查看: 4265|回复: 0
[NI驱动程序] NI-XNET 21.0.0 Driver Download Win10x64 Eng/Ger/Jpn NI-XNET仪器驱动程序21.0.0下载
    10 小时前
    发表于 2021-9-3 16:32:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-XNET
    从NI-XNET 21.0版本开始,仅支持64位的Win10/WinServer 2016/WinServer 2019系统,但是仍然支持64位系统下的32位LabVIEW。
    NI-XNET 21.0.0
    发布日期
    2021/8/13
    包含的版本
    21.0.0完整版
    受支持的操作系统
    应用程序位数
    32/64位
    语言
    德语,日语,英文
    校验和
    文件大小: 1867137024 字节 (1.74 GB)
    修改日期: 2021-08-04 10:17
    MD5: c841312373589b5e0bc61204c24ed7d0
    SHA1: c64e3d3d71749462a0978e598f2a19ede601f1a7
    SHA256: 8c0d96f620865204ab11ae686b56592f17f17a3a3201f04ea00157c2661f9c25
    CRC32: d72e2df6
    注册登录视觉论坛,购买附件查看下载地址
    NI-XNET21.0.0.txt (537 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-XNET 21.0 Readme
    July 2021
    This file contains installation instructions and compatibility information for NI-XNET.
    • NI-XNET Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-XNET Manuals: New features, behavior changes, and other documentation
    NI-XNET is an NI instrument driver that features a common set of easy-to-use functions for reading and writing Automotive Ethernet, CAN, LIN, and FlexRay data on many different platforms including USB, PXI, PCI, NI CompactDAQ, and NI CompactRIO.
    NI-XNET 21.0 supports the following operating systems:
    • NI Real-Time Phar Lap ETS
    Note  NI-XNET 21.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-XNET 21.0 to an unsupported OS. Additionally, after installing NI-XNET 21.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-XNET 21.0 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-XNET
    LabVIEW2018 SP1, 2019 SP1, 2020 SP1, and 2021
    LabVIEW Real-Time (RT)2018, 2019, 2020, and 2021
    LabVIEW NXG5.0, 5.1
    LabWindows™/CVI™2017 and later
    If you are using the NI-XNET .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-XNET .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the NI-XNET installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Added support for LabVIEW 2021.
    • Added support for LabVIEW NXG 5.1.
    • Added sleep/wake capability based on OPEN Alliance TC10 Sleep/Wake 2.0 specification. (This feature is currently supported only on the PXIe-8523 Automotive Ethernet module.)
    • Added new property, Interface:Ethernet:Output Stream Timescale, which enables an XNET Stream Session to output individual Ethernet frames at specified times.
    • Added new property, Session:Interface:Ethernet:Signal Quality, to indicate signal quality of an NI Automotive Ethernet interface.
    • Added support to create FlexRay timing sources for Linux RT.
    • Added support for PXIe-8623.
    • Replaced the NI-XNET Database Editor with new version (previously NI-XNET Database Editor Preview).
    The following list details the hardware models supported in NI-XNET 21.0.
