查看: 2823|回复: 0
[NI软件套件] NI Semiconductor Test System Development Software 20.0.0 x64Win10 64bitEng NI-STS半导体测试系统开发软件20.0.0
    9 小时前
  • 签到天数: 3537 天
    连续签到: 7 天
    发表于 2021-9-1 14:33:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    半导体测试系统开发软件
    半导体测试系统软件可帮助您开发、执行、调试和部署半导体测试系统软件(STS)应用。
    半导体测试系统开发软件为STS提供了一套测试管理和代码模块开发工具。使用该软件,您可以定义引脚图、配置数字pattern、创建测试代码模块、自定义操作界面、优化并行测试效率(PTE)、以标准测试数据格式(STDF)报告数据,以及维护和校准测试系统。
    STS20.0.0
    发布日期
    2021/7/21包含版本
    20.0.0
    受支持的操作系统
    语言
    English
    校验和
    文件大小: 25552226304 字节 (23.80 GB)
    修改日期: 2021-07-21 22:14
    MD5: 4027415174c9272ef25a20ad8cdc7a1a(官方正确)
    SHA1: c7d45ccc107d0f75e6998d1a8e1c168e6a4be63a
    SHA256: 84b8f6ae22fe61f6b246fea7b73e894bda4c8cdf9443c460fd7d1de34024b32e
    CRC32: 448336c6
    STS20.0.0.txt (637 Bytes, 下载次数: 0, 售价: 30 元)
    STS Development Software 20.0 Readme
    April 2021
    This file contains important information about STS Development Software 20.0, including installation instructions and new features. STS Development Software is a collection of NI software for developing, executing, and debugging test programs on a non-STS computer.
    Included Components
    Supported Controllers and Operating Systems
    Installation Considerations
    What's Changed
    Known Issues and Bug Fixes
    STS Development Software Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Included Components
    STS Development Software 20.0 includes the following major components:
    • STS Development Software 20.0
    • TestStand 2020
    • NI TestStand Semiconductor Module™ 2020 (TSM)
    • LabVIEW 2020 SP1
    • LabVIEW 2020 SP1 Run-Time Engine
    • NI-Digital Pattern Driver 20.6.1
    • NI-DCPower 20.7.0
    • NI-SCOPE 20.7.0
    • NI-Sync 20.0.0
    • NI-RFPM 20.6.0
    • NI RFmx 20.7.0
    • NI-RFSA 20.7.0
    • NI-RFSG 20.7.0
    • STS Auxiliary Mixed Signal Tools 20.0.0
    • STS Auxiliary RF Tools 20.0.0
    • TSM RF Steps 20.0.0
    • STS Handler and Prober Drivers 20.0.0
    • STS Maintenance Software 20.0.0
    STS Development Software 20.0 has the following requirements:
    • 2.3 GHz 8-Core Intel Xeon processor (or equivalent)
    • At least 100 GB of disk space
    • At least 12 GB RAM (NI recommends 24 GB RAM)
    STS Development Software 20.0 supports the following controllers:
    • PXIe-8880
    • PXIe-8881
    STS Development Software 20.0 supports the following operating system:
    • Windows 10 IoT Enterprise LTSC 2019 (64-bit)
    Note  STS Development Software 20.0 does not support certain versions of Windows 10. Refer to Editions of Windows 10 Supported by NI Software for more information.
    Note  Refer to STS Development Software Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI offers two installation paths for STS software—installing STS Software through the STS Version Selector and installing STS Development Software through NI Package Manager.
    NI recommends installing STS Development Software through NI Package Manager if you are using a non-STS computer and do not need to switch among versions of STS software. Use STS Development Software 20.0 to develop, run, and debug STS test programs on a non-STS computer without access to NI instruments. When test program development is complete, transfer the test program to an STS from which you will deploy the test program into a production environment.
    Note  If you install STS Development Software 20.0 through NI Package Manager, you cannot downgrade your software version. NI does not recommend updating components of STS Development Software on the non-STS computer. The set of software you use to develop an STS test program must match the set of software on the STS from which you will deploy the test program.
    If you need to switch among versions of STS software on a non-STS computer, install through the STS Version Selector. If you used a mechanism other than the STS Version Selector 19.0.0 or later to install any NI software on the STS or non-STS computer, you must reimage the computer before installing the latest version of the STS Version Selector. Refer to the STS Software 20.0 Readme for more information about installing STS Software through the STS Version Selector.
    Download the STS Development Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate STS Development Software. For more information on STS Development Software activation, refer to NI Software Activation.
    • You must restart the computer after you activate an STS software version.
    If you are using NI .NET Class Libraries, .NET Framework 4.0 (minimum) is required. The NI .NET Class Libraries can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    For information about versions of the .NET Framework and the drivers each supports, refer to NI .NET Support.
    Spectre and Meltdown
    Refer to Meltdown and Spectre - Processor Speculative Execution Vulnerabilities (Windows) for more information about addressing Spectre and Meltdown issues.
    STS Development Software 20.0 adds the following major new features:
    New Hardware Support
    • PXIe-8881 controller—Added support for NI's new high-performance 8-Core Intel Xeon-based embedded controller.
    • SCT SC2250 HMU—Added support for harmonic measurements through the STS RF subsystem (6 GHz STS for 5G configuration).
    • PXIe-5820—Added support for envelope tracking and baseband RF I/Q.
