查看: 2966|回复: 0
[NI软件套件] HIL and Real-Time Test Software Suite 19.0 Win32ENG 硬件在环和实时测试软件套件2019春季版英文
  • 签到天数: 3816 天
    连续签到: 9 天
    发表于 2021-9-15 09:51:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    套件包含:
    LabVIEW专业版开发系统
    LabVIEW高级信号处理工具包
    VeriStand完整版开发系统
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW控制设计与仿真模块
    LabVIEW状态图模块
    相关NI设备驱动程序
    2019Spring ENG32
    发布日期
    2019/8/19
    包含版本
    Spring 2019
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    应用程序位数
    32位
    语言
    英文
    校验和
    文件大小: 34177128448 字节 (31.83 GB)
    修改日期: 2019-08-19 22:22
    MD5: 7e064c6de60e4ecb332bf443498acf0a(官方正确)
    SHA1: bdb320c0226aa783090419735e9317aa9b82e4e0
    SHA256: 759d3d7c15aa490ce113c52a1bfe3f162c5ae73fdac893d1868cb15fcdbce6f6
    CRC32: dccdccc9
    HILRT TSS19.0ENG.txt (698 Bytes, 下载次数: 0, 售价: 40 圆)
    NI HIL and Real-Time Test Software Suite Spring 2019 Readme
    June 2019
    This file contains important information about the NI HIL and Real-Time Test Software Suite, including installation instructions, compatibility issues, and a list of products included on the media.
    Installing and Activating the NI HIL and Real-Time Test Software Suite
    Installing LabVIEW Add-Ons
    Products Included on the NI HIL and Real-Time Test Software Suite Media
    NI HIL and Real-Time Test Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    If you install software using the NI HIL and Real-Time Test Software Suite installation USB, complete the following steps to install products:
    • Insert the NI HIL and Real-Time Test Software Suite installation USB.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW add-ons, such as modules and toolkits, from the NI HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the NI HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    The following products are included on the NI HIL and Real-Time Test Software Suite media. The readmes for the NI software you have installed are located in the Readme directory.
    Application Software
    • JKI VI Package Manager, Free Edition
    • LabVIEW Advanced Signal Processing Toolkit
    • LabVIEW Control Design and Simulation Module
    • LabVIEW Desktop Execution Trace Toolkit
    • LabVIEW FPGA Compile Farm Toolkit
    • LabVIEW FPGA Module
    • LabVIEW MathScript Module
    • LabVIEW Model Interface Toolkit for VeriStand
    • LabVIEW Professional Development System
    • LabVIEW Real-Time Module
    • LabVIEW Unit Test Framework Toolkit
    • LabVIEW VI Analyzer Toolkit
    • NI System Configuration
    • Xilinx Compilation Tools for Windows - ISE
    • Xilinx Compilation Tools for Windows - Vivado
    • VeriStand
    Device Drivers
    • FlexRIO with Modular I/O
    • FlexRIO with Integrated I/O
    • NI CompactRIO Device Drivers
    • NI R Series Multifunction RIO Device Drivers
    • NI-488.2
    • NI-DCPower
    • NI-DAQmx
    • NI-Serial
    • NI-SWITCH
    • NI-Sync
    • NI-VISA
    • NI-XNET
    • PXI Platform Services
    Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory.
    Back to Top
    NI HIL and Real-Time Test Software Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    Back to Top
    © 2014–2019 National Instruments. All rights reserved.
    377943A-01
    GMT+8, 2026-3-5 13:23
