LabVIEW myRIO Toolkit 2019 Win32Eng LabVIEW 2019myRIO工具包
LabVIEW myRIO工具包提供了在myRIO学生嵌入式设备上开发和部署应用程序所需的工具。
LabVIEW myRIO工具包是LabVIEW的软件附件,提供了在myRIO学生嵌入式设备上快速开发和部署应用程序所需的驱动和工具。该工具包为myRIO设备上的每种I/O类型提供了基于配置的Express和Advanced I/O VI,可帮助学生快速构建想法并编写独立的应用程序。
2019myRIO
发布日期
2019/5/14
包含的版本
2019完整版
受支持的操作系统
Windows 7 (SP1) 32-bit
Windows 7 (SP1) 64-bit
Windows 8.1 32-bit
Windows 8.1 64-bit
Windows 10 32-bit
Windows Server 2012 R2 64-bit
应用程序位数
32位
语言
英文
校验和
文件大小: 1961240576 字节 (1.83 GB)
修改日期: 2019-05-15 08:47
MD5: c922194cb2b6744659f6df5e8937aa7b(官方正确)
SHA1: 185d862361ce2d2cc21e5121278faf385db7a6c7
SHA256: 4aca026a399dc491acda9c1bd5a757fbb39c352c5016086e3c75bd40c4fcfd0e
CRC32: 6bffd308
myRIO2019.txt
(653 Bytes, 下载次数: 3, 售价: 10 圆)
LabVIEW 2019 myRIO Toolkit ReadmeMarch 2019
This file contains important information about the LabVIEW myRIO Toolkit, including system requirements, installation instructions, and known issues.
Overview System Requirements Supported Operating Systems Installation Instructions Installing the High Throughput Add-On for myRIO Product Security and Critical Updates Known Issues Accessing the LabVIEW for myRIO Environment Accessing the Help Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 LabVIEW myRIO Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 Legal Information OverviewThe LabVIEW myRIO Toolkit provides you with tools for creating and deploying applications on the myRIO.
System RequirementsThe myRIO Toolkit has the following requirements:
- (Optional for C Programming) LabVIEW 2019 Student, Full, or Professional Development System
- (Optional for C Programming) LabVIEW 2019 Real-Time Module
- At least 2 GB of disk space in addition to the LabVIEW-recommended minimum
- 1 GB RAM
Refer to the LabVIEW Readme for additional system requirements for LabVIEW 2019.
- The myRIO Toolkit is compatible with only 32-bit LabVIEW. Install 32-bit LabVIEW even if you use a 64-bit operating system.
- You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
Supported Operating SystemsThe myRIO Toolkit supports the following operating systems:
- Windows 10 (version 1809)/8.1 Update 11/7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
- In 2016 the LabVIEW myRIO Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2019 myRIO Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2019 myRIO Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2019 myRIO Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
- Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport.
- Refer to LabVIEW myRIO Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
Installation InstructionsNI automates software installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
To install the myRIO Toolkit using the installer from ni.com/downloads, double-click the setup.exe file in the root directory of the myRIO Toolkit installer and follow the instructions on the screen to install this product.
Installing the High Throughput Add-On for myRIOThe High Throughput Add-On for myRIO provides the High Throughput FPGA Personality VIs which support high-speed analog or digital data access. The High Throughput FPGA Personality VIs appear on the myRIO palette only after you install the High Throughput Add-On for myRIO.
Visit ni.com/info and enter the Info Code ex6g5a to download the High Throughput Add-On for myRIO installer. Double-click the setup.exe file in the root directory of the installer and follow the instructions on the screen to install this product.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI.
Known IssuesYou can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code lvmyrio2019ki for an up-to-date list of known issues in LabVIEW 2019 myRIO Toolkit.
Accessing the LabVIEW for myRIO EnvironmentThe myRIO Toolkit provides the LabVIEW for myRIO environment to allow you to easily access myRIO-specific features and focus on developing myRIO applications.
You can use the Choose Environment Settings dialog box to change your LabVIEW environment. To display this dialog box, select Tools»Choose Environment from LabVIEW.
Accessing the HelpRefer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the myRIO Toolkit.
Finding ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the myRIO Toolkit are located in the labview\examples\myRIO directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes.
- For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Software Platform Bundle, refer to Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10.
Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
LabVIEW myRIO Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021LabVIEW myRIO Toolkit will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
Product | Info Code | | LabVIEW | lifecycle | | LabWindows/CVI | cvi_lifecycle | | Measurement Studio | mstudiolifecycle | | TestStand | tslcp | | DIAdem | ddlcp | | SignalExpress | selcp | | VeriStand | nivslifecycle |
Legal InformationCopyright
© 2013–2019 National Instruments. All rights reserved.
- Notices are located in the \_Legal Information and directories.
375387F-01
