查看: 2836|回复: 0
[NI驱动程序] NI-SWITCH 4.8 Win32/64Eng/Jpn NI开关产品驱动程序4.8下载
    9 小时前
    发表于 2021-7-27 23:15:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    Win32/64Eng/Jpn
    4.8
    文件大小: 1887077152 字节 (1.76 GB)
    修改日期: 2013-11-21 00:30
    MD5: e36b22125e90f4be7adc4f3ba55ac493(官方正确)
    SHA1: 34ac111e81dd86d8ae69f6cf6aad790964edcf61
    SHA256: cbd12fd4087f94b11975f57b7a268dc554f3034e067984021f20722f37799728
    CRC32: 355c2813
    Switch4.8.txt (514 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-SWITCH Readme
    2013
    Version 4.8
    Thank you for using NI-SWITCH. This file contains important information about NI-SWITCH and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Updates and Notifications
    • Uninstalling/Modifying NI-SWITCH
    • Known Issues
    • Bug Fixes
    • How to Use NI Software with Microsoft Windows 8
    • NI-SWITCH Drops Support for Microsoft Windows XP and Windows Server 2003 in 2016
    • Important Information
    NI-SWITCH 4.8 includes the following new features:
    • Support for the NI 2865A device.
    • Support for the NI PXI/PXIe-2542 and NI PXI/PXIe-2544 modules.
    • Device pinouts in Measurement & Automation Explorer (MAX) for NI switch modules.
    • Connect multiple channels using the niSwitch Connect Channels VI, and disconnect multiple channels using the niSwitch Disconnect Channels VI.
    • Support for NI-SWITCH run-time custom installers built using National Instruments application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI switches.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using MAX.
      • The run-time installer does not support upgrading from the full NI-SWITCH 4.6.5 or earlier or NI-DAQmx 8.9.x or earlier, to a run-time only installer. You must uninstall these products prior to installing the NI-SWITCH Run-Time installer.
    NI-SWITCH 4.6.5 adds support for LabVIEW 2013 (32-bit)and LabVIEW 2013 (64-bit).
    NI-SWITCH 4.6.1 includes the following new features:
    • Support for the NI PXI/PXIe-2540 and NI PXI/PXIe-2541 modules.
    • Improved the schematic display in Switch Soft Front Panel for some RF multiplexer topologies.
    NI-SWITCH 4.6 adds support for the NI PXI-2520, NI PXI-2521, NI PXI-2522, NI PXI-2523, and NI PXIe-2790 modules.
    NI-SWITCH 4.5.5 adds support for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit).
    NI-SWITCH 4.5 adds support for the NI 2833, NI 2834, NI PXI/PXIe-2532B, NI PXI-2720, NI PXI-2722, NI PXIe-2725, NI PXIe-2727, NI PXI-2796, NI PXI-2797, NI PXI-2798, and NI PXI-2799 modules.
    NI-SWITCH 4.4 includes the following new features:
    • Support for the NI 2812, NI 2813, NI 2814, NI 2817, and NI PXI/PXIe-2543 modules.
    • Support for one new NI PXI/PXIe-2532 topology and the NI TB-2646 terminal block.
    NI-SWITCH 4.3.5 adds support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit).
    NI-SWITCH 4.3 includes the following new features:
    • Support for the NI PXI-2530B and NI PXI-2571 modules.
    • Dynamic power budget for NI SwitchBlock cards and carriers.
