查看: 2621|回复: 0
[NI驱动程序] NI-Sync 21.0 x64Win10 32/64bitEng NI PXI同步模块及实时控制器驱动程序下载SYNC21.0
    14 小时前
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2021-9-2 15:32:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Sync用于支持用户使用PXI同步模块或任何运行实时操作系统的NI控制器。
    NI-Sync是一个NI仪器驱动程序,用于配置系统定时和同步,包括基于信号的同步和直接使用时钟。您还可以使用时间协议(如IEEE 1588标准,IEEE 802.1AS标准,IRIG或GPS)执行基于时间的同步,作为时间戳的时间参考或执行同步时钟和触发生成。NI-Sync支持PXI同步模块和实时PXI、CompactDAQ和CompactRIO控制器以及紧凑视觉系统和工业控制器。NI-Sync中还包括高级实用程序及范例,可帮助用户更轻松地创建应用程序。
    NI-Sync 21.0
    发布日期
    2021/8/13
    包含的版本
    21.0.0
    受支持的操作系统
    语言
    English
    校验和
    文件大小: 2150963200 字节 (2.00 GB)
    修改日期: 2021-08-04 10:18
    MD5: 2d3d9f8832825bf037d88a452548d7bb
    SHA1: 8fe2adf9adf5b5b7ab336a74658458542da44a7c
    SHA256: 4472886d0aa3dabe3c548fec212397aaa16c554ca6aaa671dc163b4abf63c66f
    CRC32: da7a37b5
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI-SYNC21.0.txt (537 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Sync 21.0 Readme
    July 2021
    This file contains installation instructions and compatibility information for NI-Sync 21.0.
    • NI-Sync Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Sync Manuals: New features, behavior changes, and other documentation
    NI-Sync provides support for customers using NI timing and synchronization hardware modules.
    NI-Sync 21.0 supports the following operating systems:
    • NI Real-Time Phar Lap ETS
    • Linux Real-Time (RT)1, 2, 3
    1 Certain features are unavailable on Linux RT targets. Refer to NI-Sync Limitations on Linux Desktop and NI Linux Real-Time for more information about target support and functionality.
    2 IEEE 1588-2008 protocol instances on ARM-based targets running NI Linux Real-Time are configured to be "slave only" by default. For more information about this issue, refer to Why Doesn't My ARM-Based Linux Real-Time Target Act as a 1588 Master?.
    3 Monitoring and configuring of time-based synchronization on embedded Phar Lap targets is not supported in the NI-Sync API. Use the NI-TimeSync property node installed with NI-Sync for time-based synchronization on these targets.
    Note  NI-Sync 21.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Sync 21.0 to an unsupported OS. Additionally, after installing NI-Sync 21.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-Sync 21.0 supports the following application software versions, including service packs.
    Versions Supported by NI-Sync
    LabVIEW2018 SP1, 2019 SP1, 2020 SP1, 2021
    LabVIEW Real-Time Module2018, 2019, 2020, 2021
    LabWindows/CVI2017, 2019, 2020
    LabVIEW NXG5.0, 5.1
    Download the NI-Sync 21.0 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The NI-Sync 21.0 release adds the following features:
    • Support for LabVIEW 2021.
    • Improved support for the PXIe-6674T on Linux Real-Time.
    • Support for GPS Mobile Mode for the PXI-6683 and PXI-6683H on Linux Real-Time.
    • Support for Pulse Per Second (PPS) Time Synchronization for the PXI-6683 and PXI-6683H on Linux Real-Time.
    • Improved support for System Configuration and NI-Sync properties on Linux RT.
    • Support for MAX test panels for the PXIe-6674T on Linux RT.
    • Partial support for MAX test panels for the PXI-6683 and PXI-6683H on Linux RT.
    NI-Sync 21.0 supports the following devices:
    Signal-Based Modules
    • PXI-6651
    • PXI-6652
    • PXI-6653
    • PXIe-6672
    • PXIe-6674
    • PXIe-6674T
    Time-Based Modules
    • PCI-1588
    • PXI-6682
    • PXI-6682H
    • PXI-6683
    • PXI-6683H
    Controller Support for Time-Based Synchronization
    The following embedded controller types support time-based synchronization with NI-Sync 21.0:
    • PXI(e)4
    • CompactRIO
    • CompactDAQ
    • Industrial Controller (IC)
    • Compact Vision Systems
    4 Time-based synchronization is fully supported on Phar Lap PXI(e) controllers. Time-based synchronization is supported on NI Linux Real-Time PXIe controllers only if the system includes a PXI-6683 Series timing and synchronization module.
    Refer to NI-Sync Help, accessible from Help»LabVIEW Help..., for information about using NI-Sync with LabVIEW.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-Sync are located in the \examples\instr\niSync directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • For signal-based examples that use clocks and triggers directly, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Signal-Based.
    • For time-based examples that use time references such as IEEE 1588-2008 or GPS as a basis for synchronization, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Time-Based.
    The following sections detail considerations for using LabVIEW NXG with NI-Sync 21.0.
    • Operating system—Only 64-bit operating systems are supported.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-Sync no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    NI Software Drops Support for Phar Lap ETS Real-Time Operating System in 2022.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    ©2003-2021 National Instruments. All rights reserved.
    375085T-01
    GMT+8, 2026-1-7 23:37
