查看: 7466|回复: 0
[LabVIEW] NI LabVIEW 2020 SP1 Community Linux64Eng LabVIEW20.1.0社区版Linux系统64位英文版离线安装包下载
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-8-9 11:10:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2020 SP1 Linux社区版
    发布日期:
    2021/1/8
    包含的版本:
    2020 SP1
    SUSE
    Scientific Linux
    CentOS
    RedHat
    Linux
    语言:
    English
    文件大小: 676915200 字节 (645.56 MB)
    修改日期: 2020-12-17 04:38
    MD5: 282fe2b2f7479681a7928f0d6700319c(官方正确)
    SHA1: d5bd71615f309c5cf8b7453cff8e90189bb89ba1
    SHA256: 45db028953381cc7f41523f7d337afd8066a4a459eb5048f14fa81ea4df1e354
    CRC32: d38bf954
    LV2020SP1Linux.txt (546 Bytes, 下载次数: 0, 售价: 20 圆)
    LabVIEW 2020 SP1 Readme for GNU/Linux
    January 2021
    This file contains important information about LabVIEW 2020 SP1 for Linux, including system requirements, installation instructions, known issues, and a partial list of bugs fixed.
    Supported Drivers
    LabVIEW 2020 SP1 for Linux has the following requirements:
    Linux
    Operating SystemLinux kernel 2.6x or 3.x
    GNU C Library (glibc) Version 2.11 or later for the Intel x86_64 architecture
    openSUSE Leap 15.0
    openSUSE Leap 15.1
    Red Hat Enterprise Linux 7
    Red Hat Enterprise Linux 8
    CentOS 7
    CentOS 8
    • LabVIEW 2020 SP1 for Linux is available only in 64-bit.
    Complete the following steps to install and activate LabVIEW for Linux.
    Insert and mount the LabVIEW installation media. As the root user in the mounted directory, enter sh ./INSTALL to install LabVIEW in the /usr/local directory.
    To install LabVIEW modules and toolkits, refer to the readme of each product for installation instructions. The VI Analyzer Toolkits installs with the LabVIEW Professional Development System for Linux.
    You can install NI device drivers from ni.com/linuxdrivers.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2020 SP1.
    Changes to selection rules for named Bundle and Unbundle nodes inside malleable VIs
    The rules for how LabVIEW selects cluster elements when you use a Bundle By Name function, Unbundle By Name function, or Unbundle / Bundle Elements Border Node have improved. The improvements may cause existing code to behave differently than you expect when you use these nodes inside a malleable VI. Visit ni.com/r/eakjbu for more information about how these changes impact existing code.
    Complete the following steps to install a patch on computers with LabVIEW 2020 SP1. Replace f# with the specific patch you are installing.
    • Close all NI software.
    • Download LV2020_f#LPatch.tgz into a folder. For example, download the file to ~/Desktop/Patch/LV2020_f#LPatch.tgz.
    • Unpack LV2020_f#LPatch.tgz. For example, cd ~/Desktop/Patch and tar -xzf LV2020_f#LPatch.tgz.
    • Run the installation script as root. For example, type su and enter the password. Then run ./INSTALL.
    • After the installation script reports that Patch installation completed, verify that the patch installed correctly. Select Help»About LabVIEW and look for 20.0.0f# on the right portion of the window.
    LabVIEW 2020 SP1 for Linux supports the following modules and toolkits.
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    Supported Drivers
    Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2020 SP1, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 SP1 Known Issues for an up-to-date list of known issues.
    You can access the software and documentation bug fix list online. Visit ni.com/r/lv2020sp1bf for an up-to-date list of bug fixes in LabVIEW 2020 SP1.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2020 SP1.
    © 2004–2021 National Instruments Corporation. All rights reserved.
    374718P-01
    GMT+8, 2025-12-5 13:37
