查看: 2740|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite Fall 2019 Win32Eng 嵌入式控制和监控软件套件2019秋季英文版ECMSS19.1
发表于 2021-10-27 14:50:45 | 显示全部楼层 |阅读模式
Embedded Control and Monitoring Software Suite是一组用于工业设备或设计智能机器的软件和工具集合。
Embedded Control and Monitoring Software Suite包含了LabVIEW以及推荐用于开发嵌入式控制和监测系统的附加工具。该套件可帮助您在设计周期的每个阶段,从建模和仿真到原型设计、验证和部署,都能通过一个高度优化的工具链快速响应系统不断变化的需求。
套件包含:
LabVIEW专业版
LabVIEW Real-Time模块
LabVIEW FPGA模块
LabVIEW MathScript模块
LabVIEW高级信号处理工具包
LabVIEW数字滤波器设计工具包
视觉采集软件
视觉开发模块
LabWindows/CVI执行评测工具包
LabWindows/CVI Real-Time模块
LabWindows/CVI SQL工具包
LabWindows/CVI完整版
Measurement Studio企业版
发布日期
2019/10/28
包含的版本
Fall 2019
受支持的操作系统
Windows 7 (SP1) 32-bit
Windows 7 (SP1) 64-bit
Windows 8.1 32-bit
Windows 8.1 64-bit
Windows 10 32-bit
Windows Server 2012 R2 64-bit
语言
English
校验和
2019Fall
32Eng
文件大小: 25331798016 字节 (23.59 GB)
修改日期: 2019-10-29 01:58
MD5: dca3517e8c6b5a07c428221314a9292a(官方正确)
SHA1: 80a006f75ece7650b2e82a9d282ccc390fcede15
SHA256: fc5a38787fdb19338b786f923281803f1a93368cc485df16b87bebbf637b8b95
CRC32: f3141764
2019FallEng.txt (683 Bytes, 下载次数: 0, 售价: 40 圆)
NI Embedded Control and Monitoring Software Suite Fall 2019 Readme
September 2019
This file contains important information about the NI Embedded Control and Monitoring Software Suite, including installation instructions, compatibility issues, and a list of products included on the media.
Products Included on the NI Embedded Control and Monitoring Software Suite Media
NI Embedded Control and Monitoring Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
Installation InstructionsInstalling and Activating the NI Embedded Control and Monitoring Software Suite
NI installs the NI Embedded Control and Monitoring Software Suite using NI Package Manager. If you do not already have NI software installed, the NI Embedded Control and Monitoring Software Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
  • Use the serial number that is included with your software to activate the NI Embedded Control and Monitoring Software Suite. For more information on the NI Embedded Control and Monitoring Software Suite activation, refer to National Instruments Software Activation.
Complete the following steps to install products using the NI Embedded Control and Monitoring Software Suite media.
  • Insert the NI Embedded Control and Monitoring Software Suite installation media.
Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
Installing LabVIEW Add-Ons
Installing LabVIEW add-ons, such as modules and toolkits, from the NI Embedded Control and Monitoring Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the NI Embedded Control and Monitoring Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
Back to Top
The following products are included on the NI Embedded Control and Monitoring Software Suite media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
Application Software
Version
Bitness
LabVIEW Professional Development System2019 SP132-bit
Add-Ons
Version
Bitness
LabVIEW Advanced Signal Processing Toolkit201932-bit
LabVIEW Desktop Execution Trace Toolkit201932-bit and 64-bit
LabVIEW Digital Filter Design Toolkit201932-bit
LabVIEW FPGA Compile Farm Toolkit201932-bit and 64-bit
LabVIEW FPGA ISE Compilation Tool 14.7201932-bit and 64-bit
LabVIEW FPGA Module201932-bit
LabVIEW MathScript Module201932-bit
LabVIEW OPC UA Toolkit201932-bit
LabVIEW Real-Time Module201932-bit
LabVIEW Unit Test Framework Toolkit201932-bit and 64-bit
LabVIEW VI Analyzer Toolkit201932-bit
NI Vision Development Module2019 SP132-bit and 64-bit
JKI VI Package Manager201932-bit and 64-bit
Driver Software
Version
FlexRIO with Modular I/O19.5
FlexRIO with Integrated I/O19.0
NI CompactRIO19.5
FPGA Interface C API19.0
NI R Series Multifunction RIO19.1
NI-DAQmx19.5
NI-IMAQ19.5
NI-IMAQ I/O19.5
NI-IMAQdx19.5
NI-Industrial Communications for EtherNet/IP19.0
NI-Serial19.5
NI-Sync19.5
NI-VISA19.5
NI-XNET19.5
Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit.
To compare the products included in NI Software Suites, including the NI Embedded Control and Monitoring Software Suite, refer to Compare NI Software Suites.
Back to Top
Back to Top
Back to Top
NI Embedded Control and Monitoring Software Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
Info Code
LabWindows/CVIcvi_lifecycle
© 2014–2019 National Instruments. All rights reserved.
377939B-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 13:25
