查看: 3310|回复: 0
[NI驱动程序] NI-SWITCH 18.5 Win32/64Eng/Jpn NI开关产品驱动程序18.5下载
    9 小时前
    发表于 2021-7-27 23:30:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    Win32/64Eng/Jpn
    18.5.0
    文件大小: 2205017632 字节 (2.05 GB)
    修改日期: 2018-10-29 13:26
    MD5: 949fe9b898bb6c9c1d01d70f213f16b2(官方正确)
    SHA1: f0b2b9b3f10ecddc4cb93d311db1e7de4e46067f
    SHA256: cbbf433a94a77d6953f07b137a622bc6ce7fc5e9c8b1b202bb3c143193afc884
    CRC32: a87e74af
    Switch18.5.txt (546 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH 18.5 Readme
    September 2018
    This file contains important information about NI-SWITCH, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-SWITCH is an NI instrument driver that you can use to control and configure NI switches. NI-SWITCH is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the switch module and includes an interactive soft front panel and examples.
    NI-SWITCH 18.5 has the following requirements:
    NI-SWITCH 18.5 supports the following operating systems:
    Note  NI-SWITCH 17.0 and later does not support Windows Server non-R2 editions.
    Note  In 2016 NI dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SWITCH 18.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SWITCH 18.5 to an unsupported OS. Additionally, after installing NI-SWITCH 18.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SWITCH 18.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr]
    Versions Supported by NI-SWITCH
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW Real-Time Module2015, 2016, 2017, 2018
    LabVIEW NXG3.0
    LabWindows™/CVI™ Real-Time Module2013 and later
    If you are using the NI-SWITCH .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SWITCH .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads and search for NI-SWITCH 18.5.
    • Click NI-SWITCH 18.5 and then the download link and run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Installing NI-SWITCH for LabVIEW NXG
    NI-SWITCH no longer installs IVI Compliance Package. NI-SWITCH supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    NI-SWITCH 18.5 includes the following new features.
    • Support for LabVIEW NXG 3.0.
    The following list details the hardware models supported in NI-SWITCH 18.5.
    Matrix Module for SwitchBlock
    • SWB-2810
    • SWB-2811
    • SWB-2812
    • SWB-2813
    • SWB-2814
    • SWB-2815
    • SWB-2816
    • SWB-2817
    • SWB-2833
    • SWB-2834
    • SWB-2865A
    PXI Carrier Module for SwitchBlock
    • PXI-2800
    PXI Matrix Switch Module
    • PXI/PXIe-2529
    • PXI-2530
    • PXI-2530B
    • PXI/PXIe-2531
    • PXI/PXIe-2532
    • PXI/PXIe-2532B
    • PXI-2533
    • PXI-2534
    • PXI-2535
    • PXI-2536
    • PXIe-2737
    • PXIe-2738
    • PXIe-2739
    PXI Multiplexer Switch Modules
    • PXI-2501
    • PXI-2503
    • PXIe-2524
    • PXIe-2525
    • PXIe-2526
    • PXI/PXIe-2527
    • PXI/PXIe-2575
    • PXI-2576
    • PXI-2584
    • PXI-2585
    • PXIe-2746
    • PXIe-2747
    • PXIe-2748
    PXI Programmable Resistor Module
    • PXI-2720
    • PXI-2722
    • PXIe-2725
    • PXIe-2727
    PXI Relay Driver Module
    • PXI-2567
    PXI Relay Module
    • PXI-2520
    • PXI-2521
    • PXI-2522
    • PXI-2523
    • PXI-2564
    • PXI-2565
    • PXI-2566
    • PXI-2568
    • PXI/PXIe-2569
    • PXI-2570
    • PXI-2571
    • PXI-2586
    PXI RF Matrix Switch Module
    • PXI/PXIe-2540
    • PXI/PXIe-2541
    PXI RF Multiplexer Switch Module
    • PXI/PXIe-2543
    • PXI/PXIe-2544
    • PXI-2545
    • PXI-2546
    • PXI-2547
    • PXI-2554
    • PXI-2555
    • PXI-2556
    • PXI-2557
    • PXI-2590
    • PXI-2591
    • PXI/PXIe-2593
    • PXI-2594
    • PXI-2595
    • PXI-2596
    • PXI-2597
    • PXI-2796
    • PXI-2797
    PXI RF Relay Module
    • PXI/PXIe-2542
    • PXI-2548
    • PXI-2549
    • PXI-2558
    • PXI-2559
    • PXI-2599
    • PXI-2799
    PXI Signal Insertion Switch Module
    • PXI-2510
    • PXI/PXIe-2512
    • PXI/PXIe-2514
    • PXI/PXIe-2515
    PXI Transfer Switch Modules
    • PXI-2598
    • PXI-2798
    • PXIe-2790
    General-Purpose Switch Module for SCXI
    • SCXI-1160
    • SCXI-1161
    • SCXI-1166
    • SCXI-1169
    Matrix/Multiplexer Switch Module for SCXI
    • SCXI-1127
    • SCXI-1128
    • SCXI-1129
    • SCXI-1130
    • SCXI-1175
    • SCXI-1191
    Relay Switch Module for SCXI
    • SCXI-1163R
    • SCXI-1167
    • SCXI-1192
    RF Multiplexer Switch Module for SCXI
    • SCXI-1190
    • SCXI-1193
    • SCXI-1194
    • SCXI-1195
    You can access the software and documentation known issues list online. Refer to the NI-SWITCH Known Issues at ni.com/info and enter the Info Code exz48d for an up-to-date list of known issues in NI-SWITCH 18.5.
