查看: 2193|回复: 0
[NI软件产品] NI mmWave OTA Validation Test Software 20.0 x64Win10 64bitEng NI毫米波空口验证测试软件20.0
    10 小时前
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2021-9-13 22:42:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    mmWave OTA验证测试软件
    mmWave OTA验证测试软件可简化并加速5G封装天线波束成形器件的特性分析和验证测试。
    mmWave OTA验证测试软件是一款应用软件,可帮助您配置、运行、可视化和报告5G mmWave封装天线集成电路(IC)空口(OTA)辐射性能。该软件可以执行系统校准,以测量每个信号路径的路径损耗,进而补偿测试仪器、电缆、天线和空口通信。此外,mmWave OTA验证测试软件还根据3GPP测试规范简化了配置和运行3D空间扫描的过程。您可以使用模板自定义测试序列,以自动执行数据采集、结果报告和存储。该软件包括一系列可视化工具,包括天线方向图、3D和极坐标图、波束宽度、热图等。
    20.0
    发布日期
    2020/8/31
    包含版本
    20.0.0完整版
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 772825088 字节 (737.02 MB)
    修改日期: 2020-08-25 19:45
    MD5: 10713826ea92a248704263156783e6cd
    SHA1: 0ef187d22bf3123ec061268491a4cbe5ebaee6ce
    SHA256: b46c4eba0677eb08837405322f42843d223816d60b78e6612bc8724845c342fb
    CRC32: 1a98d85d
    mmWAVE20.0.txt (645 Bytes, 下载次数: 0, 售价: 10 元)
    mmWave OTA Validation Test Software 20.0 Readme
    August 2020
    This file contains important information about the mmWave OTA Validation Test Software, including installation instructions, new features, bug fixes, and known issues.
    Finding Installed Software
    This software installation provides support for the mmWave OTA Validation Test Reference Architecture and helps you configure, run, visualize, and report the over-the-air (OTA) radiated performance of 5G mmWave antenna-in-package (AiP) integrated circuits.
    mmWave OTA Validation Test Software can perform system calibration to measure the path losses of every signal path, compensating for test instruments, cables, antennas, and air interface. Additionally, the mmWave OTA Validation Test Software simplifies the process of configuring and running 3D spatial sweeps according to 3GPP test specifications. You can use templates to customize test sequences to automate data collection, results reporting, and storage. The software also includes a collection of visualization tools for antenna pattern cuts, 3D and polar plots, beamwidth, heat map, and more.
    mmWave OTA Validation Software 20.0 includes the following new features:
    • Added support for the following RFmx NR measurements: ACP, CHP, EVM, OBW, SEM
    • Simplified automation API for fetching NR OTA measurement results
    • UI improvements to the mmWave OTA Validation Configurator
    • Added support for viewing new supported RFmx NR measurements in the mmWave OTA Validation Visualizer
    • Added support for OTA step-by-step and autonomous measurements in Microsoft Visual C# .NET
    mmWave OTA Validation Test Software 20.0 requires the following software versions.
    Software
    Required for LabVIEW Support
    Required for C# .NET Support
    LabVIEW 2019 (64-bit)
    LabVIEW 2019 Runtime Engine (64-bit)
    TestStand 2019 (64-bit)
    Microsoft Visual Studio† 2017
    RFmx NR 20.0
    RFmx SpecAn 20.0
    NI-DAQmx 19.1
    NI-RFSA 19.1
    NI-RFSG 19.1
    NI-RFSG Playback Library 20.0
    †  If you are using the mmWave OTA Validation Test C# .NET API, .NET Framework 4.0 (minimum) is required. To use the .NET API, you must also install .NET support for the required drivers.
    Refer to the documentation of each software product for specific system requirements.
    mmWave OTA Validation Test Software supports Windows 10 (64-bit).
    mmWave OTA Validation Test Software supports the mmWave OTA Validation Anechoic Chamber and all instruments used with the mmWave OTA Validation Test Reference Architecture. Refer to the mmWave OTA Validation Test Reference Architecture Manual at ni.com/r/otahelp for a full list of supported instruments.
    You should install application software and required software products before installing mmWave OTA Validation Test Software.
    NI installs mmWave OTA Validation Test Software using NI Package Manager. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can access the software and documentation known issues list online. Visit mmWave OTA Validation Test Software Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed between software revisions. This is not an exhaustive list of issues fixed in the current version.
    ID
    Fixed Issue
    903811Fixed an issue in which an error occurred when executing the simulation sequence in TestStand.
    903817Fixed an issue in which long test sequences in TestStand caused Windows to crash due to increased memory consumption.
    938051Fixed an issue in which the cut plane setting was not applied to the cut analysis (all beams) graphs in the mmWave OTA Test Visualizer.
    Refer to the mmWave OTA Validation Test Reference Architecture Manual, accessible from ni.com/r/otahelp, for information about the mmWave OTA Validation Test Software.
    • is an alias for the following National Instruments file folder location: Program Files\National Instruments
    Item
    Installed Location
    mmWave OTA TestStand Examples\TestStand 2019 (64-bit)\Examples\OTA Test
    mmWave OTA Validation Configurator\OTA Test\Configurator
    mmWave OTA Validation Positioner Control Panel\OTA Test\Positioner
    mmWave OTA Support for LabVIEW\LabVIEW 2019\user.lib\OTA Test
    mmWave OTA Support for .NET\OTA Test
    mmWave OTA Validation Visualizer\OTA Test\Visualizer
    mmWave OTA Validation Antenna Alignment Helper\OTA Test\Antenna Alignment
    RF System Calibration Assistant\RF System Calibration
    © 2019—2020 National Instruments Corporation. All rights reserved.
    378173B-01
    GMT+8, 2025-5-13 18:27
