查看: 2302|回复: 0
[NI软件产品] NI mmWave OTA Validation Test Software 20.5 x64Win10 64bitEng NI毫米波空口验证测试软件20.5
    10 小时前
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2021-9-13 22:45:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    mmWave OTA验证测试软件
    mmWave OTA验证测试软件可简化并加速5G封装天线波束成形器件的特性分析和验证测试。
    mmWave OTA验证测试软件是一款应用软件,可帮助您配置、运行、可视化和报告5G mmWave封装天线集成电路(IC)空口(OTA)辐射性能。该软件可以执行系统校准,以测量每个信号路径的路径损耗,进而补偿测试仪器、电缆、天线和空口通信。此外,mmWave OTA验证测试软件还根据3GPP测试规范简化了配置和运行3D空间扫描的过程。您可以使用模板自定义测试序列,以自动执行数据采集、结果报告和存储。该软件包括一系列可视化工具,包括天线方向图、3D和极坐标图、波束宽度、热图等。
    20.5
    发布日期
    2021/3/12
    包含版本
    20.5.0完整版
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 779849728 字节 (743.72 MB)
    修改日期: 2021-03-11 16:15
    MD5: e2bfe14b1287a1ac83fcea37f8d9fc99
    SHA1: ee8efef08b04c751caf7db5d2cac776395185dfc
    SHA256: 9e802990702f40e2dad9ee15aa5318746a2688d1566a53515b2a32db6d48a013
    CRC32: 7b22a798
    mmWAVE20.5.txt (645 Bytes, 下载次数: 0, 售价: 10 元)
    mmWave OTA Validation Test Software 20.5 Readme
    February 2021
    This file contains installation instructions and compatibility information for the mmWave OTA Validation Test Software.
    • mmWave OTA Validation Test Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Finding Installed Software
    This software installation provides support for the mmWave OTA Validation Test Reference Architecture and helps you configure, run, visualize, and report the over-the-air (OTA) radiated performance of 5G mmWave antenna-in-package (AiP) integrated circuits.
    mmWave OTA Validation Test Software can perform system calibration to measure the path losses of every signal path, compensating for test instruments, cables, antennas, and air interface. Additionally, the mmWave OTA Validation Test Software simplifies the process of configuring and running 3D spatial sweeps according to 3GPP test specifications. You can use templates to customize test sequences to automate data collection, results reporting, and storage. The software also includes a collection of visualization tools for antenna pattern cuts, 3D and polar plots, beamwidth, heat map, and more.
    mmWave OTA Validation Test Software 20.5 includes the following new features:
    • User interface improvements to the mmWave OTA Validation Configurator
    • Support for OTA step-by-step and autonomous measurements in MATLAB® and Python
    • Support for OTA measurements in IF-RF mode in Microsoft Visual C# .NET, MATLAB, and Python
    mmWave OTA Validation Test Software 20.5 requires the following software versions.
    Software
    Required for LabVIEW Support
    Required for C# .NET Support
    Required for MATLAB Support
    Required for Python Support
    LabVIEW 2019 (64-bit)
    LabVIEW 2019 Runtime Engine (64-bit)
    TestStand 2019 (64-bit)
    Microsoft Visual Studio†  2017
    MATLAB† 2019
    Python† 3.8
    RFmx NR 20.6
    RFmx SpecAn 20.6
    NI-DAQmx 20.1
    NI-RFSA 20.5
    NI-RFSG 20.5
    NI-RFSG Playback Library 20.6
    †  If you are using the mmWave OTA Validation Test C# .NET API, MATLAB examples, and Python examples, .NET Framework 4.0 (minimum) is required. To use the .NET API, you must also install .NET support for the required drivers.
    Refer to the documentation of each software product for specific system requirements.
    mmWave OTA Validation Test Software supports Windows 10 (64-bit).
    mmWave OTA Validation Test Software supports the mmWave OTA Validation Anechoic Chamber and all instruments used with the mmWave OTA Validation Test Reference Architecture. Refer to the mmWave OTA Validation Test Reference Architecture Manual at ni.com/r/otahelp for a full list of supported instruments.
    Download the mmWave OTA Validation Test Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Refer to the mmWave OTA Validation Test Reference Architecture Manual, accessible from ni.com/r/otahelp, for information about mmWave OTA Validation Test Software. The mmWave OTA Validation Test Reference Architecture documentation is also accessible from Start»National Instruments»OTA Documentation.
    • is an alias for the following National Instruments file folder location: Program Files\National Instruments
    Item
    Installed Location
    mmWave OTA TestStand Examples\TestStand 2019 (64-bit)\Examples\OTA Test
    mmWave OTA Validation Configurator\OTA Test\Configurator
    mmWave OTA Validation Positioner Control Panel\OTA Test\Positioner
    mmWave OTA Support for LabVIEW\LabVIEW 2019\user.lib\OTA Test
    mmWave OTA Support for .NET, MATLAB, and Python\OTA Test\Examples
    mmWave OTA Validation Visualizer\OTA Test\Visualizer
    mmWave OTA Validation Antenna Alignment Helper\OTA Test\Antenna Alignment
    RF System Calibration Assistant\RF System Calibration
    © 2019–2021 National Instruments Corporation. All rights reserved.
    378173C-01
    GMT+8, 2025-5-13 18:38
