查看: 5828|回复: 0
[NI驱动程序] NI-SWITCH 19.5 Win32/64Eng/Jpn NI开关产品驱动程序19.5下载
    9 小时前
    发表于 2021-7-27 23:37:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    Win32/64Eng/Jpn
    19.5
    文件大小: 1948944384 字节 (1.82 GB)
    修改日期: 2019-10-25 22:51
    MD5: 16fc48155b0a65bd69dab86ae4db079b(官方正确)
    SHA1: 018908d81ebe303721c7809fe967d29e923dfe7d
    SHA256: 267fd736e8499ad06d1d125724adb0b2df1cd07cd81e798f537466614aa27cb8
    CRC32: 2e7d5859
    Switch19.5.txt (544 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH 19.5 Readme
    September 2019
    This file contains important information about NI-SWITCH, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-SWITCH Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-SWITCH is an NI instrument driver that you can use to control and configure NI switches. NI-SWITCH is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the switch module and includes an interactive soft front panel and examples.
    NI-SWITCH 19.5 has the following requirements:
    NI-SWITCH 19.5 supports the following operating systems:
    Note  NI-SWITCH 17.0 and later does not support Windows Server non-R2 editions.
    Note  In 2016 NI dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SWITCH 19.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SWITCH 19.5 to an unsupported OS. Additionally, after installing NI-SWITCH 19.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SWITCH 19.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr]
    Application SoftwareVersions Supported by NI-SWITCH
    LabVIEW2016, 2017, 2018, 2019
    LabVIEW Real-Time Module2016, 2017, 2018, 2019
    LabVIEW NXG4.0
    LabWindows™/CVI™ Real-Time Module2013 and later
    If you are using the NI-SWITCH .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SWITCH .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs NI-SWITCH 19.5 using NI Package Manager. If you do not already have NI software installed, NI-SWITCH 19.5 installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    NI-SWITCH no longer installs IVI Compliance Package. NI-SWITCH supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2019 DVD.
    NI-SWITCH 19.5 includes the following new features.
    • Support for LabVIEW NXG 4.0.
    The following list details the hardware models supported in NI-SWITCH 19.5.
    Matrix Module for SwitchBlock
    • SWB-2810
    • SWB-2811
    • SWB-2812
    • SWB-2813
    • SWB-2814
    • SWB-2815
    • SWB-2816
    • SWB-2817
    • SWB-2833
    • SWB-2834
    • SWB-2865A
    PXI Carrier Module for SwitchBlock
    • PXI-2800
    PXI Matrix Switch Module
    • PXI/PXIe-2529
    • PXI-2530
    • PXI-2530B
    • PXI/PXIe-2531
    • PXI/PXIe-2532
    • PXI/PXIe-2532B
    • PXI-2533
    • PXI-2534
    • PXI-2535
    • PXI-2536
    • PXIe-2737
    • PXIe-2738
    • PXIe-2739
    PXI Multiplexer Switch Modules
    • PXI-2501
    • PXI-2503
    • PXIe-2524
    • PXIe-2525
    • PXIe-2526
    • PXI/PXIe-2527
    • PXI/PXIe-2575
    • PXI-2576
    • PXI-2584
    • PXI-2585
    • PXIe-2746
    • PXIe-2747
    • PXIe-2748
    PXI Programmable Resistor Module
    • PXI-2720
    • PXI-2722
    • PXIe-2725
    • PXIe-2727
    PXI Relay Driver Module
    • PXI-2567
    PXI Relay Module
    • PXI-2520
    • PXI-2521
    • PXI-2522
    • PXI-2523
    • PXI-2564
    • PXI-2565
    • PXI-2566
    • PXI-2568
    • PXI/PXIe-2569
    • PXI-2570
    • PXI-2571
    • PXI-2586
    PXI RF Matrix Switch Module
    • PXI/PXIe-2540
    • PXI/PXIe-2541
    PXI RF Multiplexer Switch Module
    • PXI/PXIe-2543
    • PXI/PXIe-2544
    • PXI-2545
    • PXI-2546
    • PXI-2547
    • PXI-2554
    • PXI-2555
    • PXI-2556
    • PXI-2557
    • PXI-2590
    • PXI-2591
    • PXI/PXIe-2593
    • PXI-2594
    • PXI-2595
    • PXI-2596
    • PXI-2597
    • PXI-2796
    • PXI-2797
    PXI RF Relay Module
    • PXI/PXIe-2542
    • PXI-2548
    • PXI-2549
    • PXI-2558
    • PXI-2559
    • PXI-2599
    • PXI-2799
    PXI Signal Insertion Switch Module
    • PXI-2510
    • PXI/PXIe-2512
    • PXI/PXIe-2514
    • PXI/PXIe-2515
    PXI Transfer Switch Modules
    • PXI-2598
    • PXI-2798
    • PXIe-2790
    • NI-SWITCH 19.1 drops support for SCXI Switch Modules.
