查看: 2949|回复: 0
[Patch补丁] LabVIEW Electric Motor Simulation Toolkit 2014 Patch Win32Eng LabVIEW电动机仿真工具包补丁NIEMsim2014F1patch
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2021-9-8 22:28:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW Electric Motor Simulation Toolkit 2014f1Patch Win32Eng LabVIEW电动机仿真工具包补丁NIEMsim2014F1patch
    LabVIEW电动机仿真工具包提供了开发桌面和硬件在环电动机系统仿真模型所需的建模元件。
    LabVIEW电机仿真工具包是LabVIEW和VeriStand的软件附件。它为电子仿真、控制和硬件在环(HIL)提供了LabVIEW项目模板,以及适用于各种电机类型的VeriStand软件附件。该工具包可帮助您在主机上执行模型,以进行桌面仿真、LabVIEW实时仿真和基于FPGA的仿真。电动机仿真工具包包括开关磁阻电动机(SRM)、应电机和永磁同步电机模型,这些模型可以是近乎线性的简单模型也可以是更高保真度的模型。
    NIEMsim2014f1patch
    发布日期
    2015/5/5
    包含的版本
    2014f1patch
    受支持的操作系统
    Windows 8
    Windows 7
    Windows Vista
    Windows XP
    Windows Server 2008 R2 64-bit
    Windows Server 2003 R2 32-bit
    应用程序位数
    32位
    语言
    英文
    校验和
    文件大小: 48662987 字节 (46.41 MB)
    修改日期: 2019-06-25 02:53
    MD5: 7cf145c88f6481378381a270adf8872b(官方正确)
    SHA1: 589820789be5168aba644883516aff32c316db60
    SHA256: ee040d8925e23d28f56b3651294c0e6bcf3552f4196192d190a0ef9017cd9dec
    CRC32: 25d017ba
    EMsim2014patch.txt (634 Bytes, 下载次数: 0, 售价: 2 圆)
    NI Electric Motor Simulation Toolkit 2014 f1 Patch Readme
    This file introduces you to the NI Electric Motor Simulation Toolkit 2014 f1 patch, which includes one fix.
    Fixed Issues
    Modified Files
    You must install the NI Electric Motor Simulation Toolkit 2014 before you can install this patch. The same system requirements for the NI Electric Motor Simulation Toolkit 2014 apply to this patch. Refer to the NI Electric Motor Simulation Toolkit 2014 readme for more information about system requirements.
    Fixed Issues
    This patch fixes the following issue.
    • CAR 518078–FPGA PMSM FEA model can output incorrect torque and current values.
    Modified Files
    This patch modifies the following installed files. is the location on the computer where NI software installs, such as C:\Program Files\National Instruments.
    LabVIEW Support
    • \LabVIEW\vi.lib\addons\E-Motor Simulation\MotorClass\PMSM_FEA\Generate FPGA Data_Constants.vi
    • \LabVIEW\vi.lib\addons\E-Motor Simulation\PMSM FEA FXP\Access DRAM_Prepare.vi
    • \LabVIEW\vi.lib\addons\E-Motor Simulation\Utility\Convert Fractional Index to U16.vi
    • \LabVIEW\vi.lib\addons\E-Motor Simulation\Utility\Generate Index LUT_Delta.vi
    VeriStand Support
    • Documents\National Instruments\VeriStand\Custom Devices\EMSim\PMSM FEA Model\PMSM FEA Model Configuration.llb
    • Documents\National Instruments\VeriStand\Custom Devices\EMSim\PMSM FEA Model\PMSM FEA Model Engine.llb
    • Documents\National Instruments\VeriStand\Custom Devices\EMSim\PMSM FEA Model\FPGA\PXIe-7965R PMSM FEA Model Simulator.lvbitx
    • Documents\National Instruments\VeriStand\Custom Devices\EMSim\PMSM FEA Model\FPGA\PXIe-7966R PMSM FEA Model Simulator.lvbitx
    • Documents\National Instruments\VeriStand\Custom Devices\EMSim\PMSM Variable Parameter Model\PMSM Variable Parameter Model Configuration.llb
    • Documents\National Instruments\VeriStand\Custom Devices\EMSim\PMSM Variable Parameter Model\PMSM Variable Parameter Model Engine.llb
    • Documents\National Instruments\VeriStand\Custom Devices\EMSim\SRM FEA Model\SRM FEA Model Configuration.llb
    • Documents\National Instruments\VeriStand\Custom Devices\EMSim\SRM FEA Model\SRM FEA Model Engine.llb
    Complete the following steps to install the NI Electric Motor Simulation Toolkit 2014 f1 patch:
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Log in as an Administrator or as a user with administrator privileges.
    • Close LabVIEW.
    • Run the patch installer.
    • Restart LabVIEW.
    • Recompile the bitfile for PMSM FEA model simulation and download the bitfile to the FPGA target.
    © 2013–2015 National Instruments. All rights reserved.
    GMT+8, 2026-2-26 02:38
