查看: 3679|回复: 0
[LV工具模块] LabVIEW 2021 Unit Test Framework Toolkit x64Win10 32bitEng LabVIEW2021单元测试框架工具包UTF2021
    前天 16:03
    发表于 2021-8-27 17:47:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    UTF2016版开始,支持64位的LabVIEW,即有UTF2016-64bit的版本。
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    LabVIEW 2021单元测试架构工具包
    发布日期
    2021/8/13
    包含的版本
    2021
    受支持的操作系统
    语言
    English
    校验和
    32ENG
    文件大小: 369917952 字节 (352.78 MB)
    修改日期: 2021-08-12 05:42
    MD5: 33d56ce114fffd09d9c73dfd378a24ae
    SHA1: ee3d1eae991f4d889b24b2428c233c373268888f
    SHA256: 252ec84e73213534d5dc192d010468feeb705c15066b643368d84b6f58a93381
    CRC32: 6a1a886f
    UTF2021.txt (708 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW 2021 Unit Test Framework Toolkit Readme
    July 2021
    This file contains installation instructions and compatibility information for NI LabVIEW 2021 Unit Test Framework Toolkit.
    • Manuals: New features, behavior changes, and other documentation
    The Unit Test Framework Toolkit provides interactive tools to create, configure, manage, and execute tests that check VIs for functional correctness.
    In addition to the system requirements for the LabVIEW Development System, LabVIEW 2021 Unit Test Framework Toolkit has the following requirements:
    • LabVIEW 2021 Base, Full, or Professional Development System
    • At least 64 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2021.
    LabVIEW 2021 Unit Test Framework Toolkit supports the following operating systems:
    Download the LabVIEW Unit Test Framework Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate LabVIEW Unit Test Framework Toolkit. For more information on LabVIEW Unit Test Framework Toolkit activation, refer to NI Software Activation.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Unit Test Framework Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Unit Test Framework folder to access the example. You also can find the examples for the Unit Test Framework Toolkit in the labview\examples\Unit Test Framework directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW Unit Test Framework Toolkit no longer supports Windows 7/8.1, Windows Server 2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2008–2021 National Instruments Corporation. All rights reserved.
    375338H-01
    GMT+8, 2026-2-25 02:42
