查看: 2947|回复: 0
[NI驱动程序] NI IVI Compliance Package 21.0 x64Win10 32/64bitEng NI IVI合规软件包下载ICP21.0
    9 小时前
    发表于 2021-9-2 14:35:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    IVI合规软件包
    IVI合规软件包ICP21.0发布日期
    2021/8/13
    包含的版本
    21.0.0
    受支持的操作系统
    语言
    English
    文件大小: 594935808 字节 (567.38 MB)
    修改日期: 2021-08-04 09:31
    MD5: 78b4613e65ab63518d2921ab99d1991c
    SHA1: 76a1e8f22047058d2bf14c1336ff5c49999a465e
    SHA256: c458dcc1929a8cb7b530817c4dff43a2526789d8714f52a0c389049c30abbc33
    CRC32: 5ef4bf7b
    ICP21.0.txt (559 Bytes, 下载次数: 0, 售价: 10 圆)
    NI IVI Compliance Package 21.0 Readme
    July 2021
    This file contains important information about the IVI Compliance Package (ICP), including installation instructions, new features, a list of bugs fixed for ICP 21.0, and known issues.
    • IVI Compliance Package Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • IVI Compliance Package Manuals: New features, behavior changes, and other documentation
    Installed Components
    Uninstall Considerations
    Known Incompatibilities
    The IVI Compliance Package is a software package that contains the IVI class drivers and support libraries necessary to develop and use applications that leverage IVI instrument interchangeability. The IVI Compliance Package also is based on and is compliant with the latest version of the instrument programming specifications defined by the IVI Foundation. You can use the IVI class drivers in the IVI Compliance Package with IVI specific drivers.
    IVI class drivers implement functions and attributes for controlling an instrument within a specified class, as defined by the IVI Foundation. The IVI Compliance Package provides IVI class drivers for the following specifications:
    • IviACPwr
    • IviCounter
    • IviDCPwr
    • IviDigitizer
    • IviDmm
    • IviDownconverter
    • IviFgen
    • IviPwrMeter
    • IviRFSigGen
    • IviScope
    • IviSpecAn
    • IviSwtch
    • IviUpconverter
    IVI specific drivers are drivers for the most popular instruments from all of the currently defined IVI Foundation classes and from the largest instrument manufacturers including National Instruments, Keysight Technologies, and Tektronix. You can create IVI specific drivers yourself, or download them from ni.com/idnet.
    Depending on the software support you select when you install ICP 21.0, the installation includes one or more of the following components:
    • IVI class drivers
    • IVI class driver wrappers for LabVIEW 2018, 2019, 2020, and 2021
    • IVI class driver wrappers for LabVIEW NXG 5.0
    • IVI.NET adapters
    • IVI Shared Components 2.6.1
    • IVI.NET Shared Components 1.4.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.7 and later
    • Documentation
    ICP supports the following operating systems:
    • Red Hat Enterprise Linux 8
    • Red Hat Enterprise Linux 7
    • CentOS 8
    • CentOS 7
    • openSUSE Leap 15.2
    • openSUSE Leap 15.1
    • Ubuntu 20.04
    • Ubuntu 18.04
    Note  ICP no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. ICP 21.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use ICP 21.0 to an unsupported OS. Additionally, after installing ICP 21.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    ICP supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by ICP
    LabVIEW2018, 2019, 2020, 2021, and NXG 5.0, 5.1
    NI LabWindows™/CVI™2017, 2019, 2020
    Download the IVI Comliance Package installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    To install the stand-alone, web-only version of ICP, complete the following steps:
    • Download the ICP 21.0 self-extracting archive file from http://www.ni.com/downloads/drivers/ by searching for IVI Compliance Package.
    • Double-click the self-extracting archive file to launch the installer.
    Installing ICP for LabVIEW NXG
    You can install ICP at the same time that you install LabVIEW NXG. In Package Manager, select LabVIEW NXG and Drivers. Then select IVI Compliance Package from the list of drivers available to install.
    Installation Notes
    • The ICP 21.0 stand-alone, web-only distribution does not install NI I/O Trace (formerly known as NI-Spy) or MAX. You can install NI I/O Trace and MAX using several other National Instruments products, including the NI Device Drivers media.
    • The installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    • ICP 3.2 and later include IVI-COM adapters, which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    • ICP 19.0 and later includes IVI.NET adapters, which enable users to use IVI-C and IVI.NET specific drivers interchangeably in the same application.
    • ICP 4.5 and later installs alternate FP and SUB files for the IviFgen class driver in order to support setting 64-bit integer attributes. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    After you uninstall ICP 21.0, the IVI Shared Components remain on the system. To remove the remaining components, right-click IVI Shared Components 2.6.1 and select Uninstall/Change.
    If you installed ICP 21.0 as part of another distribution that depends on ICP 21.0, you cannot uninstall ICP 21.0 without uninstalling the dependent product.
    This release includes the following new features:
    • Added support for LabVIEW 2021 and LabVIEW NXG 5.0
    • In ICP 19.5 and IVI Shared Components 2.6 or later, the installers no longer unlock the IVI Foundation directory. Therefore, you no longer can modify the files installed under the IVI Foundation directory.
    The following sections detail considerations for using LabVIEW NXG 5.0 with ICP 21.0.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    ©1999–2021 National Instruments Corporation. All rights reserved.
    376942F-01
    GMT+8, 2025-12-8 19:07
