查看: 3072|回复: 0
[LV工具模块] LabVIEW myRIO Toolkit 2015 Win32Eng LabVIEW 2015myRIO工具包
    发表于 2021-9-7 22:50:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW myRIO工具包提供了在myRIO学生嵌入式设备上开发和部署应用程序所需的工具。
    LabVIEW myRIO工具包是LabVIEW的软件附件,提供了在myRIO学生嵌入式设备上快速开发和部署应用程序所需的驱动和工具。该工具包为myRIO设备上的每种I/O类型提供了基于配置的Express和Advanced I/O VI,可帮助学生快速构建想法并编写独立的应用程序。
    2015myRIO
    发布日期
    2015/8/1
    包含的版本
    2015完整版
    受支持的操作系统
    Windows Server 2003 R2 32-bit
    Windows XP (SP3) 32-bit
    Windows Vista
    Windows 8
    Windows 7
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows Server 2008 R2 64-bit
    应用程序位数
    32位
    语言
    英文
    校验和
    文件大小: 2861187072 字节 (2.66 GB)
    修改日期: 2016-08-01 14:02
    MD5: cfb6958293bd13e28cbd39f324f76cdb(官方正确)
    SHA1: e7260514276b955ae05839c65a09842b27aac650
    SHA256: cea78813ea21e053769cd25aef5a04a9f0ec84e3ec3a09a57bf8a361d1976919
    CRC32: b39c6fe7
    myRIO2015.txt (546 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2015 myRIO Toolkit Readme
    June 2015
    This file contains important information about the LabVIEW myRIO Toolkit, including system requirements, installation instructions, known issues, and a partial list of bugs fixed for the LabVIEW 2015 myRIO Toolkit.
    Installing the High Throughput Add-On for myRIO
    Installing the USBLAN Driver in Microsoft Windows XP and Windows Server 2003
    Accessing the LabVIEW for myRIO Environment
    The LabVIEW myRIO Toolkit provides you with tools for creating and deploying applications on the myRIO.
    The myRIO Toolkit has the following requirements:
    • (Optional for C Programming) LabVIEW 2015 Student, Full, or Professional Development System (32-bit)
    • (Optional for C Programming) LabVIEW 2015 Real-Time Module
    • At least 2 GB of disk space in addition to the LabVIEW-recommended minimum
    • 1 GB RAM
    • One of the following operating systems for application development:
      • Windows 8.0/8.1 (32-bit and 64-bit)
      • Windows XP Service Pack 3 Professional
    • The myRIO Toolkit is compatible with only 32-bit LabVIEW. Install 32-bit LabVIEW even if you use a 64-bit operating system.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). Refer to the National Instruments website for information about how this might affect your use of Windows Server 2003 R2 and what actions you might have to take.
    • The myRIO Toolkit does not support the Windows Server non-R2 editions.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    To install the myRIO Toolkit using the LabVIEW myRIO Software Bundle media, complete the following steps:
    • Log in to the development computer as an administrator or as a user with administrative privileges.
    • Insert the LabVIEW myRIO Software Bundle DVD 1.
    • Select Install NI LabVIEW 2015 myRIO Toolkit.
    • (Optional for C Programming) Click the drop-down arrow next to LabVIEW Support and select Install this feature to a local drive.
    • Click Next and follow the instructions on the screen to install the myRIO Toolkit.
    To install the myRIO Toolkit using the installer from ni.com/downloads, double-click the setup.exe file in the root directory of the myRIO Toolkit installer and follow the instructions on the screen to install this product.
    The High Throughput Add-On for myRIO provides the High Throughput FPGA Personality VIs which support high-speed analog or digital data access. The High Throughput FPGA Personality VIs appear on the myRIO palette only after you install the High Throughput Add-On for myRIO.
    Visit ni.com/info and enter the Info Code ex6g5a to download the High Throughput Add-On for myRIO installer. Double-click the setup.exe file in the root directory of the installer and follow the instructions on the screen to install this product.
    You must manually install the USBLAN driver before using the myRIO with Microsoft Windows XP and Windows Server 2003. Complete the following steps to install the USBLAN driver:
    Note  Before completing the following steps, make sure that you have downloaded and installed the KB 931125 package from Microsoft. For more information, refer to the Workarounds and Recommendations section of KB 65O8AH55, Why Are National Instruments Installers Failing on Windows XP and Server 2003 Machines?.
    • Connect the myRIO to your computer after you install the myRIO Toolkit.
    • In the Found New Hardware Wizard, select No, not this time and click Next.
    • Select Install from a list or specific location and click Next.
    • Select Include this location in the search and navigate to the National Instruments\CompactRIO\Staging\USBLAN\XP directory.
    • Click Next to install the USBLAN driver. Click Continue Anyway when you see the Windows Logo testing warning.
    • Click Finish.
    The USBLAN driver appears under Network adapters in the Windows Device Manager.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the LabVIEW myRIO Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW myRIO Toolkit. This is not an exhaustive list of issues fixed in the current version of the myRIO Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    487269SPI in the Customized FPGA Signal Generator example uses IRQ's, but the custom FPGA bitfile does not include the appropriate IRQ logic.
    486313The RSS for myRIO software is missing in MAX when only the myRIO Toolkit is installed.
    486289Using special characters, <, ", and &, in channel alias names causes the myRIO Express VIs to function improperly.
    The myRIO Toolkit provides the LabVIEW for myRIO environment to allow you to easily access myRIO-specific features and focus on developing myRIO applications.
    You can use the Choose Environment Settings dialog box to change your LabVIEW environment. To display this dialog box, select Tools»Choose Environment from LabVIEW.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the myRIO Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the myRIO Toolkit are located in the labview\examples\myRIO directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW myRIO Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW myRIO Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the LabVIEW myRIO Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2013–2015 National Instruments. All rights reserved.
    375387A-01
    GMT+8, 2025-12-8 07:35
