查看: 3143|回复: 0
[NI软件套件] HIL and Real-Time Test Software Suite 19.1 Win32ENG 硬件在环和实时测试软件套件2019秋季版英文
    前天 16:03
    发表于 2021-9-15 09:55:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    套件包含:
    LabVIEW专业版开发系统
    LabVIEW高级信号处理工具包
    VeriStand完整版开发系统
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW控制设计与仿真模块
    LabVIEW状态图模块
    相关NI设备驱动程序
    2019Fall ENG32
    发布日期
    2019/10/28
    包含版本
    Fall 2019
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    应用程序位数
    32位
    语言
    英文
    校验和
    文件大小: 36183277568 字节 (33.70 GB)
    修改日期: 2019-10-29 03:06
    MD5: 655f01ec7f306d6638b69d67b8f451e9(官方正确)
    SHA1: 14c6be2df85939253f934e60b38c42ea6f6ee3f9
    SHA256: af7ea92d0dabbae0a71231efb7b6fb9e8aa8a3e12aa3e41ba23bdbc9f3cbcb43
    CRC32: a372e0a3
    HILRT TSS19.1ENG.txt (696 Bytes, 下载次数: 0, 售价: 40 圆)
    NI HIL and Real-Time Test Software Suite Fall 2019 Readme
    September 2019
    This file contains important information about the NI HIL and Real-Time Test Software Suite, including installation instructions, compatibility issues, and a list of products included on the media.
    Products Included on the NI HIL and Real-Time Test Software Suite Media
    NI HIL and Real-Time Test Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Installation InstructionsInstalling and Activating the NI HIL and Real-Time Test Software Suite
    NI installs the NI HIL and Real-Time Test Software Suite using NI Package Manager. If you do not already have NI software installed, the NI HIL and Real-Time Test Software Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the NI HIL and Real-Time Test Software Suite. For more information on the NI HIL and Real-Time Test Software Suite activation, refer to National Instruments Software Activation.
    If you install software using the NI HIL and Real-Time Test Software Suite installation media, complete the following steps to install products:
    • Insert the NI HIL and Real-Time Test Software Suite installation media.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the NI HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the NI HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    The following products are included on the NI HIL and Real-Time Test Software Suite media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    LabVIEW Professional Development System2019 SP132-bit
    VeriStand2019 R232-bit and 64-bit
    Add-Ons
    Version
    Bitness
    LabVIEW Advanced Signal Processing Toolkit201932-bit
    LabVIEW Control Design and Simulation Module201932-bit
    LabVIEW Desktop Execution Trace Toolkit201932-bit and 64-bit
    LabVIEW Digital Filter Design Toolkit201932-bit
    LabVIEW FPGA Compile Farm Toolkit201932-bit and 64-bit
    LabVIEW FPGA ISE Compilation Tool 14.7201932-bit and 64-bit
    LabVIEW FPGA Module201932-bit
    LabVIEW FPGA Vivado Compilation Tool 2017.22019 SP164-bit
    LabVIEW MathScript Module201932-bit
    LabVIEW Model Interface Toolkit201932-bit and 64-bit
    LabVIEW Real-Time Module201932-bit
    LabVIEW Unit Test Framework Toolkit201932-bit and 64-bit
    LabVIEW VI Analyzer Toolkit201932-bit
    JKI VI Package Manager201932-bit and 64-bit
    VeriStand Model Generation Support for LabVIEW2019 R232-bit and 64-bit
    VeriStand Model Framework2019 R232-bit and 64-bit
    Device Drivers
    Version
    FlexRIO with Modular I/O19.5
    FlexRIO with Integrated I/O19.0
    NI CompactRIO19.5
    NI PXI Platform Services19.5
    NI R Series Multifunction RIO19.1
    NI-488.219.5
    NI-DAQmx19.5
    NI-DCPower19.5
    NI-Industrial Communications for EtherCAT19.0
    NI-Serial19.5
    NI-SLSC19.0
    NI-SWITCH19.5
    NI-Sync19.5
    NI-VISA19.5
    NI-XNET19.5
    Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory.
    To compare the products included in NI Software Suites, including the NI HIL and Real-Time Test Software Suite, refer to Compare NI Software Suites.
    Back to Top
    NI HIL and Real-Time Test Software Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    Back to Top
    © 2014–2019 National Instruments. All rights reserved.
    377943B-01
    GMT+8, 2026-2-25 00:57
