查看: 2564|回复: 0
[NI软件产品] NI mmWave OTA Validation Test Software 1.0 Win64Eng NI毫米波空口验证测试软件1.0
    10 小时前
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2021-9-13 22:38:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    mmWave OTA验证测试软件
    mmWave OTA验证测试软件可简化并加速5G封装天线波束成形器件的特性分析和验证测试。
    mmWave OTA验证测试软件是一款应用软件,可帮助您配置、运行、可视化和报告5G mmWave封装天线集成电路(IC)空口(OTA)辐射性能。该软件可以执行系统校准,以测量每个信号路径的路径损耗,进而补偿测试仪器、电缆、天线和空口通信。此外,mmWave OTA验证测试软件还根据3GPP测试规范简化了配置和运行3D空间扫描的过程。您可以使用模板自定义测试序列,以自动执行数据采集、结果报告和存储。该软件包括一系列可视化工具,包括天线方向图、3D和极坐标图、波束宽度、热图等。
    1.0
    发布日期
    2019/11/5
    包含版本
    1.0.0完整版
    受支持的操作系统
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 377290752 字节 (359.81 MB)
    修改日期: 2021-09-11 22:43
    MD5: 9f01794dbedfaadb7a080380545972b5
    SHA1: bf9f0cd7e3564347763a0de001ad5b873345d544
    SHA256: 8af83b328d99d012c76a760b1f7432539b5d0272c126b98d4c9709566634f6bd
    CRC32: f7985f38
    mmWAVE1.0.txt (641 Bytes, 下载次数: 0, 售价: 10 元)
    mmWave OTA Validation Test Software 1.0 Readme
    October 2019
    This file contains important information about the mmWave OTA Validation Test Software, including installation instructions, new features, and known issues.
    Finding Installed Software
    This software installation provides support for the mmWave OTA Validation Test Reference Architecture and helps you configure, run, visualize, and report the over-the-air (OTA) radiated performance of 5G mmWave antenna-in-package (AiP) integrated circuits.
    The mmWave OTA Validation Test Software can perform system calibration to measure the path losses of every signal path, compensating for test instruments, cables, antennas, and air interface. Additionally, the mmWave OTA Validation Test Software simplifies the process of configuring and running 3D spatial sweeps according to 3GPP test specifications. You can use templates to customize test sequences to automate data collection, results reporting, and storage. The software also includes a collection of visualization tools for antenna pattern cuts, 3D and polar plots, beamwidth, heat map, and more.
    • LabVIEW 2018 (64-bit)
    • TestStand 2019 (64-bit)
    • RFmx NR 19.0
    • RFmx SpecAn 19.0
    Refer to the documentation of each product for specific system requirements.
    mmWave OTA Validation Test Software supports Windows 10 (64-bit).
    mmWave OTA Validation Test Software supports the mmWave OTA Validation Anechoic Chamber and all instruments used with the mmWave OTA Validation Test Reference Architecture.
    You should install application software and required software products before installing mmWave OTA Validation Test Software.
    NI installs mmWave OTA Validation Test Software using NI Package Manager. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can access the software and documentation known issues list online. Visit mmWave OTA Validation Test Software Known Issues for an up-to-date list of known issues.
    Refer to the mmWave OTA Validation Test Reference Architecture Manual, accessible from ni.com/r/otahelp, for information about the mmWave OTA Validation Test Software.
    • is an alias for the following National Instruments file folder location: Program Files\National Instruments
    Item
    Installed Location
    TestStand Examples\TestStand 2019 (64-bit)\Examples\OTA Test
    Configuration UI\LabVIEW 2018\user.lib\OTA Test\Configuration UI\ConfigUI.vi
    Positioner Soft Front Panel\LabVIEW 2018\user.lib\OTA Test\Plugins\Positioners\Positioner Example.vi
    Measurement Interface\LabVIEW 2018\user.lib\OTA Test\Measurement Interface
    Visualizer\OTA Test\Visualizer
    RF System Calibration Assistant\RF System Calibration
    © 2019 National Instruments. All rights reserved.
    378173A-01
    GMT+8, 2025-5-13 18:44
