NI-SWITCH 17.5 Win32/64Eng/Jpn NI开关产品驱动程序17.5下载
NI-SWITCH
NI-SWITCH为使用NI开关产品的客户提供支持。
Win32/64Eng/Jpn
17.5
文件大小: 1924738952 字节 (1.79 GB)
修改日期: 2018-01-10 07:12
MD5: 9fa074ee941820c059b745fa8755d554(官方正确)
SHA1: dd578b353ba51d285ba94fc5f83d0253db18a3a5
SHA256: 5fe175fa6f4e5eb13d34656f3a46f24fbe6765a956e710c2d9e260a4d0d9e660
CRC32: 5a5f8b4d
Switch17.5.txt
(518 Bytes, 下载次数: 0, 售价: 10 圆)
NI-SWITCH 17.5 ReadmeJanuary 2018 This file contains important information about NI-SWITCH, including installation instructions, new features, a partial list of bugs fixed, and known issues. If you plan to use LabVIEW NXG, refer to LabVIEW NXG Support and Considerations.
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions IVI Compliance Package Functionality Product Security and Critical Updates New Features Supported Hardware Known Issues Bug Fixes Accessing the Help Finding Examples LabVIEW NXG Support and Considerations Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information OverviewNI-SWITCH is an NI instrument driver that you can use to control and configure NI switches. NI-SWITCH is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the switch module and includes an interactive soft front panel and examples. System RequirementsNI-SWITCH 17.5 has the following requirements: - Processor—1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
- RAM—1 GB RAM (32-bit) or 2 GB RAM (64-bit)
- Windows 10/8.1/7, with all available critical updates and service packs
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW. Supported Operating SystemsNI-SWITCH 17.5 supports the following operating systems: - Windows 10/8.11/7 SP12 (32-bit and 64-bit)
- Windows Server 2012 R21 (64-bit)
- Windows Server 2008 R2 SP12 (64-bit)
Note NI-SWITCH 17.0 and later does not support Windows Server non-R2 editions. Note In 2016 NI dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SWITCH 17.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SWITCH 17.5 to an unsupported OS. Additionally, after installing NI-SWITCH 17.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Application Software SupportNI-SWITCH 17.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. [tr][/tr]
| Application Software | Versions Supported by NI-SWITCH | | LabVIEW | 2014, 2015, 2016, 2017 | | LabVIEW Real-Time Module | 2014, 2015, 2016, 2017 | | LabVIEW NXG | 2.0 | | LabWindows™/CVI™ | 2013 and later | | LabWindows™/CVI™ Real-Time Module | 2013 and later | Microsoft Visual Studio SupportIf you are using the NI-SWITCH .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SWITCH .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5. To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport. Installation InstructionsInstalling NI-SWITCH for LabVIEWYou can install all of your LabVIEW products—including NI-SWITCH—using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website. Note - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
- If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
Caution Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly. Note Do not attempt to uninstall by manually deleting files. Installing NI-SWITCH for LabVIEW NXGNI automates LabVIEW NXG installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. IVI Compliance Package FunctionalityNI-SWITCH no longer installs IVI Compliance Package. NI-SWITCH supports IVI configuration and runtime, but no longer supports the following features: - LabVIEW and CVI IVI class driver APIs for developing IVI interchangeable applications
- IVI Class Simulation drivers
- IVI-COM Adapters
If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New Features- NI-SWITCH 17.5 adds support for LabVIEW NXG 2.0.
Supported HardwareThe following list details the hardware models supported in NI-SWITCH 17.5. Matrix Module for SwitchBlock - SWB-2810
- SWB-2811
- SWB-2812
- SWB-2813
- SWB-2814
- SWB-2815
- SWB-2816
- SWB-2817
- SWB-2833
- SWB-2834
- SWB-2865A
PXI Carrier Module for SwitchBlock PXI Matrix Switch Module - PXI/PXIe-2529
- PXI-2530
- PXI-2530B
- PXI/PXIe-2531
- PXI/PXIe-2532
- PXI/PXIe-2532B
- PXI-2533
- PXI-2534
- PXI-2535
- PXI-2536
- PXIe-2737
- PXIe-2738
- PXIe-2739
PXI Multiplexer Switch Modules - PXI-2501
- PXI-2503
- PXIe-2524
- PXIe-2525
- PXIe-2526
- PXI/PXIe-2527
- PXI/PXIe-2575
- PXI-2576
