NI-SCOPE 21.0 x64Win10 32/64bitEng/Jpn NI示波器驱动程序SCOPE21.0
NI-SCOPE
NI-SCOPE为使用NI示波器产品的客户提供支持。
NI-SCOPE 21.0
发布日期
2021/8/13
包含的版本
21.0.0
受支持的操作系统
语言
英文,日语
程序位数
32/64位
校验和
文件大小: 2909929472 字节 (2.71 GB)
修改日期: 2021-08-04 10:31
MD5: 3d7ba44eef37e826f87c7bb9a29ca5b9
SHA1: d0225ddf743ff1bf606f11eb271cb3f623b70fc2
SHA256: fbff77c4514c2e855bfd2047cbf3849723473a44de33fe39ad573a471b6bde6b
CRC32: afdc2a22
NI-Scope21.0.txt
(541 Bytes, 下载次数: 4, 售价: 10 圆)
NI-SCOPE 21.0 ReadmeJuly 2021 This file contains installation instructions and compatibility information for NI-SCOPE. You can find more release information on ni.com. - NI-SCOPE Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- NI-SCOPE Manuals: New features, behavior changes, and other documentation
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Supported Hardware Accessing the Help Finding Examples LabVIEW NXG Support and Considerations Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Unsupported Windows Operating Systems Legal Information OverviewNI-SCOPE is an NI instrument driver that enables you to implement multirecord acquisition, continuous acquisition, multiboard synchronization, more than 50 measurement and analysis functions, and the functionality of traditional oscilloscopes. NI-SCOPE is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the oscilloscope and includes an interactive soft front panel and examples. System RequirementsNI-SCOPE 21.0 has the following requirements: - 1 GHz or faster 64-bit (x64) processor
- 2 GB RAM (64-bit)
- If you are running your application on an RT target, at least 128 MB of memory
Supported Operating SystemsNI-SCOPE 21.0 supports the following operating systems: - Windows 10
- Windows Server 2016
- Windows Server 2019
- NI Linux® Real-Time1
1 This operating system is not supported for the following features: - Autopopulation of resource names in LabVIEW 2020 and earlier
- Test panels as accessible from Measurement & Automation Explorer (MAX)
NI Software Drops Support for Phar Lap ETS Real-Time Operating System in 2022NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022 may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi. Note In 2016, NI-SCOPE dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SCOPE will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SCOPE to an unsupported OS. Additionally, after installing NI-SCOPE 21.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?. Application Software SupportNI-SCOPE supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by NI-SCOPE | | LabVIEW | 2018, 2019, 2020, and 2021 | | LabVIEW Real-Time Module1 | 2018, 2019, 2020, and 2021 | | LabVIEW NXG | 5.1 | | LabWindows™/CVI™ | 2013 SP1 or later | | LabWindows/CVI Real-Time Module3 | 2013 SP1 or later |
1No support for the PXIe-5110/5111/5113, the PXIe-5163, or the PXIe-5164 and PXIe-517x reconfigurable oscilloscopes. Microsoft Visual Studio SupportIf you are using the NI-SCOPE .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SCOPE .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5. To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-SCOPE installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support. Installation InstructionsNI installs NI-SCOPE using NI Package Manager. If you do not already have NI software installed, NI-SCOPE installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. NI-SCOPE is available for download from ni.com/downloads/drivers. NI-SCOPE installs NI-DAQmx if it is not already installed or if an earlier version of NI-DAQmx is installed. NI-DAQmx support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQmx is the device driver. Upgrading from a Previous Version of NI-SCOPE- From NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
- From NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
Uninstalling NI-SCOPEAs part of the NI-SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages: - NI-DAQmx
- NI Measurement & Automation Explorer
- NI Hierarchical Waveform Storage
- NI I/O Trace
Notice Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Supported HardwareThe following table details the hardware models supported in NI-SCOPE 21.0. Hardware Device | Supported Under Windows 10 (64-bit)1 | NI-DAQmx-Based Oscilloscopes | | PXI/PXIe/PCI-5105 | Yes | | PXI/PXIe/PCI-5114 | Yes | | PXI/PXIe/PCI-5122 | Yes | | PXI/PCI-5124 | Yes | | USB-5132/5133 | Yes | | PXI/PCI-5142 | Yes | | PXI/PCI-5152 | Yes | | PXI/PCI-5153 | Yes | | PXI/PCI-5154 | Yes | | PXIe-5160/5162 | Yes | | PXIe-5185/5186 | Yes | | PXIe-5622 | Yes | | PXI-5900 | Yes | | PXI/PCI-5922 | Yes | SDI-Based Oscilloscopes | | PXIe-5110 | Yes | | PXIe-5111 | Yes | | PXIe-5113 | Yes | 516x Oscilloscopes | | PXIe-5163 | Yes | | PXIe-5164 | Yes | 517x Oscilloscopes | | PXIe-5170 | Yes | | PXIe-5171 | Yes | | PXIe-5172 | Yes | 1When you install NI-SCOPE 21.0 and later, InstrumentStudio is installed instead of the SCOPE soft front panel. Use InstrumentStudio to monitor and control your oscilloscope.
Device-specific information about these modules is included in the NI High-Speed Digitizers Help. Accessing the Help- For help with the NI-SCOPE driver, refer to the NI High-Speed Digitizers Help, accessible by selecting Help»NI High-Speed Digitzers Help.
- For help with InstrumentStudio, used to configure and monitor NI-SCOPE devices, refer to the InstrumentStudio help at ni.com.
Finding ExamplesNI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples. For LabVIEW examples, select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SCOPE are located in the labview\examples\instr\niScope directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using LabVIEW NXG with NI-SCOPE. LabVIEW NXG Hardware SupportThe following table details the hardware models supported in NI-SCOPE with LabVIEW NXG. [tr][/tr]
Hardware Module | Supported Under Windows 10 | NI-DAQmx-Based Oscilloscopes | | PXI/PXIe/PCI-5105 | Yes | | PXI/PXIe/PCI-5114 | Yes | | PXI/PXIe/PCI-5122 | Yes | | PXI/PCI-5124 | Yes | | USB-5132/5133 | Yes | | PXI/PCI-5142 | Yes | | PXI/PCI-5152 | Yes | | PXI/PCI-5153 | Yes | | PXI/PCI-5154 | Yes | | PXIe-5160/5162 | Yes | | PXIe-5185/5186 | Yes | | PXIe-5622 | Yes | | PXI-5900 | Yes | | PXI/PCI-5922 | Yes | SDI-Based Oscilloscopes | | PXIe-51101 | Yes | | PXIe-51111 | Yes | | PXIe-51131 | Yes | 516x Oscilloscopes | | PXIe-51631 | Yes | | PXIe-51641 | Yes | 517x Oscilloscopes | | PXIe-51701 | Yes | | PXIe-51711 | Yes | | PXIe-51721 | Yes | | 1External calibration of this module is not supported in LabVIEW NXG. | LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Unsupported Windows Operating SystemsNI-SCOPE no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport. Legal InformationCopyright © 1999–2021 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 375360AC-01
