查看: 3157|回复: 0
[NI软件套件] LabVIEW myRIO Software Bundle 2013 Win32Eng LabVIEW myRIO软件套件1.0
    1 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2021-9-6 23:02:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW myRIO软件套件
    LabVIEW myRIO软件套件为myRIO学生嵌入式设备提供LabVIEW myRIO工具包和附加软件。
    LabVIEW myRIO软件套件包含了LabVIEW编程环境和其他LabVIEW软件附件和驱动软件,用于在myRIO学生嵌入式设备上开发和部署应用程序。
    myRIO软件套件包含以下内容:
    • LabVIEW Development System
    • myRIO Module
    • Real-Time Module
    Optional Software
    • FPGA Module
    • Vision Development Module
    • Vision Acquisition Software
    • Control Design and Simulation Module
      • Control Design Assistant
    • MathScript RT Module
    • Robotics for myRIO
    通常包含两个DVD文件,其中文件2一般是包含了FPGA Xilinx编译程序,
    本套件只有DVD1,无DVD2。FPGA编译程序参考以下内容:
    LabVIEW FPGA Module Xilinx Compilation Tools Win/Linux 32/64Eng ISE/Vivado LV FPGA编译工具历年版本下载2010~2022
    http://visionbbs.com/thread-24839-1-1.html?fromuid=9
    发布日期:2013/8/2
    包含的版本:1.0.0
    Windows 7
    Windows Server 2008 R2 64-bit
    Windows Server 2003 R2 32-bit
    Windows Vista
    Windows XP 32-bit
    应用程序位数:32
    语言:英文
    文件大小: 6433202176 字节 (5.99 GB)
    修改日期: 2013-08-03 06:30
    MD5: ebbbfa30a1a8555bebe10f75d24dfd24(官方正确)
    SHA1: e00625ac77193b6075d15695cc1a80bdd3372e72
    SHA256: ae0589da7e2863ef798f853c3ada8c0663d7ce41a0f473af82bd615ea8f57e70
    CRC32: d4c002b1
    请注册登录机器视觉论坛会员,购买附件查看下载地址,充值请联系在线客服
    LVmyRIO2013V1.0.txt (547 Bytes, 下载次数: 2, 售价: 30 圆)
    NI myRIO Software Suite 2013 Readme
    Version 1.0
    June 2013
    With the NI myRIO Software Suite, one installation gives you access to the LabVIEW for myRIO Module and other products that you need for developing NI myRIO applications.
    The NI myRIO Software Suite contains the following products:
    • myRIO Module
    • Real-Time Module
    Optional Software
    • FPGA Module
    The NI myRIO Software Suite also contains compilation tools for FPGA devices other than Virtex-II.
    The NI myRIO Software Suite supports the following operating systems:
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP Pro (Service Pack 3)
    Refer to the readme of each product for specific system requirements and supported operating systems.
    Complete the following steps to install LabVIEW, LabVIEW Real-Time Module, LabVIEW for myRIO Module, and other NI software on a development computer.
    • Log in to the development computer as an administrator or as a user with administrative privileges.
    • Insert the NI myRIO Software Suite DVD 1.
    • Follow the instructions on the screen to install and activate the software.
    Insert the NI myRIO Software Suite DVD 2 if you want to install optional software for FPGA programming.
    NI myRIO Software Suite Updates and Notifications
    Using NI Launcher
    Finding All Programs
    NI myRIO Software Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments myRIO Software Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the NI myRIO Software Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2013 National Instruments. All rights reserved.
    GMT+8, 2026-4-8 09:21