- PXI-2584
- PXI-2585
- PXIe-2746
- PXIe-2747
- PXIe-2748
PXI Programmable Resistor Module - PXI-2720
- PXI-2722
- PXIe-2725
- PXIe-2727
PXI Relay Driver Module PXI Relay Module - PXI-2520
- PXI-2521
- PXI-2522
- PXI-2523
- PXI-2564
- PXI-2565
- PXI-2566
- PXI-2568
- PXI/PXIe-2569
- PXI-2570
- PXI-2571
- PXI-2586
PXI RF Matrix Switch Module - PXI/PXIe-2540
- PXI/PXIe-2541
PXI RF Multiplexer Switch Module - PXI/PXIe-2543
- PXI/PXIe-2544
- PXI-2545
- PXI-2546
- PXI-2547
- PXI-2554
- PXI-2555
- PXI-2556
- PXI-2557
- PXI-2590
- PXI-2591
- PXI/PXIe-2593
- PXI-2594
- PXI-2595
- PXI-2596
- PXI-2597
- PXI-2796
- PXI-2797
PXI RF Relay Module - PXI/PXIe-2542
- PXI-2548
- PXI-2549
- PXI-2558
- PXI-2559
- PXI-2599
- PXI-2799
PXI Signal Insertion Switch Module - PXI-2510
- PXI/PXIe-2512
- PXI/PXIe-2514
- PXI/PXIe-2515
PXI Transfer Switch Modules - PXI-2598
- PXI-2798
- PXIe-2790
General-Purpose Switch Module for SCXI - SCXI-1160
- SCXI-1161
- SCXI-1166
- SCXI-1169
Matrix/Multiplexer Switch Module for SCXI - SCXI-1127
- SCXI-1128
- SCXI-1129
- SCXI-1130
- SCXI-1175
- SCXI-1191
Relay Switch Module for SCXI - SCXI-1163R
- SCXI-1167
- SCXI-1192
RF Multiplexer Switch Module for SCXI - SCXI-1190
- SCXI-1193
- SCXI-1194
- SCXI-1195
Known IssuesYou can access the software and documentation known issues list online. Refer to the NI-SWITCH Known Issues at ni.com/info and enter the Info Code exqtsr for an up-to-date list of known issues in NI-SWITCH 17.5. Bug FixesThe following items are changes in NI-SWITCH 15.1.1 from NI-SWITCH 15.1.0.
| ID | Fixed Issue | | 530716 | Fixed issue that caused MAX with NI Switch Executive to hang when users configured RouteGroups with more connections than are normally allowed by the relay drive limit. | Accessing the HelpRefer to the NI Switches Help, accessible from Start»All Programs»National Instruments»NI-SWITCH»NI-SWITCH Documentation, for information about NI-SWITCH. Finding ExamplesYou can access all the installed NI-SWITCH examples at Start»All Programs»National Instruments»NI-SWITCH»NI-SWITCH Examples. Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SWITCH are located in the LabVIEW XXXX\examples\instr\niSwitch directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions: - Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
- Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all switch examples.
LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using LabVIEW NXG with NI-SWITCH 17.5. LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways: - System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
LabVIEW NXG Hardware SupportThe following list details the hardware models supported in NI-SWITCH 17.5 for LabVIEW NXG. Matrix Module for SwitchBlock - SWB-2810
- SWB-2811
- SWB-2812
- SWB-2813
- SWB-2814
- SWB-2815
- SWB-2816
- SWB-2817
- SWB-2833
- SWB-2834
- SWB-2865A
- PXI-2530
- PXI-2530B
- PXI/PXIe-2531
- PXI/PXIe-2532
- PXI/PXIe-2532B
- PXI-2533
- PXI-2534
- PXI-2535
- PXI-2536
- PXIe-2737
- PXIe-2738
- PXIe-2739
PXI Multiplexer Switch Module - PXI-2501
- PXI-2503
- PXIe-2524
- PXIe-2525
- PXIe-2526
- PXI/PXIe-2527
- PXI/PXIe-2575
- PXI-2576
- PXI-2584
- PXI-2585
- PXIe-2746
- PXIe-2747
- PXIe-2748
- PXI-2722
- PXIe-2725
- PXIe-2727
- PXI-2521
- PXI-2522
- PXI-2523
- PXI-2564
- PXI-2565
- PXI-2566
- PXI-2568
- PXI/PXIe-2569
- PXI-2570
- PXI-2571
- PXI-2586
- PXI/PXIe-2541
- PXI/PXIe-2544
- PXI-2545
- PXI-2546
- PXI-2547
- PXI-2554
- PXI-2555
- PXI-2556
- PXI-2557
- PXI-2590
- PXI-2591
- PXI/PXIe-2593
- PXI-2594
- PXI-2595
- PXI-2596
- PXI-2597
- PXI-2796
- PXI-2797
- PXI-2548
- PXI-2549
- PXI-2558
- PXI-2559
- PXI-2599
- PXI-2799
- PXI/PXIe-2512
- PXI/PXIe-2514
- PXI/PXIe-2515
- PXI-2798
- PXIe-2790
- SCXI-1161
- SCXI-1166
- SCXI-1169
- SCXI-1128
- SCXI-1129
- SCXI-1130
- SCXI-1175
- SCXI-1191
- SCXI-1167
- SCXI-1192
- SCXI-1193
- SCXI-1194
- SCXI-1195
LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My NI Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Legal InformationCopyright © 1998–2018 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Members of the NI Alliance Partner Program are business entities independent from NI and have no agency, partnership, or joint-venture relationship with NI. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 375366D-01