    Refer to the NI Switches Help, accessible from Start»All Programs»National Instruments»NI-SWITCH»NI-SWITCH Documentation, for information about NI-SWITCH.
    You can access all the installed NI-SWITCH examples at Start»All Programs»National Instruments»NI-SWITCH»NI-SWITCH Examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SWITCH are located in the LabVIEW XXXX\examples\instr\niSwitch directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all switch examples.
    The following sections detail considerations for using LabVIEW NXG with NI-SWITCH 18.5.
    LabVIEW NXG Hardware Support
    The following list details the hardware models supported in NI-SWITCH 18.5 for LabVIEW NXG.
    • SWB-2810
    • SWB-2811
    • SWB-2812
    • SWB-2813
    • SWB-2814
    • SWB-2815
    • SWB-2816
    • SWB-2817
    • SWB-2833
    • SWB-2834
    • SWB-2865A
    • PXI-2800
    • PXI/PXIe-2529
    • PXI-2530
    • PXI-2530B
    • PXI/PXIe-2531
    • PXI/PXIe-2532
    • PXI/PXIe-2532B
    • PXI-2533
    • PXI-2534
    • PXI-2535
    • PXI-2536
    • PXIe-2737
    • PXIe-2738
    • PXIe-2739
    • PXI-2501
    • PXI-2503
    • PXIe-2524
    • PXIe-2525
    • PXIe-2526
    • PXI/PXIe-2527
    • PXI/PXIe-2575
    • PXI-2576
    • PXI-2584
    • PXI-2585
    • PXIe-2746
    • PXIe-2747
    • PXIe-2748
    • PXI-2720
    • PXI-2722
    • PXIe-2725
    • PXIe-2727
    • PXI-2567
    PXI Relay Module
    • PXI-2520
    • PXI-2521
    • PXI-2522
    • PXI-2523
    • PXI-2564
    • PXI-2565
    • PXI-2566
    • PXI-2568
    • PXI/PXIe-2569
    • PXI-2570
    • PXI-2571
    • PXI-2586
    • PXI/PXIe-2540
    • PXI/PXIe-2541
    • PXI/PXIe-2543
    • PXI/PXIe-2544
    • PXI-2545
    • PXI-2546
    • PXI-2547
    • PXI-2554
    • PXI-2555
    • PXI-2556
    • PXI-2557
    • PXI-2590
    • PXI-2591
    • PXI/PXIe-2593
    • PXI-2594
    • PXI-2595
    • PXI-2596
    • PXI-2597
    • PXI-2796
    • PXI-2797
    PXI RF Relay Module
    • PXI/PXIe-2542
    • PXI-2548
    • PXI-2549
    • PXI-2558
    • PXI-2559
    • PXI-2599
    • PXI-2799
    • PXI-2510
    • PXI/PXIe-2512
    • PXI/PXIe-2514
    • PXI/PXIe-2515
    • PXI-2598
    • PXI-2798
    • PXIe-2790
    • SCXI-1160
    • SCXI-1161
    • SCXI-1166
    • SCXI-1169
    • SCXI-1127
    • SCXI-1128
    • SCXI-1129
    • SCXI-1130
    • SCXI-1175
    • SCXI-1191
    • SCXI-1163R
    • SCXI-1167
    • SCXI-1192
    • SCXI-1190
    • SCXI-1193
    • SCXI-1194
    • SCXI-1195
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 1998–2018 National Instruments. All rights reserved.
    375366G-01
    GMT+8, 2025-12-8 19:07