    NI-SWITCH 4.8 and later supports the following National Instruments switch products:
    • NI 2810
    • NI 2811
    • NI 2812
    • NI 2813
    • NI 2814
    • NI 2815
    • NI 2816
    • NI 2817
    • NI 2833
    • NI 2834
    • NI 2865A
    • NI PXI-2501
    • NI PXI-2503
    • NI PXI-2510
    • NI PXI/PXIe-2512
    • NI PXI/PXIe-2514
    • NI PXI/PXIe-2515
    • NI PXI-2520
    • NI PXI-2521
    • NI PXI-2522
    • NI PXI-2523
    • NI PXI/PXIe-2527
    • NI PXI/PXIe-2529
    • NI PXI-2530
    • NI PXI-2530B
    • NI PXI/PXIe-2531
    • NI PXI/PXIe-2532
    • NI PXI/PXIe-2532B
    • NI PXI-2533
    • NI PXI-2534
    • NI PXI-2535
    • NI PXI-2536
    • NI PXI/PXIe-2540
    • NI PXI/PXIe-2541
    • NI PXI/PXIe-2542
    • NI PXI/PXIe-2543
    • NI PXI/PXIe-2544
    • NI PXI-2545
    • NI PXI-2546
    • NI PXI-2547
    • NI PXI-2548
    • NI PXI-2549
    • NI PXI-2554
    • NI PXI-2555
    • NI PXI-2556
    • NI PXI-2557
    • NI PXI-2558
    • NI PXI-2559
    • NI PXI-2564
    • NI PXI-2565
    • NI PXI-2566
    • NI PXI-2567
    • NI PXI-2568
    • NI PXI/PXIe-2569
    • NI PXI-2570
    • NI PXI-2571
    • NI PXI/PXIe-2575
    • NI PXI-2576
    • NI PXI-2584
    • NI PXI-2585
    • NI PXI-2586
    • NI PXI-2590
    • NI PXI-2591
    • NI PXI/PXIe-2593
    • NI PXI-2594
    • NI PXI-2595
    • NI PXI-2596
    • NI PXI-2597
    • NI PXI-2598
    • NI PXI-2599
    • NI PXI-2720
    • NI PXI-2722
    • NI PXIe-2725
    • NI PXIe-2727
    • NI PXIe-2790
    • NI PXI-2796
    • NI PXI-2797
    • NI PXI-2798
    • NI PXI-2799
    • NI PXI-2800
    • NI SCXI-1127
    • NI SCXI-1128
    • NI SCXI-1129
    • NI SCXI-1130
    • NI SCXI-1160
    • NI SCXI-1161
    • NI SCXI-1163R
    • NI SCXI-1166
    • NI SCXI-1167
    • NI SCXI-1169
    • NI SCXI-1175
    • NI SCXI-1190
    • NI SCXI-1191
    • NI SCXI-1192
    • NI SCXI-1193
    • NI SCXI-1194
    • NI SCXI-1195
    NOTES:  NI-SWITCH does not support legacy resource descriptors (SCXI:: and PXI::) under Windows 8/7/Vista.
    NI-SWITCH supports the NI USB-1359 under Windows XP and the 32-bit version of Windows 8/7/Vista. NI-SWITCH does not support the NI USB-1359 under the 64-bit version of Windows 8/7/Vista.
    If you are using a cabled PXI chassis, notice that MXI-4 is supported under Windows 8/7/Vista/XP, but MXI-3 is supported under only Windows XP.
    NI-SWITCH 4.8 and later and NI-DAQmx 9.8 and later support the following operating systems:
    NOTE:  NI-SWITCH 4.8 and later and NI-DAQmx 9.8 and later do not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-SWITCH 4.0.1 or earlier.
    NI-SWITCH 4.8 and later and NI-DAQmx 9.8 and later support the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP Service Pack 3 (SP3): 128 MB
      • Windows 8/7/Vista: 512 MB
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 8/7/Vista: 1 GB
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-SWITCH. To add support for ADEs installed after installing NI-SWITCH, modify your NI-SWITCH installation or launch the NI-SWITCH installer again.
    • LabVIEW 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 (32-bit), or 2013 (64-bit)
    • LabVIEW Real-Time Module 2010 SP1, 2011 SP1, 2012 SP1, or 2013
    • LabWindows/CVI 2009 or later
    • LabWindows/CVI Real-Time Module 2010 or later
    Installed File Names and LocationsSoftware
      • Windows XP: Documents and Settings\All Users\Documents\National Instruments
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-SWITCH\Drivers\niSwitch
    NI-SWITCH Function Panel\Drivers\niSwitch\niSwitch.fp
    NI-SWITCH Examples\NI-SWITCH\examples
    NI-SWITCH Header files\Include
    NI-SWITCH Import Library files (32-bit)\Lib
    NI-SWITCH Import Library files (64-bit)\Lib_x64
    NI-SWITCH DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-SWITCH DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    • NI-SWITCH Readme
    • NI Switches Getting Started Guide—Printed and PDF format. Contains hardware and software installation, MAX configuration, and signal connection information.
