查看: 3993|回复: 1
[RTE运行引擎] NI-VISA 21.0 Driver Runtime MacOs64Eng 美国国家仪器虚拟仪器软件架构NI-VISA21.0 MAC运行版驱动下载
  • 签到天数: 3810 天
    发表于 2021-9-3 10:45:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    注意,NI-VISA从VISA14.0版开始,使用年代名称来命名,即14代表的是2014年,不再延续之前的5.X之类的名称。而在VISA5.4.1及之前的版本,则是使用数字版本来命名的,5并不是代表着2005年之类的。
    NI-VISA 21.0
    发布日期
    21-8-3
    包含的版本
    21.0.0RTE
    受支持的操作系统
    Mac OS
    语言
    English
    校验和
    文件大小: 6817968 字节 (6.50 MB)
    修改日期: 2021-07-20 22:32
    MD5: 1094bebebb1609e8d951278e1abc9f93
    SHA1: baf1a30a55fce90ec5186f4da9e2f6ac9c8c94a2
    SHA256: 83ea39d49aa20e317e9afa3aa25b894778abb582d3f653c49251ccb59d30bc4c
    CRC32: beaba8af
    请注册视觉论坛会员登录后购买附件下载查看,充值请备注论坛用户名UID或联系在线客服
    VISA21.0MACrte.txt (539 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-VISA 21.0 for macOS Readme
    June 2021
    This file contains installation instructions and compatibility information for NI-VISA 21.0.
    • NI-VISA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-VISA Manuals: New features, behavior changes, and other documentation
    Contents
    NI-VISA is the NI implementation of the Virtual Instrument Software Architecture (VISA), a standard for configuring, programming, and troubleshooting instrumentation systems comprising GPIB, VXI, PXI, Serial, Ethernet, and/or USB interfaces.
    NI-VISA 21.0 for macOS supports the following platforms:
    • macOS 11.x
    • macOS 10.15.x
    Note  The online version of this readme supersedes the readme provided with the installation media to contain an updated list of supported macOS platforms.
    NI-VISA for macOS currently supports the following resource types and utilities:
    • GPIB
    • Serial
    • PXI/PCI
    • TCPIP
    • Remote Client
    • Remote Server
    • ENET Serial
    • USB
    • VISA Interactive Control
    • NI I/O Trace
    Note  NI-VISA for macOS supports only 64-bit applications.
    The following table lists the NI application software versions supported by NI-VISA:
    Versions Supported by NI-VISA
    NI LabVIEW2018, 2019, 2020, 2021
    Installation InstructionsLabVIEW Installation
    You can install all of your LabVIEW products—including NI-VISA—using the LabVIEW 2021 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    To request additional LabVIEW Platform media, visit ni.com/r/media.
    Installed Files and Paths
    There are three main locations where NI-VISA installs files.
    • The local /Library/Frameworks folder contains the VISA.framework folder. This folder contains all needed headers and supporting Passport libraries that NI-VISA uses.
    • In the local /Applications/National Instruments folder, there is an NI-VISA folder. This folder includes the NI-VISA Help, as well as several groups of C examples using NI-VISA. This NI-VISA folder also includes a graphical utility called NI-VISA Configuration to configure VISA options and the VISA Interactive Control (VISAIC).
    • Finally, the /Library/Preferences folder contains an NIvisa folder with .ini files. These files are used for NI-VISA settings and status codes.
    New FeaturesNI-VISA 15.0
    Added support for NI MAX.
    NI-VISA 14.0
    Added support for 64-bit versions of LabVIEW.
    Added support for the System Configuration API.
    Added support for viGpibControlREN on TCPIP resources that use the VXI-11 protocol.
    NI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    NI-VISA 5.2
    Improved performance of viWrite for a HiSLIP resource.
    NI-VISA 5.1.2
    Added support for 64-bit kernel for OS X.
    Added OS X 10.7 support.
    NI-VISA 5.1
    Added support for HiSLIP.
    Added the VISA Interactive Control (VISAIC) stand-alone application. Refer to the NI-VISA Help for more information on the updates to VISAIC.
    NI-VISA 5.0
    Added OS X 10.6 support.
    Added support for 64-bit formatted I/O.
    Dropped GPIB-VXI support.
    NI-VISA 4.5
    Added automatic detection of LXI (TCP/IP) devices that support the mDNS and DNS-SD technologies.
    NI-VISA 4.0.1
    Added support for the PXI/PCI Passport on the x86 architecture.
    Added native support for the NI-VISA Configuration Utility on the x86 architecture.
    NI-VISA 4.0
    Added support for OS X on the x86 architecture, aka Mactel.
    Added support for 64-bit data transfers in register-based operations, to support the VISA 4.0 specification.
    Added support for DTR/DSR flow control. The Agilent 34401A requires DTR/DSR flow control when used via Serial. Note that not all Serial port drivers on OS X support DTR/DSR. We have tested the Agilent 34401A with NI-VISA 4.0 using the Keyspan USA-19HS and verified that it works properly.
    © 1995–2021 National Instruments Corporation. All rights reserved.
    Third-Party Legal Notices
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    375354J-01
  • 签到天数: 193 天
    发表于 2026-1-15 14:35:27 | 显示全部楼层 来自:吉林省 移动(全省通用)
    GMT+8, 2026-2-27 11:47
