查看: 5452|回复: 0
[LV工具模块] LabVIEW 2021 MathScript Module x64Win10 32bitChn LabVIEW2021文本数学脚本模块32位中文版MSRT2021
    发表于 2021-8-26 16:02:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。自2016MSRT开始,WINDOWS系统LabVIEW增加64位版本MSRT。自2019MSRT开始,增加在线安装方式,同时增加中文、法语、德语、日语、韩语等多国语言版本。
    LabVIEW 2021 MathScript模块
    发布日期
    2021/8/13
    包含的版本
    2021
    受支持的操作系统
    语言
    中文
    Win32Chn
    文件大小: 567306240 字节 (541.03 MB)
    修改日期: 2021-08-12 05:42
    MD5: f9c18d4a63285568c5745d44fa285656
    SHA1: 29db52679211abbce45ce68b4ce93a2559c0bb1e
    SHA256: 0f5a801aa53530bc57bbf4ef8d269203e4d5ac5275e764defb3a78508e28b20b
    CRC32: 490bcd89
    请登录视觉论坛会员购买附件下载查看
    Mathscript2021X86Chn.txt (671 Bytes, 下载次数: 5, 售价: 10 圆)
    LabVIEW 2021 MathScript Module Readme
    July 2021
    This file contains installation instructions and compatibility information for LabVIEW MathScript Module.
    • Manuals: New features, behavior changes, and other documentation
    Note  LabVIEW MathScript is no longer recommended for new designs. Visit ni.com/migratemathscript for more information and recommended alternatives.
    Limitations on Windows (64-bit), macOS, and Linux
    LabVIEW MathScript is a text-based environment you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    In addition to the system requirements for the LabVIEW Development System, the MathScript Module has the following requirements:
    • LabVIEW 2021 Full or Professional Development System
    The MathScript Module supports the following operating systems:
    WindowsWindows 10 (version 1909)
    Windows Server 2016
    macOSmacOS 11 (x86_64 only) or 10.15
    LinuxopenSUSE LEAP 15.0
    openSUSE LEAP 15.1
    Red Hat Enterprise Linux 7
    Red Hat Enterprise Linux 8
    CentOS 7
    CentOS 8
    Note  The LabVIEW 2021 MathScript Module for Linux requires a 64-bit distribution and does not support 32-bit applications.
    The MathScript Module on Windows (64-bit), macOS, and Linux does not support the libraries class of MathScript Module functions.
    (Windows)
    NI installs the MathScript Module using NI Package Manager. If you do not already have NI software installed, the MathScript Module installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the MathScript Module using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    (macOS, Linux)
    You can install the MathScript Module using the LabVIEW media for macOS/Linux. Refer to the LabVIEW Media Readme for macOS/Linux for instructions on how to install the MathScript Module.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the MathScript Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the MathScript Module are located in the labview\examples\MathScript directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Advanced Signal Processing Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2009–2021 National Instruments Corporation. All rights reserved.
    375325H-01
    GMT+8, 2025-12-8 07:36
