查看: 3718|回复: 0
[LV工具模块] LabVIEW 2021 Datalogging and Supervisory Control Module Runtime System x64Win10 32bitEng LabVIEW2021数据记录与监控模块运行时系统DSC2021RTS
    4 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-8-26 15:23:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    LabVIEW 2021数据记录与监控模块运行时系统
    发布日期
    2021/8/13
    包含的版本
    2021Runtime System
    受支持的操作系统
    语言
    English
    32ENG RTS
    文件大小: 1128542208 字节 (1.05 GB)
    修改日期: 2021-08-12 05:43
    MD5: 7d17917775a2b301482f65d8b1e003da
    SHA1: a3fbf9e71cdb4a7c9f47796e04bba2216c63bbbb
    SHA256: de8ea2982f76021983f9fec2f0649f3c2fbe5602c61a568c2e055277f1ec7bc8
    CRC32: 80ce3bf1
    请注册视觉论坛会员登录后购买附件下载查看
    DSC2021-X86-RTS.txt (720 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2021 Datalogging and Supervisory Control Runtime Readme
    July 2021
    This file contains installation instructions and compatibility information for LabVIEW Datalogging and Supervisory Control (DSC) Runtime.
    • Manuals: New features, behavior changes, and other documentation
    The LabVIEW DSC Runtime allows you to run applications built with LabVIEW, the DSC Module, and the LabVIEW Application Builder on a computer without the DSC Module installed. The DSC Runtime contains components that enable the DSC Module features in the built applications.
    The DSC Runtime has the following requirements:
    • Depending on the components you choose to install, the computer must have the following amount of free disk space:
      • 1.0 GB free disk space if you install all components of the DSC Runtime except the Shared Variable Logging Support component
      • 2.5 GB free disk space if you install all components of the DSC Runtime
    • At least 512 MB of RAM
    The DSC Runtime supports the following operating systems:
    • Windows 10 (version 1909)
    NI installs the DSC Runtime using NI Package Manager. If you do not already have NI software installed, the DSC Runtime installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the DSC Runtime by using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    Note  The NI OPC Servers application installed with the DSC Runtime provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    SQL Server Support
    The LabVIEW 2021 DSC Module requires Microsoft SQL Server 2012 Service Pack 4 (SP4) Express. This component is installed by default when you install the DSC Module.
    To install the LabVIEW 2020 DSC Module on a machine that has a previous version of the DSC Module installed, you need to upgrade the Microsoft SQL Server version from 2008 R2 to 2012 SP4 Express. Because upgrading the Microsoft SQL Server affects the Citadel database, you must backup your Citadel data before upgrading. Refer to the Archiving Citadel Data topic in the LabVIEW Help for detailed information about archiving the Citadel database.
    The Advanced Signal Processing Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2000–2021 National Instruments Corporation. All rights reserved.
    375311H-01
    GMT+8, 2025-12-5 13:10
