—Printed and PDF format. Contains NI switch module accessory installation information.
  • Read Me First: Safety and Electromagnetic Compatibility—Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
Examples
Refer to Start»All Programs»National Instrument»NI-SWITCH»Examples for the examples for the supported, previously installed ADEs. The examples cover immediate operations, synchronous scanning, handshaking, and software triggering. A complete example list is available in the NI Switches Help.
Refer to the Installed File Names and Locations section for the installed locations of the example sets.
National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
  • Double-click Add/Remove Programs.
  • Click Change/Remove.
  • Select NI-SWITCH 4.x from the dialog box that appears.
As part of the NI-SWITCH installation, the following list of software was installed. To completely remove NI-SWITCH from your system, you must remove all of these packages also.
  • NI Measurement & Automation Explorer 5.3
  • NI-DAQmx 9.6
  • NI-VISA 5.0
  • NI Spy 2.7.2
  • niSwitch Can Connect Channels? VI*
  • niSwitch Connect and Wait VI/function
  • niSwitch Control a Single Switch VI/function
  • niSwitch Disconnect and Wait VI/function
  • niSwitch Error-Query VI/function
  • niSwitch Get Error Info VI/function
  • niSwitch Is Debounced? VI*
  • niSwitch Is Scanning? VI*
  • niSwitch Query a Single Switch VI/function
  • niSwitch Read Calibration Data VI/function
  • niSwitch Scan VI/function
  • niSwitch Scanning Acquisition VI/function
  • niSwitch Write Calibration Data VI/function
* The niSwitch Can Connect Channels?, niSwitch Is Debounced?, and niSwitch Is Scanning? VIs were replaced by identical VIs without question marks in the name.
You can access the software and documentation known issues list online. Refer to the NI-SWITCH 4.6 Known Issues web page on the National Instruments web site for an up-to-date list of known issues in NI-SWITCH 4.6.
The following items are changes in NI-SWITCH 4.5 from NI-SWITCH 4.4.
328251Fixed an issue where the NI PXI-2571 did not honor user-defined settling times.
The following items are changes in NI-SWITCH 4.4 from NI-SWITCH 4.3.
256580Improved Windows 7 performance.
The following items are changes in NI-SWITCH 4.1 from NI-SWITCH 4.0.2.
209501Fixed an issue that disabled legacy scanning of multiple modules with NI-SWITCH.
The following items are changes in NI-SWITCH 4.0.1 from NI-SWITCH 4.0.
181045Fixed power budget issue for the PXI/PXIe-2515.
181067Fixed an issue where calling Device Reset on certain PXI/PXIe devices (NI-PXI/PXIe-2512/2514/2564/2585/2586) incorrectly updated relay count.
© 1998–2012 National Instruments Corporation. All rights reserved.
QQ|LabVIEW视觉
GMT+8, 2026-4-8 11:20
