查看: 3163|回复: 0
[NI驱动程序] National Instruments RF Device Drivers 18.0 Win32/64Eng NI RF设备驱动套件RFDRVSUITE201805
    昨天 15:38
  • 签到天数: 3826 天
    连续签到: 19 天
    发表于 2021-9-9 10:54:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    校验和
    文件大小: 6068555479 字节 (5.65 GB)
    修改日期: 2021-09-09 10:40
    MD5: b14fc378303f605184afaa5810d404e4
    SHA1: de29dacc7a3fbff9b679e884b6ae1ef9812c4bff
    SHA256: dc118de0d970a8fe88ee21dd0bc35416e4a6fb0c1fdfc0b0d936bf64c78e98ed
    CRC32: 5e156993
    RFDRVSUITE201805.txt (483 Bytes, 下载次数: 2, 售价: 10 圆)
    National Instruments RF Device Drivers 18.0 Readme
    May 2018
    RF Device Driver Readme Files
    For important information about your National Instruments RF device driver software, refer to your product readme file, as follows:
    • NI-RFmx SpecAn 2.4
    • NI-RFmx Demod 2.4
    • NI-RFSA 18.0
    • NI-RFSG 18.0
    • LabVIEW Modulation Toolkit 18.0
    Choosing What Software to Install
    To help you decide which software to install, refer to the following descriptions:
    NI-RFmx SpecAn 2.4—Use this software to perform spectral measurements with vector signal analyzers or the RF input subsystem of vector signal transceivers (VSTs).
    NI-RFmx Demod 2.4—Use this software to perform demodulation measurements with vector signal analyzers or the RF input subsystem of VSTs.
    NI-RFSA 18.0—This software installation provides support for customers using vector signal analyzers or the RF input subsystem of VSTs. To program the vector signal analyzer or VST, use the NI-RFSA API. The getting started guide for your device provides information about how to install, configure, test, and begin using a vector signal analyzer or VST.
    NI-RFSG 18.0—This software installation provides support for customers using RF analog signal generators or the RF output subsystem of VSTs. To program the RF analog signal generator or VST, use the NI-RFSG API. The getting started guide for your device provides information about how to install, configure, test, and begin using a RF signal generator or VST.
    Modulation Toolkit (LabVIEW)—This software installation provides additional modulation scheme software functionality for customers using vector signal generators, waveform generators, vector signal analyzers, and IF digitizers.
    Insert the driver software DVD. When the NI RF Device Drivers window appears, click Install RF Driver Software to begin installation. If the NI RF Device Drivers window does not appear, launch autorun.exe from the root directory of the driver software DVD.
    • Windows 10/8.11/7 SP12
    This installation requires that version 3.1 of the MSI (Windows Installer) Engine is installed on your computer. If you do not have MSI 3.1 or later, the installer updates the engine automatically and may require you to restart your computer.
    Refer to your product-specific readme file for additional requirements.
    Uninstallation Instructions
    You can uninstall each RF device driver by selecting National Instruments Software in the Windows Add/Remove Programs application.
    Software Updates and Replacement Media
    For the latest version of the NI RF Device Drivers, visit ni.com/info and enter the Info Code RFDriverSuite to download the latest version.
    If you require a replacement NI RF Device Driver DVD, visit ni.com/info and enter the Info Code media for instructions on obtaining a replacement.
    © 2013–2018 National Instruments. All rights reserved.
    GMT+8, 2026-3-16 03:25
