查看: 3008|回复: 0
[NI驱动程序] NI RF Signal Analyzers 20.5.4 Win64Eng NI PXI矢量信号分析仪驱动NI-RFSA 20.5.4
    10 小时前
    发表于 2021-9-12 22:15:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSA
    发布日期
    2021/2/25
    包含的版本
    20.5.4完整版
    受支持的操作系统
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 4751687680 字节 (4.43 GB)
    修改日期: 2021-02-25 17:19
    MD5: c2a87b08c37f9f5e152e95f2490f34ef
    SHA1: 70d523b8926297c7a9eee31b72d4e7489454f010
    SHA256: 03451f3fbdca4013e7ccbf507409a7db25e567bca929d24b02ff08b6f6efdd48
    CRC32: d0c85dc3
    RFSA20.5.4.txt (560 Bytes, 下载次数: 0, 售价: 10 圆)
    NI RF Signal Analyzers (NI-RFSA) 20.5.4 Readme
    Febraury 2021
    You can find more release information on ni.com in the NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release.
    NI-RFSA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 in 2021
    This software installation provides support for customers using vector signal analyzer or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSA 20.5.4 includes a bug fix to address a .NET initialization issue for PXIe-5830/1/2 devices in RFmx
    NI-RFSA 20.5 includes the following new features:
    • Support for the PXIe-5832
    • Support for selected ports in configuration lists on the PXIe-5830/5831/5832
    NI-RFSA 20.0 includes the following new features:
    • Support for LabVIEW 2020
    • Support for RF list mode on the PXIe-5841 with PXIe-5655
    NI-RFSA 19.6 includes the following new features:
    • Support for checking module connections on the PXIe-5830/5831 with intermediate self-test in MAX or System Configuration API
    • Support for reference level in configuration lists on the PXIe-5830/5831
    • Support for clearing self calibrate range data on the PXIe-5820/5830/5831/5840/5841
    NI-RFSA 19.2.1 includes support for configuring the pulse width of the user source signals
    NI-RFSA 19.2 includes support for the PXIe-5841 with PXIe-5655
    NI-RFSA 19.1.6 includes improvements for the PXIe-5831 in the Semiconductor Test System
    NI-RFSA 19.1.5 includes support for the PXIe-5841
    NI-RFSA 19.1 includes the following new features:
    • Support for the PXIe-5830/5831
    • Support for LO sharing on the PXIe-5830/5831 to improve phase noise performance
    NI-RFSA 19.0 includes support for LabVIEW 2019
    NI-RFSA 18.2 includes the following new features:
    • Support for specifying digital gain on the PXIe-5820/5840
    • Support for de-embedding measurements on the PXIe-5840
    • Improvements to communication performance on the PXIe-5820/5840
    • Support for specifying external calibration date for the PXIe-5644/5645/5646 and PXIe-5820/5840 in System Configuration API and MAX
    NI-RFSA 18.1 includes the following new features:
    • Support for NI-TClk on the PXIe-5668
    • Support for the PXIe-5840 with PXIe-5653 in the NI-RFSA SFP
    • Added Fetch IQ (1D I16 Data Ref) for improved fetch and streaming performance
    • Improvements to initiate performance on the PXIe-5820/5840
    • Support for associating the PXIe-5840 with the PXIe-5653 LO source
    • Support for controlling the RF OUT LO OUT terminal on the PXIe-5840
    • Support for PXIe-5820/5840 self-calibration in System Configuration API
    • Support for modifying temperature resolution for automatic thermal correction
    • Support for modifying DMA buffer size to improve NI-RFSA fetch performance
    • Support for clearing self calibrate range data on the PXIe-5644/5645/5646
    NI-RFSA 18.0 includes the following new features:
    • Added support for LabVIEW 2018
    • Added the NI-RFSA .NET Class Library and NI-RFSA .NET examples to the installer
    Hardware Product
    Hardware Model
    NI-RFSA
    RF Signal DownconverterPXI-5600
    PXIe-5601
    PXIe-5603
    PXIe-5605
    PXIe-5606
    Vector Signal AnalyzerPXI-5661
    PXIe-5663/5663E
    PXIe-5665
    PXIe-5667
    PXIe-5668
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5832
    PXIe-5840
    RF Analog Signal Generator
    PXIe-5841
    RF Preselector ModulePXIe-5693
    IF Conditioning ModulePXIe-5694
    RF AmplifierPXIe-5698
    MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    • 4 GB RAM*
    NI-RFSA 20.5.4 and NI-RFSA SFP 20.5.4 support the following operating systems:
    • Windows 10, 8.11, 7 SP12 (64-bit)
    1NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  In 2019 NI-RFSA dropped support for all 32-bit Windows operating systems. NI-RFSA will not install or run on an unsupported OS. Refer to NI-RFSA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Versions Supported by NI-RFSA
    LabVIEW2017 SP1, 2018 SP1, 2019, or 2020
    LabVIEW Real-Time Module2017, 2018 SP1, 2019, or 2020
    LabWindows/CVI2010 to current
    LabWindows/CVI Real-Time Module2010 to current
    Note  When using NI-RFSA with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646, PXIe-5668, and PXIe-5820/5830/5831/5832/5840/5841 are not supported.
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Document
    Format
    Description
    • Hardware device overviews
    NI-RFSA no longer installs IVI Compliance Package (ICP). NI-RFSA supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    The following are behavior changes in NI-RFSA 18.2 from NI-RFSA 18.1:
    • Support was removed for the PXIe-5653 Test Panel in MAX.
    • The NI-RFSA Express VIs are now obsolete and are no longer installed.
    • The NI-RFSA RF Out LO Export Enabled property no longer requires the NI-RFSG LO Out Export Configure From RFSA property to be set to Enabled. NI-RFSA can change the export state of NI-RFSG without an open NI-RFSG session on the PXIe-5840. Ensure the NI-RFSG LO out export is generating a useful signal before using that signal for NI-RFSA operations.
    NI-RFSA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2004–2021 National Instruments Corporation. All rights reserved.
    374797AE-01
    GMT+8, 2025-12-8 19:32