    • USB-8501 Low-Speed/Fault Tolerant USB CAN Interface Device
    • USB-8502 High-Speed/FD USB CAN Interface Device
    • USB-8506 USB LIN Interface Device
    • PCI-8511 Low‑Speed/Fault-Tolerant CAN Interface Device
    • PCI-8512 High‑Speed/FD CAN Interface Device
    • PCI-8513 Software‑Selectable/FD CAN Interface Device
    • PCI-8516 PCI LIN Interface Device
    • PCI-8517 FlexRay Interface Device
    • PCIe-8510 PCIe Vehicle Multi-Protocol Interface Device
    • PXI-8511 Low-Speed/Fault Tolerant PXI CAN Interface Module
    • PXI-8512 High-Speed, Flexible Data Rate PXI CAN Interface Module
    • PXI-8513 Software-Selectable PXI CAN Interface Module
    • PXI-8516 PXI LIN Interface Module
    • PXI-8517 PXI FlexRay Interface Module
    • PXIe-8510 PXI Vehicle Multiprotocol Interface Module
    • PXIe-8521 100BASE-T1 PXI Automotive Ethernet Interface Module
    • PXIe-8522 1000BASE-T1 PXI Automotive Ethernet Interface Module
    • PXIe-8523 100/1000BASE-T1 PXI Automotive Ethernet Interface Module
    • PXIe-8623 100BASE-TX/1000BASE-T PXI Automotive Ethernet Interface Module
    • TRC-8542 CAN HS/FD Transceiver Cable
    • TRC-8543 CAN HS/FD or LS/FT Transceiver Cable
    • TRC-8546 LIN Transceiver Cable
    C Series modules:
    • NI 9860 C Series Vehicle Multiprotocol Interface Module
    • NI 9861 Low-Speed/Fault Tolerant C Series CAN Interface Module
    • NI 9862 High-Speed, Flexible Data Rate C Series CAN Interface Module
    • NI 9866 C Series LIN Interface Module
    • CompactDAQ—NI-DAQmx 17.1 (or later) is required for:
      • USB Chassis: cDAQ-9171, cDAQ-9174, cDAQ-9178, and cDAQ-9179
      • Ethernet Chassis: cDAQ-9181, cDAQ-9184, and cDAQ-9188
      • Wireless Chassis: cDAQ-9191
      • cDAQ Controller: cDAQ-9138 (Windows only) and cDAQ-9139 (Windows only)
      • cDAQ Controller: cDAQ-9132 (Windows and RT) and cDAQ-9134 (Windows and RT)
      • cDAQ Controller: cDAQ-9133 (Windows and RT) and cDAQ-9135 (Windows and RT)
      • cDAQ Controller: cDAQ-9136 (Windows and RT) and cDAQ-9137 (Windows and RT)
      • Ethernet Chassis: cDAQ-9185 and cDAQ-9189
    • CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2017 (or later) are required for the following targets:
      • Integrated CompactRIO Real-Time Controller: cRIO-906x, and cRIO-903x
      • Single-Board RIO: sbRIO-9627, sbRIO-9607
      • CompactRIO Real-Time Controller: cRIO-9032, cRIO-9037
      • CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
      • When using a cRIO-903x or cRIO-906x, a bit stream is not needed with NI 986x modules in the project
      • When using a cRIO-903x, cRIO-906x, or sbRIO-96x7, installation in the "Other" programming environment is not supported
      • CompactRIO Real-Time Controller: cRIO-9040, cRIO-9042, cRIO-9043, cRIO-9045, cRIO-9046, cRIO-9047, cRIO-9048, and cRIO-9049
      • When using a cRIO-904x, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
    • CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2018 (or later) are required for the following targets:
      • CompactRIO Real-Time Controller: cRIO-9053, cRIO-9054, cRIO-9056, and cRIO-9057
      • When using a cRIO-905x, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
    • CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2019 (or later) are required for the following targets:
      • Single-Board RIO: sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, sbRIO-9638
      • When using an sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, or sbRIO-9638, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
    Note  NI-XNET software supports only NI Automotive Ethernet, CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Refer to NI-XNET Help, accessible from the Help menu in LabVIEW, for information about NI-XNET.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder.
    You can find Automotive Ethernet, CAN, FlexRay, and LIN examples under Hardware Input and Output in the Example Finder.
    LabVIEW examples for NI-XNET are located in the National Instruments\LabVIEW\examples\nixnet directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The following sections detail considerations for using LabVIEW NXG with NI-XNET 21.0.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-XNET no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI Software Drops Support for Phar Lap ETS Real-Time Operating System in 2022.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    © 2009–2021 National Instruments Corporation. All rights reserved.
    374802AA-01
    GMT+8, 2025-12-8 19:35