    • PXIe-6594—Added support for high-speed serial instrument, up to 16.3 Gbps.
    • PXIe-4139 (40W)—Added support for high power (40W/10 A, Pulsed) SMU version.
    • PXIe-5841 with STS-5531—Added support for the PXIe-5841 Vector Signal Transceiver with STS-5531 as a 6 GHz, 1 GHz bandwidth, STS RF subsystem.
    • PXIe-5831 + PXIe-5841—Added support for the PXIe-5841 as a 44 GHz, 1 GHz bandwidth, STS mmWave subsystem with lower frequency IF.
    New and Improved Test Program Development and Debugging
      • TSM Sequence Call Step Type—Enables creation of customizable, reusable multistep IP parameter sequences.
      • TSM Relay Configuration Step—Enables naming and recall of custom system relay configurations.
      • NI-DCPower channel expansion—Enables aggregation of multiple SMU instrument sessions into a single session.
      • NI-DCPower compliance alarms—Alerts the user when the state of an NI-DCPower instrument exceeds programmed limits.
      • High-site-count operator interface—Provides enhanced operator interface (OI) options with optimizations for high-site-count DUT applications.
      • Automated test program generation from a Digital Pattern Editor Project.
    • Digital Pattern Editor
      • Automated DUT bring up/shutdown—Enables automation of DUT power sequencing and initialization patterns.
      • Interactive continuity check—Verifies measurement connection paths to the DUT.
      • Software-timed power sequencing—Provides user-defined DC power (DUT power) and digital pin power sequencing.
      • Filtering items in the System View—User interface improvements with advanced filtering options for high-pin-count DUTs and high-site-count DUT applications.
      • DUT register debug view—Quickly view the current DUT state and edit DUT registers with I2C, SPI, and MIPI RFFE protocols.
    • RF Steps and Tools
      • .NET C# RF measurement steps and debugging tools for 5G NR, WiFi-6E, and mmWave applications
      • Harmonics measurement support (HMU) through the STS RF subsystem (6 GHz STS for 5G configuration)
      • S-Parameters measurement support for the following STS RF subsystem configurations (up to 8 GHz): 6 GHz STS for 5G and 8 GHz STS for WiFi-6E
      • Noise figure measurement step (Y-factor method with synthetic noise source)
      • Handler and prober driver support:
        • (Improved) Accretech GPIB Prober Driver—Communicates with supported GPIB probers during test execution.
        • (Improved) General GPIB Handler Driver—Communicates with supported GPIB handlers during test execution.
        • (Improved) TEL GPIB Prober Driver—Communicates with supported TEL probers during test execution.
        • (New) General TTL Handler Driver—Communicates with supported TTL handlers during test execution.
    What's Changed
    STS Development Software 20.0 includes updates to the following major components.
    Note  This is not an exhaustive list of updated products in STS Development Software.
    Previous Version
    Current Version
    TestStand 2019 f2TestStand 2020
    TSM 2019 f3TSM 2020
    LabVIEW 2019 f2LabVIEW 2020 SP1
    LabVIEW 2019 SP1 f1 RTELabVIEW 2020 SP1 RTE
    STS Maintenance Software 19.5.0STS Maintenance Software 20.0.0
    NI-Digital Pattern Driver 19.0.1NI-Digital Pattern Driver 20.6.1
    NI-DCPower 20.0.0NI-DCPower 20.7.0
    NI-SCOPE 19.1.1NI-SCOPE 20.7.0
    NI-Sync 19.5.0NI-Sync 20.0.0
    NI-RFPM 19.0.2NI-RFPM 20.6.0
    NI RFmx 20.0.1NI RFmx 20.7.0
    NI-RFSA 19.6.0NI-RFSA 20.7.0
    NI-RFSG 19.6.0NI-RFSG 20.7.0
    STS Development Software 20.0 Auxiliary Components
    STS Development Software 20.0 changes the following auxiliary components.
    Note  This is not an exhaustive list of changed auxiliary components in STS Development Software.
    Previous Version
    Renamed/Current Version
    TSM RF Steps 19.5.0TSM RF Steps 20.0.0
    STS Auxiliary RF Tools 19.5.0STS Auxiliary RF Tools 20.0.0
    STS Auxiliary Mixed Signal Tools 19.5.0STS Auxiliary Mixed Signal Tools 20.0.0
    STS Handler and Prober Drivers 19.5.0STS Handler and Prober Drivers 20.0.0
    You can access the known issues list and bug fixes list online. Refer to the private NI STS Technical Support Community, located at https://forums.ni.com/t5/NI-STS-Technical-Support/gp-p/5300, for an up-to-date list of known issues and bug fixes in STS Development Software 20.0. You can work directly with NI Services personnel contracted on your project to request to be added to the NI STS Technical Support Community.
    Select Start»National Instruments»STS Help to access the STS Help, which includes information about STS Development Software 20.0.
    If you open help files directly from the <;Program Files>\National Instruments\STS\Documentation\Help directory, NI recommends that you open STSDocumentation.chm first because this file is a collection of help files and provides a complete table of contents and index.
    STS manuals are available as PDFs in the <;Program Files>\National Instruments\STS\Documentation\Manuals directory. You must have Adobe Acrobat Reader installed to view the PDFs.
    STS Development Software will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2017–2021 National Instruments Corporation. All rights reserved.
    378143D-01
    GMT+8, 2025-5-12 17:19
