查看: 3383|回复: 0
[LV工具模块] NI LabVIEW 2021 Digital Filter Design Toolkit x64Win10 64bitENG LV2021数字滤波器设计工具包64位版DFDT2021
    昨天 16:03
    发表于 2021-8-26 15:03:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW数字滤波器设计工具包
    LabVIEW数字滤波器设计工具包提供了设计、分析和实现数字滤波器所需的交互式工具。
    LabVIEW数字滤波器设计工具包是一个LabVIEW附加软件,其内置的交互式设计工具可以帮助您探索经典的滤波器设计。该工具包还提供了各种算法、滤波器拓扑结构以及用于定点与浮点数字滤波器分析工具。对于定点滤波器,您可以建立量化效应的模型,优化数值表示/拓扑结构,并使用自动生成的ANSI C或LabVIEW FPGA代码,将设计部署到数字信号处理器或FPGA上。
    DFDT数字滤波器工具包,从2018年版本开始提供64位版的。之前的版本,则只有32位的版本。自2022Q3版开始,LabVIEW专业版集成DFDT工具包,但是仍然有独立安装版本。从2024Q1版开始,则不再提供独立安装包,仅在LabVIEW专业版安装包中包含DFDT工具包。
    LabVIEW 2021数字滤波器设计工具包
    发布日期:2021/8/13
    包含的版本:2021完整版,版本号21.0.0
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    文件大小: 404250624 字节 (385.52 MB)
    修改日期: 2021-08-12 05:36
    MD5: fce9949b5c9378c52042505af7e68de4
    SHA1: e6d22d5c3f3c476e27440d724ae79e6e554e9b42
    SHA256: 923f9c09e05d9d2e89d74518f165423c761bbfccd5ad27fc7cd436a51e97db14
    CRC32: d554c3e2
    NI官方下载地址和百度网盘下载地址:
    请注册登录视觉论坛会员,购买附件下载查看
    DFDT-X64.txt (660 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2021 Digital Filter Design Toolkit Readme
    July 2021
    This file contains installation instructions and compatibility information for the LabVIEW Digital Filter Design Toolkit.
    • Manuals: New features, behavior changes, and other documentation
    LabVIEW Digital Filter Design Toolkit (64-bit)
    The Digital Filter Design Toolkit includes the Digital Filter Design VIs and the Adaptive Filters VIs to provide a collection of digital filter design tools, including adaptive filter design tools, to supplement the LabVIEW Full Development System. The Digital Filter Design Toolkit helps you design digital filters and filter banks without requiring you to have advanced knowledge of digital signal processing or digital filtering techniques. With the Digital Filter Design Toolkit, you can design and analyze floating-point and fixed-point digital filters and filter banks. With the Digital Filter Design Toolkit, you also can design and analyze floating-point and fixed-point adaptive filters. You also can simulate fixed-point digital filters, including fixed-point adaptive filters.
    Without prior knowledge about programming in LabVIEW, you can use the Digital Filter Design Express VIs to interact graphically with filter specifications to design appropriate digital filters and filter banks.
    The Digital Filter Design VIs help you design the following filters and filter banks:
    • Digital finite impulse response (FIR) or infinite impulse response (IIR) filters—You can use the VIs to analyze the characteristics of the digital filter, change the implementation structure of the digital filter, and process data with the digital filter. In addition to the floating-point support, the Digital Filter Design VIs also help you create a fixed-point digital filter model, analyze the characteristics of the fixed-point digital filter, simulate the performance of the fixed-point digital filter, and generate fixed-point C code, or integer LabVIEW code.
    • Floating-point multirate digital filters—You can use the VIs to design a floating-point single-stage or multistage multirate filter, analyze the characteristics of the floating-point multirate filter, and process data with the floating-point multirate filter. In addition to the floating-point filter design, the Digital Filter Design VIs also help you create a fixed-point multirate filter, analyze the characteristics of the fixed-point multirate filter, and simulate the behavior of the fixed-point multirate filter.
    • Filter banks—You can use the VIs to design a 2-band quadrature mirror filter (QMF) or M-band cosine-modulated filter bank, analyze the characteristics of a filter bank, decompose or reconstruct signals with filter banks, retrieve filter bank parameters, and create a filter bank from a prototype filter.
    The Adaptive Filters VIs help you design a floating-point and fixed-point adaptive filter for different applications and with different adaptive filter algorithms. You can use the Adaptive Filters VIs to create an adaptive filter with the following adaptive algorithms:
    • Least mean squares (LMS) and the variants, such as normalized LMS, leaky LMS, normalized leaky LMS, sign LMS, and fast block LMS
    • Filtered-x LMS and normalized filtered-x LMS
    • Recursive least squares (RLS) and QR decomposition-based RLS (QR-RLS)
    You can apply the adaptive filter that you create to applications like adaptive noise cancellation, adaptive echo cancellation, and system identification.
    In addition to the graphical tools for digital filter design, the toolkit also provides Digital Filter Design MathScript Module functions that LabVIEW MathScript supports. These functions enable you to design filters in a text-based environment. You must install the LabVIEW MathScript Module to use the Digital Filter Design MathScript Module functions.
    In addition to the system requirements for the LabVIEW Development System, the Digital Filter Design Toolkit has the following requirements:
    • LabVIEW 2021 Full or Professional Development System
    • At least 200 MB of disk space
    The Digital Filter Design Toolkit supports the following operating systems:
    Download the Digital Filter Design Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    You can also install LabVIEW and the Digital Filter Design Toolkit by using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the Digital Filter Design Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Digital Filter Design folder and the Toolkits and Modules»Adaptive Filters folder to access the examples. You also can find the examples for the Digital Filter Design Toolkit in the labview\examples\Digital Filter Design directory and the labview\examples\Adaptive Filters directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Digital Filter Design Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2005–2021 National Instruments Corporation. All rights reserved.
    375119H-01
    GMT+8, 2026-2-24 22:15