    You can access the software and documentation known issues list online. Refer to the NI-SWITCH Known Issues at ni.com/info and enter the Info Code niswitch195ki for an up-to-date list of known issues in NI-SWITCH 19.5.
    Refer to the NI Switches Help, accessible from Start»All Programs»National Instruments»NI-SWITCH»NI-SWITCH Documentation, for information about NI-SWITCH.
    You can access all the installed NI-SWITCH examples at Start»All Programs»National Instruments»NI-SWITCH»NI-SWITCH Examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SWITCH are located in the LabVIEW XXXX\examples\instr\niSwitch directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all switch examples.
    The following sections detail considerations for using LabVIEW NXG with NI-SWITCH 19.5.
    LabVIEW NXG Hardware Support
    The following list details the hardware models supported in NI-SWITCH 19.5 for LabVIEW NXG.
    • SWB-2810
    • SWB-2811
    • SWB-2812
    • SWB-2813
    • SWB-2814
    • SWB-2815
    • SWB-2816
    • SWB-2817
    • SWB-2833
    • SWB-2834
    • SWB-2865A
    • PXI-2800
    • PXI/PXIe-2529
    • PXI-2530
    • PXI-2530B
    • PXI/PXIe-2531
    • PXI/PXIe-2532
    • PXI/PXIe-2532B
    • PXI-2533
    • PXI-2534
    • PXI-2535
    • PXI-2536
    • PXIe-2737
    • PXIe-2738
    • PXIe-2739
    • PXI-2501
    • PXI-2503
    • PXIe-2524
    • PXIe-2525
    • PXIe-2526
    • PXI/PXIe-2527
    • PXI/PXIe-2575
    • PXI-2576
    • PXI-2584
    • PXI-2585
    • PXIe-2746
    • PXIe-2747
    • PXIe-2748
    • PXI-2720
    • PXI-2722
    • PXIe-2725
    • PXIe-2727
    • PXI-2567
    PXI Relay Module
    • PXI-2520
    • PXI-2521
    • PXI-2522
    • PXI-2523
    • PXI-2564
    • PXI-2565
    • PXI-2566
    • PXI-2568
    • PXI/PXIe-2569
    • PXI-2570
    • PXI-2571
    • PXI-2586
    • PXI/PXIe-2540
    • PXI/PXIe-2541
    • PXI/PXIe-2543
    • PXI/PXIe-2544
    • PXI-2545
    • PXI-2546
    • PXI-2547
    • PXI-2554
    • PXI-2555
    • PXI-2556
    • PXI-2557
    • PXI-2590
    • PXI-2591
    • PXI/PXIe-2593
    • PXI-2594
    • PXI-2595
    • PXI-2596
    • PXI-2597
    • PXI-2796
    • PXI-2797
    PXI RF Relay Module
    • PXI/PXIe-2542
    • PXI-2548
    • PXI-2549
    • PXI-2558
    • PXI-2559
    • PXI-2599
    • PXI-2799
    • PXI-2510
    • PXI/PXIe-2512
    • PXI/PXIe-2514
    • PXI/PXIe-2515
    • PXI-2598
    • PXI-2798
    • PXIe-2790
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-SWITCH will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 1998–2019 National Instruments. All rights reserved.
    375366L-01
    GMT+8, 2025-12-8 19:07