    • NI Switches Help—HTML help format. Contains switching fundamentals, device specific information, programming information, a LabVIEW reference, and C/CVI/VB reference sections.
    • NI Switch Specifications—Printed and PDF format. Lists specifications for each NI switch module.
    • NI Switch Accessory Installation Instructions (Optional)—Printed and PDF format. Contains NI switch module accessory installation information.
    • Maintain Forced-Air Cooling Note to Users—Printed format. Contains important cooling information for each NI switch.
    • Read Me First: Safety and Electromagnetic Compatibility—Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    NI-SWITCH Updates and Notifications
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
    Perform the following procedure to uninstall NI-SWITCH 4.8:
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-SWITCH 4.x from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-SWITCH installation, the following software is installed. To completely remove the NI-SWITCH installation from your system, you must also remove all of the following packages:
    • NI IVI Compliance Package 4.6
    • NI Measurement & Automation Explorer 5.5
    • NI-DAQmx 9.8
    • NI-VISA 5.0
    • NI Spy 2.7.2
    • NI-SWITCH Run-Time 4.8
    You can access the software and documentation known issues list online. Refer to the NI-SWITCH 4.8 Known Issues web page on the National Instruments web site for an up-to-date list of known issues in NI-SWITCH 4.8.
    The following items are changes in NI-SWITCH 4.8 from NI-SWITCH 4.6.5.
    412074Fixed an issue where the DAQmx Disconnect All VI returned an error when closing or opening multiple relays.
    338542Fixed an issue where the DAQmx Stop Task VI would time out.
    410401Fixed an issue where the NI switch software scanning examples did not work on an RT target.
    363694Fixed an issue with the Multi-Module Scan List that caused scanning to be incomplete.
    410717Fixed an issue where relay commands did not execute while using the USB-1359 with SCXI switch modules.
    The following items are changes in NI-SWITCH 4.6.5 from NI-SWITCH 4.6.1.
    408193Fixed an issue where calling DAQmx Disconnect (Multiple) on the NI PXI/PXIe-2540 or the NI PXI/PXIe-2541 left one or more relays powered.
    393334Fixed an issue where resetting the same switch in two or more parallel threads resulted in an error.
    The following items are changes in NI-SWITCH 4.6.1 from NI-SWITCH 4.6.
    372998Fixed an issue where the NI 2833/2834 power consumption was not accounted for in the carrier power budget.
    373015Removed hyphens from the SwitchBlock model strings in the NISWITCH_SUPPORTED_INSTRUMENT_MODELS constant.
    373073Fixed an issue where the default channel state of the NI PXIe-2790 did not represent the hardware state correctly.
    The following items are changes in NI-SWITCH 4.5 from NI-SWITCH 4.4.
    328251Fixed an issue where the NI PXI-2571 did not honor user-defined settling times.
    The following items are changes in NI-SWITCH 4.4 from NI-SWITCH 4.3.
    256580Improved Windows 7 performance.
    The following items are changes in NI-SWITCH 4.1 from NI-SWITCH 4.0.2.
    209501Fixed an issue that disabled legacy scanning of multiple modules with NI-SWITCH.
    The following items are changes in NI-SWITCH 4.0.1 from NI-SWITCH 4.0.
    181045Fixed power budget issue for the PXI/PXIe-2515.
    181067Fixed an issue where calling Device Reset on certain PXI/PXIe devices (NI-PXI/PXIe-2512/2514/2564/2585/2586) incorrectly updated relay count.
    Using NI Launcher
    Finding All Programs
    NI-SWITCH Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments NI-SWITCH will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-SWITCH that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 1998–2013 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-8 19:07
